Leica 75mm Noctilux to be realised in 2017...
w44neg
  • Replies 113
  • Created
  • Last Reply
Now, what Leica lens can be the equivalent of Dog and Rat meat in Chinese soup?
All!
A sharp lens?: "Wow, Masterpiece!"
A soft lens?: "Wow, Masterpiece!"
A Lemon?: "Wow, masterpice! You need two, one for the special look, another for the standard look"
A battered lens?: "Wow, masterpiece with fine patina!"
A New lens: "Wow, masterpiece! I shall not use it and keep it as a collector."
Each and every M lens is like a Dog and Rat Chinese soup.
You have your own way to show excitement about this expected product of 2017 Leica optical technology,
which thanks to the M-constraints will hopefully not suffer from Otus-gigantism.
€ 9000 (I presume) for a lens that seems to have again a shortest distance of 1m. Although this gives a smaller subject field than the Noctilux 50, it would still miss the charms of the historically smallest subject field of the Summilux 75.
If this is a longer Noctilux 50/0.95 I think it will be nice on the SL, but ergonomically a bit too heavy on the M10 I'm afraid
Could this lens be too wide for the M, and not allow rangefinder focusing? [...]
No problem, in theory at least. With 0.72x VF magnification it would be as easy (or difficult) to focus as a 135/4 lens at full aperture.
The next will be a 35mm Noctilux, at f/1.399
1.39/35mm Noctilux APO ;) !
On a serious note: the focal length of 35 is the sweet-spot, so a 2.0/35 APO
and also a 35mm Noctilux would find a lot of customers.
I think it stands as much chance as a chocolate teapot.
:) well, when Leica makes chocolate teapots, they tend to be a great success, at least a great hype. See for instance the wide-angle summiluxes and the 50mm/0.95
I'm pretty sure the aberration APO corrects for is found in long focal lengths. Not previously regarded necessary even on 50mm lenses. Goes to show the power of marketing I suppose as I have seen this a few times.
