Imar Posted October 18, 2017 Share #1 Posted October 18, 2017 Advertisement (gone after registration) I've recently bought a Summitar in very good condition (I hope) from an Austrian Leica specialised shop. It is the ten aperture blade version instead of the six aperture blade version. Overall condition looks very good. No visible scratches on the front element or back element and focus is smooth. While scanning the first results I noticed that the centre of the frame has less contrast and is lighter than the outer portions of the frame. First I thought this is internal reflections or incoming light from the side. I didn't use a hood. But looking at more frames it also shows while the sun is coming from behind me so flare is not so likely. Does anyone has an idea about what this could be? I’ve attached some unedited scans. The are shot with Tri X / TMax 400 @ 250, developed for 6 min. in HC-110 at 20C. It is not in every frame. I used the sunny 16 rule (lens only goes to 12.5 so I compensated for that). Hope to find out if it is the lens, light conditions or something else. Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted October 18, 2017 Posted October 18, 2017 Hi Imar, Take a look here What could be wrong with my Summitar?. I'm sure you'll find what you were looking for!
earleygallery Posted October 18, 2017 Share #2 Posted October 18, 2017 Could possibly be internal haze, or veiling flare. You need to take some shots in controlled lighting of a test chart or similar. If it's haze you should see it but try shining a light through the lens and look through the other end - post a photo of it if you can. Link to post Share on other sites More sharing options...
Ecar Posted October 18, 2017 Share #3 Posted October 18, 2017 Indeed, if the front and rear elements look good, it's probably haze on an internal one. Also, is it a coated or uncoated lens? If memory serves, the early 10-blades Summitars were uncoated, while the last ones before the introduction of the 6-blades versions were coated. Early coatings were not as stable/resistant as those we know today, so I'm wondering if coating degradation could somehow cause the issue. Link to post Share on other sites More sharing options...
Imar Posted October 18, 2017 Author Share #4 Posted October 18, 2017 Thanks for the input. As soon as I can I will do the flashlight test. This version is the uncoated version. Is it possible to remove haze? Link to post Share on other sites More sharing options...
TomB_tx Posted October 18, 2017 Share #5 Posted October 18, 2017 It depends on the cause of the haze. I've had several lenses of similar vintage cleared during a CLA service, and one Leica tech noted she used a liquid provided by Leica to remove haze. However, sometimes a glass surface may become etched, or the glue between elements affected, and little can be done. My 1939 Summitar cleared up well. Link to post Share on other sites More sharing options...
earleygallery Posted October 18, 2017 Share #6 Posted October 18, 2017 If it's haze I'd be inclined to send the lens back for a refund. Link to post Share on other sites More sharing options...
jaapv Posted October 18, 2017 Share #7 Posted October 18, 2017 Advertisement (gone after registration) I agree with the haze diagnosis. I would advise contacting the seller and have them CLA the lens. Link to post Share on other sites More sharing options...
Stein K S Posted October 21, 2017 Share #8 Posted October 21, 2017 Hi I have a Summitar # 526606 with the same problem. Then I discovered a strange ¨oval glare¨ behind the first lens element ( I dontˋ know how else to put it). Classic Camera in London looked at it and suggested that the glueing of lens element 1 and 2 had started to loosen. Was possibly fixable... but costly. Good luck! Link to post Share on other sites More sharing options...
arno_nyhm Posted October 21, 2017 Share #9 Posted October 21, 2017 the summitar often suffers from lens-separation. does the problem also occur, when you stop the lens down to f=8 or more? Link to post Share on other sites More sharing options...
einem anderen Posted October 25, 2017 Share #10 Posted October 25, 2017 It looks like ping pong of reflexions between the stopped down aperture and the filmsurface, compare it with open aperture. Link to post Share on other sites More sharing options...
pgk Posted October 27, 2017 Share #11 Posted October 27, 2017 Try using an LED torch to inspect the lens internally as it will illuminate any dust, have and separation. If it turns out that the adhesive holding elements together is failing then it should be possible to have this repaired as its likely to be Balsam rather than a UV cured adhesive so can be softened and removed usually. You will need to find a specialist and ensure that they can remove the old adhesive, accurately realign the elements and then re-glue (probably with a UV cure adhesive) them. Its unlikely to be cheap so if you can get this sorted under warranty it would be viable. If not then I'd return the lens for a refund because it won't get any better on its own! Link to post Share on other sites More sharing options...
