Stealth3kpl Posted December 27, 2017 Share #1 Posted December 27, 2017 Advertisement (gone after registration) I read on a forum that the published resolution for the 8100i of 7200ppi is achieved using interpolation, so there is little point in scanning greater than 3600ppi (the actual scanner resolution) as it merely gives you bloated files. Is this correct? Pete Link to post Share on other sites More sharing options...
Advertisement Posted December 27, 2017 Posted December 27, 2017 Hi Stealth3kpl, Take a look here Plustek 8100 Resolution . I'm sure you'll find what you were looking for!
Stealth3kpl Posted December 28, 2017 Author Share #2 Posted December 28, 2017 I've been scanning at full resolution (in Vuescan). I was doing so to gain as much information as possible before downsizing to about 2000 pixels along the long edge. Is this a waste of time? Pete 1 Link to post Share on other sites More sharing options...
philipus Posted December 28, 2017 Share #3 Posted December 28, 2017 Hi Pete, I'm no expert on that scanner but I've read at filmscanner.info that the effective resolution is about half of 7200. If that's true, I'm wondering if scanning at 7200 isn't just bloating the file without meaningful information being added. As for scanning at a higher resolution, whether in your case 7200 or half that, and later downsizing, that can be useful in certain situations. For instance it can deal with noise in the shadows, which is also 'shrunk' as one downsizes. Personally I don't do this, though, but scan at 2000dpi because it simplifies my workflow and is big enough for internet use. I will scan higher if I need to print larger, for instance. BrPhilip 1 Link to post Share on other sites More sharing options...
pop Posted December 28, 2017 Share #4 Posted December 28, 2017 I read on a forum that the published resolution for the 8100i of 7200ppi is achieved using interpolation, so there is little point in scanning greater than 3600ppi (the actual scanner resolution) as it merely gives you bloated files. Is this correct? Pete The technical data on Plustek's site state that 7200ppi is the optical resolution of the device. Link to post Share on other sites More sharing options...
Stealth3kpl Posted December 29, 2017 Author Share #5 Posted December 29, 2017 (edited) Hi Pete, I'm no expert on that scanner but I've read at filmscanner.info that the effective resolution is about half of 7200. If that's true, I'm wondering if scanning at 7200 isn't just bloating the file without meaningful information being added. As for scanning at a higher resolution, whether in your case 7200 or half that, and later downsizing, that can be useful in certain situations. For instance it can deal with noise in the shadows, which is also 'shrunk' as one downsizes. Personally I don't do this, though, but scan at 2000dpi because it simplifies my workflow and is big enough for internet use. I will scan higher if I need to print larger, for instance. Br Philip I suspect this is the approach I'll take in future. Thanks to all who responded. Pete Edited December 29, 2017 by Stealth3kpl Link to post Share on other sites More sharing options...
Mr.Prime Posted December 18, 2020 Share #6 Posted December 18, 2020 (edited) I tried scanning some b&w negs at 3600 and at 7200 and subjectively there was more detail at full resolution. I’m wondering if there is some pixel-shifting going on or if perhaps the resolution in higher in the scan direction and interpolated between pixels orthogonal to the scan direction. Edited December 18, 2020 by Mr.Prime Link to post Share on other sites More sharing options...
pop Posted December 18, 2020 Share #7 Posted December 18, 2020 Advertisement (gone after registration) vor 3 Stunden schrieb Mr.Prime: I’m wondering if there is some pixel-shifting going on Why would that be? As said above, the device has an optical resolution of 7200 dpi. That is, if it merely records what the scan head sees, you will fetch a genuine resolution of 7200. Hence, you are bound to see more detail than at 3600. Link to post Share on other sites More sharing options...
Mr.Prime Posted December 18, 2020 Share #8 Posted December 18, 2020 (edited) 7 hours ago, pop said: Why would that be? I was under the mis-apprehension that somebody said that the optical resolution was only 3600dpi. This corresponds to 7um pixel size. Edited December 18, 2020 by Mr.Prime Link to post Share on other sites More sharing options...
bags27 Posted January 17, 2021 Share #9 Posted January 17, 2021 Here's a test https://www.dpreview.com/forums/thread/4547755 Plustek 8200i Expected 7200 Actual 3505 Plustek 8200i Expected 3600 Actual 2794 Canon FS4000US Expected 4000 Actual 3150 Epson V550 Expected 3600 Actual 1575 Nikon D610 + f/2.8 50mm D + ES2 Expected 4233 (based on 4000 pixels per 24mm) Actual 2794 Link to post Share on other sites More sharing options...
giannis Posted January 19, 2021 Share #10 Posted January 19, 2021 On 12/18/2020 at 3:27 PM, Mr.Prime said: I was under the mis-apprehension that somebody said that the optical resolution was only 3600dpi. This corresponds to 7um pixel size. The optical resolution is 7200dpi. That is for the sensor only. The real, achievable resolution, when scanning at 7200dpi, is around 3800dpi as tested with a target. The discrepancy is due to: • lens quality (in the scanner) • focus quality (in the scanner) • stepper motor quality (the thing that moves the sensor line across the film to scan it) Long story short, you get better resolution when scanning at 7200dpi, but that's a small difference compared to filesizes and scan times. The way to get the best res at the best filesize, is to scan at 7200dpi and resize (say with Bicubic) by a factor of 3 or so (roughly 1,8x in each dimension). In practice, scanning at 3600dpi (which will yield 3200-3400dpi tested with a target) is the best compromise in terms of resolution, scanning speed and file size. 1 1 Link to post Share on other sites More sharing options...
