wlaidlaw Posted February 28, 2019 Share #21  Posted February 28, 2019 Advertisement (gone after registration) On 1/13/2018 at 2:38 PM, lct said: Leica warns against using UV/IR filters for film. See attachment. LeicaM_filter_uv-ir_inst_roc.pdf That file does not open in my system, either Acrobat Reader, Preview or PDF Pen Pro - all say it is corrupted. Wilson  Link to post Share on other sites More sharing options...
Advertisement Posted February 28, 2019 Posted February 28, 2019 Hi wlaidlaw, Take a look here Series VII Filter. I'm sure you'll find what you were looking for!
wlaidlaw Posted February 28, 2019 Share #22  Posted February 28, 2019 There is some ambiguous filter data on the Forum Wiki. For example for my 24/2.8 Elmarit-R ROM lens, the wiki says Series VIII. This may be required for earlier versions of the lens but mine also has an e60 thread. The only filter where a Series VIII would be an advantage is with a polariser, where the hood which acts as a series VIII filter retainer, has a small wheel at the edge which rotates the filter. This wheel does not rotate the Rodenstock E60 polariser I am using. Wilson Link to post Share on other sites More sharing options...
lct Posted February 28, 2019 Share #23  Posted February 28, 2019 5 hours ago, wlaidlaw said: That file does not open in my system, either Acrobat Reader, Preview or PDF Pen Pro - all say it is corrupted. Same here. Worked last year though. Another copy: LeicaM_filter_uv-ir_inst_roc.pdf Link to post Share on other sites More sharing options...
lct Posted February 28, 2019 Share #24  Posted February 28, 2019 5 hours ago, wlaidlaw said: There is some ambiguous filter data on the Forum Wiki. For example for my 24/2.8 Elmarit-R ROM lens, the wiki says Series VIII. This may be required for earlier versions of the lens but mine also has an e60 thread. According to my Leica catalogue from 1981, the lens has an M 60 x 0.75 filter thread and Series 8 filters to be used with the 12523 hood. Link to post Share on other sites More sharing options...
20HC Posted October 14, 2020 Share #25  Posted October 14, 2020 Hello Amaitra, Michael Geschlect and others. I've just bought an elderly Elmarit-R 90mm f2.8 for use on my SL (still awaiting the adapter). It came with a Series VII retaining ring (marked 'Germany') holding a yellow filter. I've tried to replace the VII with a 55mm (modern) filter which doesn't fit, so I'm assuming an earlier comment about 54.4mm dia. is correct. I'd like to get a clear (UV?) filter as a protector - anyone know where from (UK preferably)? BTW, I'm using a Nikon 58mm lens cap, attached to the hood rim, for carrying. Link to post Share on other sites More sharing options...
Pyrogallol Posted October 14, 2020 Share #26  Posted October 14, 2020 I think what is being said is that you will find that a regular screw in filter of an appropriate size will drop into a series filter holder in place of a plain series filter without a screw thread. An E39 filter will fit in a series 6 holder if you drop it in upside down, with the screw thread facing outward and a series 7 lenshood I bought recently 12504 had a screw thread filter inside, cannot remember what size it was.. It’s just a matter of finding a filter that fits inside the holder and still allows the retaining ring to be screwed on. Link to post Share on other sites More sharing options...
20HC Posted October 14, 2020 Share #27 Â Posted October 14, 2020 Advertisement (gone after registration) Sounds like a cunning plan - thanks very much for that idea. I'll report later tomorrow ... Link to post Share on other sites More sharing options...
20HC Posted October 15, 2020 Share #28 Â Posted October 15, 2020 To Pyrogallol - your suggestion has paid dividends, thank you! The inner diameter of the 14161 ring is just over 50mm. A modern 49mm filter fits snugly, though different filters have different rim thicknesses - thin ones 'rattle' around in the 14161 as it can't be tightened enough. But I robbed another lens of a Hoya Pro1 49mm UV and this is a 'perfect' fit. Problem solved! 1 Link to post Share on other sites More sharing options...
