I received notification from Leica NJ on 24 May 2017 that the sensor would be replaced. I called customer service today and was told that they had received a shipment of sensors and that my MM was scheduled to receive one. Expected time is now 1 to 2 weeks.
Wow
8 months!
Ah - I see, I thought you were still planning to send it in. The last I heard from the USA was early next year - more or less unspecified.
Wetzlar appears to be running steady on about twelve weeks, New Jersey about double that.
Out of fairness to NJ it should be noted that they can only install as many new sensors as they receive. I do believe that Wetzler provides (not to be confused with manufactures) the sensors. Hence.....    Regards, Ron
And today I received my Monochrom back. It was sent early August 2017 and in November I received an update from Leica Customer Care that they we waiting on the required spareparts and excused for the delay. So today 26 January 2018 the camera is back with a postcard saying "Vielen dank für Ihre Geduld and Loyalität" - Many thanks for you patience and loyalty. As I put the process in motion before the 15th of August the replacement was done under warranty at no cost as promissed. So all in all some 5,5 months between sending from Belgium to Wetzlar and being back home.
Regards
Gerd
my last post in this thread was over a month ago and i had waited 7 months then......talked to new jersey today and was told another 8 weeks because the sensors were being sent to them in such small numbers.....if indeed it is another 8 weeks that will be 10 months to get my sensor replaced THIS IS ABSURD!!!!!!!!!!!!!
