fatihayoglu Posted December 5, 2017 Share #21 Posted December 5, 2017 Advertisement (gone after registration) Also, if you are considering perspective, then you need to get all the lenses with you as you cannot get a perspective with other lens. If you need to choose some items to take and some items to leave at home, you need to make some trade off's Link to post Share on other sites More sharing options...
Advertisement Posted December 5, 2017 Posted December 5, 2017 Hi fatihayoglu, Take a look here Help me Choose Lenses for a Trip. I'm sure you'll find what you were looking for!
Jeff S Posted December 5, 2017 Share #22 Posted December 5, 2017 Also, if you are considering perspective, then you need to get all the lenses with you as you cannot get a perspective with other lens. All these lenses will exhibit the same perspective IF used from the identical camera location and subject distance. Jeff 3 Link to post Share on other sites More sharing options...
Herr Barnack Posted December 5, 2017 Share #23 Posted December 5, 2017 If you insist on adhering to a three lens kit, take the 21, the 35 and the 50. Those will cover about 95% of your travel photography lens needs. 1 Link to post Share on other sites More sharing options...
fatihayoglu Posted December 6, 2017 Share #24 Posted December 6, 2017 All these lenses will exhibit the same perspective IF used from the identical camera location and subject distance. Jeff So are you saying if the subject is let’s say 2m away from the camera with a 21mm lens or with a 135mm lens, you’ll get the same perspective? Or am I wrong what you mean? Because I bet you get different perspectives as wide angle extend the fore/back ground and tele lens shortens it. But maybe there is a confusion with wording Link to post Share on other sites More sharing options...
jaapv Posted December 6, 2017 Share #25 Posted December 6, 2017 So are you saying if the subject is let’s say 2m away from the camera with a 21mm lens or with a 135mm lens, you’ll get the same perspective? Or am I wrong what you mean? Because I bet you get different perspectives as wide angle extend the fore/back ground and tele lens shortens it. But maybe there is a confusion with wording No, you have it wrong. A lens does nothing with perspective except record it. The perspective in an image is solely dependent on the subject distance. Jeff is spot-on. It is a common misconception that longer focal lengths flatten the perspective. People forget that they have to move further out to get the same field of view. If you take a photograph from the same spot the perspective of a 21 mm lens cropped to the FOV of a 135 mm lens will be exactly the same as the same image taken with the 135 mm lens Using a longer focal length is more akin to cropping an image. Link to post Share on other sites More sharing options...
Narsuitus Posted December 6, 2017 Share #26 Posted December 6, 2017 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! The perspective or relationship between a foreground object and a background object does not change if the camera location and subject distance remain the same. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! The perspective or relationship between a foreground object and a background object does not change if the camera location and subject distance remain the same. ' data-webShareUrl='https://www.l-camera-forum.com/topic/279066-help-me-choose-lenses-for-a-trip/?do=findComment&comment=3412095'>More sharing options...
Narsuitus Posted December 6, 2017 Share #27 Posted December 6, 2017 Advertisement (gone after registration) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! The perspective or relationship between a foreground object and a background object changes when the camera location is changed to keep the foreground object the same size in the camera frame. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! The perspective or relationship between a foreground object and a background object changes when the camera location is changed to keep the foreground object the same size in the camera frame. ' data-webShareUrl='https://www.l-camera-forum.com/topic/279066-help-me-choose-lenses-for-a-trip/?do=findComment&comment=3412099'>More sharing options...
jaapv Posted December 6, 2017 Share #28 Posted December 6, 2017 Indeed, because the relative distances between the objects and the camera does not change in the first example and it does change in the second. Link to post Share on other sites More sharing options...
Jeff S Posted December 6, 2017 Share #29 Posted December 6, 2017 So are you saying if the subject is let’s say 2m away from the camera with a 21mm lens or with a 135mm lens, you’ll get the same perspective? Yes. Jeff Link to post Share on other sites More sharing options...
M11 for me Posted December 6, 2017 Share #30 Posted December 6, 2017 (edited) So are you saying if the subject is let’s say 2m away from the camera with a 21mm lens or with a 135mm lens, you’ll get the same perspective? Or am I wrong what you mean? Because I bet you get different perspectives as wide angle extend the fore/back ground and tele lens shortens it. But maybe there is a confusion with wording As you can see from the above examples the perspective remains unchainged if you keep your camera position unchanged and if you only change lenses because you want to change focal lengths (lets assume you change from 28mm to 75mm). I just want to add the following: Changing lenses without changing your position means changing the angle of view and this will result in the exact same as if you had shot at 28mm and then in Lightroom you would have cropped. What you do is simply changing the angle of view as mentioned before. I evidently do not speak about the data you loose when cropping. If though that loss in data would not matter to you at all because you shoot photographs that are viewed on a smart phone screen only, then actually you would need nothing else than 1 single lens, a wide angle of course, and the preferred angle of view you simply set in Lightroom later. You can then easily simulate a135mm lens when a picture that was taken with a 21mm is cropped enough. You can save a lot of money that way at the expense of image detail or image quality. You could even go a step further and say that the term „focal length“ is not a clever measure for lenses. Imagine a 50mm lens on an M10 or a 50mm on an Olympus with its smaller „four third“ sensor. This results in a different angle of view and as a matter of fact in a different picture (with the same perspective). If we want the same angle of view on the cameras with the different sensors we would have to take a 25mm lens on the Olymus whereas we need our 50mm on the Leica full frame camera. The „angle of view“ would be the better term to define a lens as we would have one clear term for any sensor size. And as the next consequence the f Stop will have to be questioned. The f-stop is as confusing as the focal length and there would be a much better term here too. But this is another story. Edited December 6, 2017 by Alex U. Link to post Share on other sites More sharing options...
otto.f Posted December 6, 2017 Share #31 Posted December 6, 2017 (edited) The 135 for the puffins at the rocks at the west of Scotland The 28 for the landscapes The 50 for people, culture and also landscape with panorama stitching This is because you want to take only 3. I would use the 135 then for portraits which I would otherwise have done with the 85 Edited December 6, 2017 by otto.f 1 Link to post Share on other sites More sharing options...
cp995 Posted December 6, 2017 Share #32 Posted December 6, 2017 I'd take 21 - 35 - 50 for the trip 1 Link to post Share on other sites More sharing options...
fatihayoglu Posted December 6, 2017 Share #33 Posted December 6, 2017 Focal Lengths sml.jpg The perspective or relationship between a foreground object and a background object does not change if the camera location and subject distance remain the same. To me the background seems closeer on 50mm shoot than the 18mm shoot. Or are my eyes playing up the trick? Link to post Share on other sites More sharing options...
colint544 Posted December 6, 2017 Share #34 Posted December 6, 2017 I always think there's little you can't do, especially for travel, with just a 50 and a 28. https://www.instagram.com/colintempleton/ 2 Link to post Share on other sites More sharing options...
doublev Posted December 7, 2017 Share #35 Posted December 7, 2017 I always think there's little you can't do, especially for travel, with just a 50 and a 28. +1 leave the rest at home.. I think the point of the M is the compactness, isnt it? I will travel and take only 50mm.. but knowing you want to do landscapes throw the 28mm in there. 2 Link to post Share on other sites More sharing options...
Narsuitus Posted December 7, 2017 Share #36 Posted December 7, 2017 To me the background seems closeer on 50mm shoot than the 18mm shoot. Or are my eyes playing up the trick? The background is closer on the 50mm shot compared to the 18mm shot; but so is the foreground. 1 Link to post Share on other sites More sharing options...
MarkP Posted December 7, 2017 Share #37 Posted December 7, 2017 21, 35 and 50mm, no need for tele lenses. 21, 28, 50 works for me, better spacing. 2 Link to post Share on other sites More sharing options...
MarkP Posted December 7, 2017 Share #38 Posted December 7, 2017 Personally 28 & 50 as a two-lens kit. I'd next throw in a 21. A close friend would choose a 90 over a 21 for travel - everyone sees the world differently. No right or wrong. 1 Link to post Share on other sites More sharing options...
wattsy Posted December 7, 2017 Share #39 Posted December 7, 2017 (edited) Zeiss Distagon 1.4/35 ZM Zeiss Planar 2/50 ZM T* Zeiss 28/f2.8 Biogon ZM T* Zeiss 2.8/21 Biogon ZM T* Zeiss 4/85 ZM Tele-Tessar T* Leica Tele-Elmar-M 135mm F4 Which 3 lenses would you take? I think the answer depends upon how you are travelling. If you are driving around but based in only a few hotels you may as well take the lot (they will all easily fit into a Domke or Billinghma bag) and then take out for the day what lens(es) you are likely to want. If you really only want to take three then 28, 35 and 85 seems like the obvious choice to me but that is just because that is my preference. The last time I did a multi-week touring type holiday was before my daughter was born and when I used an M8 with 28 and 50 (effectively 37mm and 65mm). I don't remember hankering after any other lenses though if I did it again I'd probably take my 28, 35 and 90 lenses. Edited December 7, 2017 by wattsy 1 Link to post Share on other sites More sharing options...
a.noctilux Posted December 7, 2017 Share #40 Posted December 7, 2017 (edited) I think the answer depends upon how you are travelling. If you are driving around but based in only a few hotels you may as well take the lot (they will all easily fit into a Domke or Billinghma bag) and then take out for the day what lens(es) you are likely to want. If you really only want to take three then 28, 35 and 85 seems like the obvious choice to me but that is just because that is my preference. The last time I did a multi-week touring type holiday was before my daughter was born and when I used an M8 with 28 and 50 (effectively 37mm and 65mm). I don't remember hankering after any other lenses though if I did it again I'd probably take my 28, 35 and 90 lenses. Bolded by me. Ian sees things as me in one post : see post #2 and #8, first page Edited December 7, 2017 by a.noctilux 1 Link to post Share on other sites More sharing options...
