orc999 Posted December 28, 2016 Share #1 Posted December 28, 2016 Advertisement (gone after registration) Hello often after turning back from sleep mode to AF point appears in the very corner of the frame. This is getting very annoying. Is tgere any way to fix this? best regards Link to post Share on other sites More sharing options...
Advertisement Posted December 28, 2016 Posted December 28, 2016 Hi orc999, Take a look here Autofocus point in corner after sleep. I'm sure you'll find what you were looking for!
SrMi Posted December 28, 2016 Share #2 Posted December 28, 2016 Do you have rear monitor turned on or does it happen also in EVF-only mode as well (to switch between modes, press the button to the right of viewfinder)? I have experienced that issue on some other cameras, which was caused by accidentally touching the screen (with the nose?) and thus moving the focal point into the corner. It never happened to me with the SL, maybe because I am most of the times in EVF-only mode (SL is the only mirrorless where that mode makes sense, since I can still use LCD for menus and review). Link to post Share on other sites More sharing options...
orc999 Posted December 28, 2016 Author Share #3 Posted December 28, 2016 yes I was thinking that could be the reason(...touching with the nose most likely). Sadly I did not find a option to disable the touchscreen(...or focus). I figure out you are right about the EVF only mode works really well, can still review and use menues on the lcd. Impressed. The M with EVF is a bit crap to review, need to switch. Sony A7r2 was also a bit off the proper use for my taste, don't exactly remember the problem. Anyway like this it looks like I'm gonna save on battery life...yet to see if the focus point was moved by accidental touch. Strange it always appears in the very corner. I was also thinking I could have accidentally touched the joystick and it would have moved. Anyway I never had such a problem on a different camera. Hope to figure out to fix it. Link to post Share on other sites More sharing options...
orc999 Posted December 28, 2016 Author Share #4 Posted December 28, 2016 actualy als the display setting changes all the time because the BR button is hit easily while the camera is around the neck and touches my body. The buttons are generaly great, but there should be some option to be protected from this. I know there is a key lock but that seems a bit extreme. Link to post Share on other sites More sharing options...
IkarusJohn Posted December 28, 2016 Share #5 Posted December 28, 2016 I carry the camera slung over my right shoulder, lens facing my body. That way, the lens is reasonably protect behind my thigh, and the lcd doesn't rub against my clothing - might solve your button pressing problem? Link to post Share on other sites More sharing options...
LD_50 Posted December 28, 2016 Share #6 Posted December 28, 2016 So many posters here seem not to be able to read or search the instruction manual. Search "touch AF" or "touch" and you find logically the section on page 207 of the English manual explaining how to disable touch-controlled autofocus. Link to post Share on other sites More sharing options...
vintola Posted December 28, 2016 Share #7 Posted December 28, 2016 Advertisement (gone after registration) So many posters here seem not to be able to read or search the instruction manual. Search "touch AF" or "touch" and you find logically the section on page 207 of the English manual explaining how to disable touch-controlled autofocus. In my manual page 213. - vintola - Link to post Share on other sites More sharing options...
orc999 Posted December 29, 2016 Author Share #8 Posted December 29, 2016 RTFM true anyway I was not sure if this is the cause. I will keep you updated. Link to post Share on other sites More sharing options...
orc999 Posted December 29, 2016 Author Share #9 Posted December 29, 2016 I carry the camera slung over my right shoulder, lens facing my body. That way, the lens is reasonably protect behind my thigh, and the lcd doesn't rub against my clothing - might solve your button pressing problem? yes I do that too, however not with that tripod socket connection, as I don't trust it. Now with the big SL lens the head will probably be hanging down and touch less easy then with a light M lens. I will see if I can find a secure way with bottom attachment. there are safety atachements. Link to post Share on other sites More sharing options...
SrMi Posted December 29, 2016 Share #10 Posted December 29, 2016 yes I do that too, however not with that tripod socket connection, as I don't trust it. Now with the big SL lens the head will probably be hanging down and touch less easy then with a light M lens. I will see if I can find a secure way with bottom attachment. there are safety atachements. I like RRS bottom plate and a dual QD sling strap. Reliable and quick to detach in case I need to store the camera or to mount it on a tripod Link to post Share on other sites More sharing options...
IkarusJohn Posted December 29, 2016 Share #11 Posted December 29, 2016 yes I do that too, however not with that tripod socket connection, as I don't trust it. Now with the big SL lens the head will probably be hanging down and touch less easy then with a light M lens. I will see if I can find a secure way with bottom attachment. there are safety atachements. What's wrong with the standard attachments? Link to post Share on other sites More sharing options...
orc999 Posted December 30, 2016 Author Share #12 Posted December 30, 2016 those bottom plates can loose up. camera ends crashing on the floor. the standard left right will not have lens down facing as suggested by srdj Link to post Share on other sites More sharing options...
ramarren Posted December 30, 2016 Share #13 Posted December 30, 2016 I gave up on shoulder straps for the SL. I use a wrist leash when shooting (Harry Benz' La Cravate Brogue with a small customization (that he now ships with every one)) and carry the camera in as small a bag as it will fit in. This way it's either in my hand because I'm shooting or it's in the bag because I'm carrying. No mistakenly pressed buttons, no clumsy hanging it by the tripod mount, etc etc. Link to post Share on other sites More sharing options...
Donzo98 Posted December 31, 2016 Share #14 Posted December 31, 2016 Which bag are you using G??? Link to post Share on other sites More sharing options...
ramarren Posted January 1, 2017 Share #15 Posted January 1, 2017 Small bag: Billingham L2 "Alice" ... just big enough to fit SL + SL24-90, also fits SL with up to three R lenses, like 24/50/90 (that's a little tight, usually just two is better). This is what I use most of the time. Large bag: Tenba Cooper 13SLR ... can fit way more than I ever want to actually lug around at one time. For instance: SLfitted with SL24-90, Super-Elmar-R 15mm, Elmar-R 180mm f/4, and Telyt-R 250/4. It would easily fit the SL + SL24-90 + SL90-280 + a wide like the Tri-Elmar-M 16-18-21 or maybe the upcoming SL16-35. If I ever need to carry more than that, I pull out my Pelican rollaway hard case. :-) Link to post Share on other sites More sharing options...
orc999 Posted January 8, 2017 Author Share #16 Posted January 8, 2017 I was out on a documentary for a week and can confirm: after deactivating the touch AF selection the problem disappeared. Link to post Share on other sites More sharing options...
