Leica M10 and glue
willemr
  • 2 weeks later...
In my experience the best way to remove the adhesive from the label on the base plate of the M10 is to roll it with your finger into a small ball, then roll it off the base plate. It’s enough material that googone or other organic solvents will create quite a mess before you get perfectly clean results.
I agree, I did the same, and also used the adhesive, applying it to the remains it helped take them off.
I also reported it.
  • 3 weeks later...
Same thing happened to the bottom of my M10. I rubbed it off with an alcohol prep. Took no time at all.
I don't know why the glue on the M10 does that. When I bought my M6TTL back in 2000, the protective film on the baseplate came right off.
