roshuu Posted December 22, 2016 Share #1 Posted December 22, 2016 Advertisement (gone after registration) I have a question. I bought Voitlanger 40 mm f / 1.4 to filter Leica E43 UV / IR.Do you recommend to enable the Leica M8 menu function "on + uv / ir" or better left to the "off"? Voitlanger of course, is not encoded. I have the impression that the pictures from the "off" are more greenish than with "a + uv / ir." How do you have at home? Does it also affect the sharpness of jpg files is? Link to post Share on other sites More sharing options...
Advertisement Posted December 22, 2016 Posted December 22, 2016 Hi roshuu, Take a look here Voigtlander 40 / 1.4 with E43 UV / IR. I'm sure you'll find what you were looking for!
lct Posted December 23, 2016 Share #2 Posted December 23, 2016 I don't shoot jpegs but with non coded lenses i've always set Lens Detection to off on my M8.2. According to the M8.2 instructions (page 104) « When using aperture priority and manual exposure setting in conjunction with a lens without 6-bit coding, the camera’s identification function must always be turned off, to prevent malfunctions ». Also the Leica UV/IR filters instructions state that « Leica 6-bit coded lenses are necessary for the use of this filter with the Leica M8 ». I would take those warnings with a pinch of salt though as one of my favorite lenses on M8.2 is an uncoded Summilux 35/1.4 v2 on which i use Leica UV/IR filters with no problem at all. But again i don't shoot jpegs so i don't know how the camera behaves in this format. Link to post Share on other sites More sharing options...
roshuu Posted December 24, 2016 Author Share #3 Posted December 24, 2016 The image is then greenish, with the function to "on + uv / if" color is better, more natural. I checked. Link to post Share on other sites More sharing options...
lct Posted December 24, 2016 Share #4 Posted December 24, 2016 So much the better. Link to post Share on other sites More sharing options...
roshuu Posted January 17, 2017 Author Share #5 Posted January 17, 2017 Does this affect the picture? The original filter Leica UV / IR not tightened completely on the lens Voigtlander 40 / 1.4 or 35 / 1.4. See the picture: Link to post Share on other sites More sharing options...
lct Posted January 17, 2017 Share #6 Posted January 17, 2017 If it is the # 13417 (M43 x 0.75) Leica UV/IR filter it should fit the filter thread of the CV 40/1.4 which has also a 0.75 pitch if i'm not mistaken but i have no experience with this combo. Otherwise it could damage the filter thread of the lens but i won't affect the image quality of the lens anyway. Link to post Share on other sites More sharing options...
roshuu Posted January 17, 2017 Author Share #7 Posted January 17, 2017 Advertisement (gone after registration) Screwing up badly but sitting and mechanically is ok. I was just wondering whether such a 1-2mm gap has no effect on the image (the impression of blurred images, etc.) Link to post Share on other sites More sharing options...
lct Posted January 17, 2017 Share #8 Posted January 17, 2017 I don't think so. Link to post Share on other sites More sharing options...
roshuu Posted January 17, 2017 Author Share #9 Posted January 17, 2017 Check it out - the picture is as if shaken but time was 1/180, focal length 40 mm made from a stable position ... It is rather not the fault of the filter? Link to post Share on other sites More sharing options...
lct Posted January 17, 2017 Share #10 Posted January 17, 2017 I don't think so. More probably a focusing issue due to focus shift and/or RF misalignment. Just compare with and w/o filter to be sure. Link to post Share on other sites More sharing options...
roshuu Posted January 17, 2017 Author Share #11 Posted January 17, 2017 LCT have! I checked DNG and see below.It turned out that .jpg M8 little "treats" details.Image of DNG to the default settings in the Camera Raw is sharp, has a better detail. Too bad, because I wanted to do .jpg straight from the camera ... Link to post Share on other sites More sharing options...
