They migrate thousand of miles....
https://en.wikipedia.org/wiki/Monarch_butterfly_migration
400mm Telyt 6.8 on Nex-6. On a related note, I was thinking of replacing my Nex-6 with CL but realized that tilt screen is so much better for focusing and framing without arching your back and neck in uncomfortable position. CL is no go for me now.
Edited by jmahto
More...
Finally
Edited by jmahto
And now myself. You can see the cluster of Monarchs in the top middle. Just follow the lens.
A lovely set, and it's good to see you.  My favorite is #3.
Thanks. It is interesting that many of my friends like #3 as well but it is not my favorite. Somehow I am really bad in visualizing a vertical composition. I tend to like 16:9 (as in other two). I have to refine my sense of aesthetics I guess. :)
BTW, I realized that 400mm Telyt has a mechanism to quickly change from landscape to vertical. That's how I shot #3.
One more as I make progress in PP. This one is using X2 APO with 400mm Telyt. Merge of two side by side shots to give wide aspect ratio.
There was a huge amount of CA after pushing the files for color and removing them fully affected the color. It was still possible to go to photoshop and remove the color fringes manually but I don't have that much patience.
It is very common for the photographer to prefer an image other than the image most liked by viewers.
The set is very good and one to be proud of. The detail and color are first rate.
