Heard from Leica in New Jersey today.  Seems they've had about 2000 cameras in for repair this year already BUT only about 4 with this issue.  Can occur due to mounting lenses poorly, or at attaching a lens at a bad angle.  Could also be cause by trauma.  I asked if 3rd party lenses might cause it, which I was told initially would....but the fellow said only  if you were using an adaptor....which rules me out.
This problem is not common so they haven't spent a ton of time researching why.
Unfortunately, I have a crack in the 6-bit reader of my M240, which I must admit I caused myself, long embarrassing story. Whilst it does annoy me, it still reads every 6-bit coded lens correctly every time, and the crack does not appear to be getting any worse over time. I may get around to replacing the entire lens mount one day including the 6-bit reader (does anyone know if this is even possible?), but unless it starts to mis-read the 6-bit code, at the moment I just live with it.
As the reader is easily accessible after removing the lens mounting flange, it should be a simple repair.
From Mark Norton's "Anatomy" thread.
I spoke with the Leica tech yesterday and yes, you can most certainly have it repaired.  I'm sending mine in tomorrow.  Not sure the cost....but I want to sell my M240 , sadly - so I want it fixed.  I'm having issues with my eyes and want an autofocus system.... moving over to Sony.
  • 1 year later...
Does anyone know any more about how the cover glass can get cracked?
i just purchased a used m240 from the Leica store in London. I was cleaning the main camera sensor yesterday prior to first use and noticed 2/3rds of the 6 bit coding cover glass in the mount is missing. I assume the damage was there when I purchased the camera.
If this is a sign of prior trauma I think I will see if I can return the camera.
I think your first step should be to contact the dealer in question ASAP.
On 5/22/2017 at 1:26 AM, ECohen said:
I just love the photos of my cameras guts......thank you for posting!
No thanks:-)
Up until a moment ago, I was imagining the inside of my M262 to be just like the inside of my M3, except with a digital sensor where the film would be...
