lct Posted December 20, 2017 Share #1 Posted December 20, 2017 Advertisement (gone after registration) Protruding M lenses on the digital CL: - My Super-Angulon 21/3.4 protrudes too deeply into the CL body and cannot be used on it accordingly. Do not try folks you could damage the lens or the body. - Same for Elmar-M 50/2.8 v1 and v2 when they are collapsed, in which case their tube can hit the black sort of shade around the sensor. The same lenses work fine when they are extended though. Two solutions: don't collapse the lens of follow Leica's advice in its 120-50 leaflet for film CL (attached). - No problem with Super-Elmar-M 21/3.4 ash. - No problem either with CV Skopar 21/4. 120-50_leaflet_en_roc.pdf 3 Link to post Share on other sites More sharing options...
Advertisement Posted December 20, 2017 Posted December 20, 2017 Hi lct, Take a look here Protruding M lenses on Leica digital CL . I'm sure you'll find what you were looking for!
lct Posted December 20, 2017 Author Share #2 Posted December 20, 2017 - No problem with the Macro-Elmar-M 90/4 v1 (11633) either because it does not protrude, or so little, into the body. - I would use carefully the earlier Elmar 90/4 collapsible (11631) though as it protrudes deeply into M bodies. I don't have it with me here but i suspect what is true for the 50/2.8 is also true for the 90/4. 1 Link to post Share on other sites More sharing options...
willeica Posted December 20, 2017 Share #3 Posted December 20, 2017 I never collapse a lens ( LTM or M or other make) on any digital camera, even if people here say that you can do it. It is always better to be sure than sorry. The Super-Angulon often comes with a health warning as well. That leaflet you posted is for the film CL, which is , of course, a completely different camera. If they have not done so already, Leica should publish a similar document for the current digital CL. William Link to post Share on other sites More sharing options...
jaapv Posted December 20, 2017 Share #4 Posted December 20, 2017 Well, if you look inside the camera it is quite clear that it is impossible to use any lens that collapses or protrudes inside the body to any significant extent. One can experiment carefully (with the lens at infinity/ collapsed) as the risk of severe mechanical damage is very small. A scratch on the finish of the mask at most and easily repaired by a lick of flat black paint. Link to post Share on other sites More sharing options...
Waterden Posted December 21, 2017 Share #5 Posted December 21, 2017 List of compatible M lenses here http://uk.leica-camera.com/Photography/Leica-SL/SL-Lenses/L-Adapters/M-Adapter-L Link to post Share on other sites More sharing options...
lct Posted December 21, 2017 Author Share #6 Posted December 21, 2017 (edited) List of compatible M lenses here http://uk.leica-camera.com/Photography/Leica-SL/SL-Lenses/L-Adapters/M-Adapter-L Those are lenses recognized by the Leica M-Adapter L. Doesn't mean that M lenses not recognized by the adapter are not compatible with the CL though. As far as my own lenses are concerned, the CL works fine with Summaron 35/2.8, Elmar 90/4 and Elmar 135/4 but there are many more compatible Leitz lenses most probably Edited December 21, 2017 by lct Link to post Share on other sites More sharing options...
Joe S Posted October 22, 2020 Share #7 Posted October 22, 2020 Advertisement (gone after registration) On 12/19/2017 at 5:31 PM, lct said: Protruding M lenses on the digital CL: - Two solutions: don't collapse the lens of follow Leica's advice in its 120-50 leaflet for film CL (attached). 120-50_leaflet_en_roc.pdf 68.69 kB · 52 downloads The attached pdf won't open. Any idea of its contents? Link to post Share on other sites More sharing options...
lct Posted October 22, 2020 Author Share #8 Posted October 22, 2020 9 minutes ago, Joe S said: The attached pdf won't open. Any idea of its contents? Same leaflet here. It will open hopefully. LeicaCL_120-50_notice_p02_roc.pdf Link to post Share on other sites More sharing options...
lct Posted October 23, 2020 Author Share #9 Posted October 23, 2020 6 hours ago, Joe S said: The attached pdf won't open. Any idea of its contents? Complete leaflet attached below: 120-50_notice_en_roc.pdf Link to post Share on other sites More sharing options...
pop Posted October 23, 2020 Share #10 Posted October 23, 2020 The booklet that comes with the M-to-L adapter has this to say: Zitat Leica M lenses whose construction protrudes backwards by more than 11mm over the bayonet contact area cannot be used. https://de.leica-camera.com/content/download/143072/2416357/version/3/file/M-Adapter L.pdf, page 11. A list of all (?) supported M lenses follows. 2 Link to post Share on other sites More sharing options...
Joe S Posted October 24, 2020 Share #11 Posted October 24, 2020 The information provided for the old film Leica CL is much more helpful than the current version. It discusses the fact that collapsible lenses may need safety strips to limit the retraction of the lens barrel and even provides the width of the strips for lenses of the era. It would be helpful if Leica would provide a current list which would eliminate trial and hopefully errors. Link to post Share on other sites More sharing options...
pop Posted October 24, 2020 Share #12 Posted October 24, 2020 11 millimetres behind the bajonet contact area. How difficult is this to measure? Link to post Share on other sites More sharing options...
