wlaidlaw Posted March 14, 2018 Share #1 Posted March 14, 2018 Advertisement (gone after registration) I will be looking to use a polaroid filter on my Leica Summarit 5cm/f1.5, when it gets back from cleaning, internal repainting and service by Alan Starkie, to increase the quite low contrast of this lens. As far as I can see the only original 41 x 0.5mm filters available for this lens, are Leica. Not only do folks ask huge prices for these but every one I have looked at, has either obvious or the beginnings of separation occurring. Not surprising given the sandwich construction and natural Canada balsam, used to make them in the 1950's and 60's. They are also linear polarisers, which is fine when I am using film but unsuitable for when using on digital. The obvious solution therefore is to find a step up ring and use a modern Polariser. I already have good quality Heliopan, Rodenstock or B+W polarisers in 49, 52, 58, 60, 62 and 82mm. The problem is the 41mm is an uncommon thread and even worse, Leica used 41 x 0.5mm fine pitch, when most of the rest of the world used 0.75mm pitch with any filters larger than 39mm. Does anyone know a source for 41 x 0.5mm step up rings? Wilson Link to post Share on other sites More sharing options...
Advertisement Posted March 14, 2018 Posted March 14, 2018 Hi wlaidlaw, Take a look here 41mm x 0.5mm filter step up ring for Summarit 5cm? . I'm sure you'll find what you were looking for!
wlaidlaw Posted March 14, 2018 Author Share #2 Posted March 14, 2018 Don't know why I didn't look there first but our ever helpful friends at Heavy2Stars do a 41 x 0.5mm to 43mm ring made specifically for the Summarit. https://www.ebay.co.uk/itm/New-41-43mm-and-43mm-cap-Leica-Summarit-Lens-Filter-Ring-E41-E43-/362188804260?hash=item54542290a4 Where would we be without them? Wilson 1 Link to post Share on other sites More sharing options...
jaapv Posted March 14, 2018 Share #3 Posted March 14, 2018 Be careful. These rings by Heavystar tend to bind quite severely. Link to post Share on other sites More sharing options...
Ko.Fe. Posted March 14, 2018 Share #4 Posted March 14, 2018 Then I had S 50 1.5 I purchased 40.5 adapter on eBay. It worked. Link to post Share on other sites More sharing options...
wlaidlaw Posted March 14, 2018 Author Share #5 Posted March 14, 2018 Be careful. These rings by Heavystar tend to bind quite severely. Thanks Jaap. I found that out with the Series 5.5 to e39 ring I bought from them for my 40mm Summicron-C and had to use a hair dryer to heat the lens front enough to get it off with a strap wrench. I always put a wipe of Teflon-silicone gel on the threads now. I assume it must be the anodising they use that binds to Leica alloy. However I will be using it on a chrome-brass lens as well, where they don't seem to bind as badly. Wilson 1 Link to post Share on other sites More sharing options...
Giuliobigazzi Posted March 15, 2018 Share #6 Posted March 15, 2018 When I used to own a summarit I found the Hoya 40.5mm filters to fit quite well, other brands of the same measurements did not. Link to post Share on other sites More sharing options...
wlaidlaw Posted March 15, 2018 Author Share #7 Posted March 15, 2018 Advertisement (gone after registration) In a perfect example of Murphy's law, when I was looking for something else, I found a 41 to 43mm step up ring, made by S&W Photo, attached to a 43mm ventilated metal hood. Of course by the time I found it, I had already ordered another one from Heavy2Stars. This also appears to be an S&W, so I must have acquired it from Heavy2Stars for another lens in the past, I think the Kodak 105mm/f5 I used to have on my Graflex Crown Century, before replacing it with a Zeiss 80mm/f2.8 Tessar. Wilson Link to post Share on other sites More sharing options...
bags27 Posted November 7, 2022 Share #8 Posted November 7, 2022 Wondering whether a 40.5mm filter will fit the Summarit. Lots of step-up filters of that size. Thanks! Link to post Share on other sites More sharing options...
zeitz Posted November 7, 2022 Share #9 Posted November 7, 2022 Ken, you can contact S K Grimes in Woonsocket. They will make a high quality ring for you at a very reasonable price. Link to post Share on other sites More sharing options...
bags27 Posted November 7, 2022 Share #10 Posted November 7, 2022 53 minutes ago, zeitz said: Ken, you can contact S K Grimes in Woonsocket. They will make a high quality ring for you at a very reasonable price. Thanks so very much! I had no idea of their existence, even though their minutes away from me. Much appreciated! Link to post Share on other sites More sharing options...
wlaidlaw Posted November 7, 2022 Author Share #11 Posted November 7, 2022 I seem to recall that the eBay seller Heavystar does a number of fittings for 41mm. I got a 41mm to e43 ring from them some years ago for my LTM Summarit. They also do oddities like a series 5.5 to e39 for the film Leica CL with 40mm Summicron. Wilson Link to post Share on other sites More sharing options...
