Shooting Ektar 100. Rate at box speed or 50?
Kupo43
Hello Kupo43,
Welcome to the Forum.
If you pick up a roll of Ektar 100 & hold it horizontally with the little nubbin to your left & then tell us the colors in the 6 boxes on the top row: Reading left to right: For example: white - black - white - black - white - black
And then read us the lower row in the same manner:
I will tell you what those 12 little boxes would tell an M7 to do.
Best Regards,
Michael
Ektar will give even more saturated colours at 1 stop over. Rate at 100 for more realistic, but still highly saturated, colours.
You can happily rate Portra at half box speed, though.
Cheers
J
Sent from my iPhone using Tapatalk
Yes - but be careful with blue skies which seem to turn cyan if over-exposed (at least with my processing!).
I normally rate Ektar at 80, and then if the scene is worth bracketing I will take another exposure with 1/2 to a full stop more light.
This topic recently came up on the I Like Film thread and I remarked that I find Ektar a bit tricky b/c it has a fair amount of latitude but if you push your luck too much it affects the color balance and doesn't sing as it should.
A couple of recent examples:
One thing I know about Ektar 100 is that it loves sunlight, the more the better. I've tried over / under exposing it and have typically found that box speed was ideal, however I haven't tried rating it at 80 yet so I'm curious to try that out myself!
There is only 1/3 stop difference between ISO 100 and ISO 80. I would be pleasantly surprised if the shutter speeds of my M6 or M2 were accurate to 1/3 stop. However, ISO 80 would at least help insure that one is not underexposing the Ektar,
Hello Kupo43
Did you consider doing what I suggested in Post #2 above?
Best Regards,
Michael
Hey Michael,
I don't have a roll with me at this point; I've ordered some and it's on the way. I've shot it at box speed before but found that when underexposed shadows have a strange purple tint. I'll make sure to check in when I receive the film. Thanks!
Hey Michael,
Under exposure is not caused by the film. So adjusting the film speed to compensate for either the camera or the photographer is the wrong way to go because the camera or photographer will still under expose using other film types, and they always end up chasing their tail asking 'what is the correct film speed?'. It's better to determine if your camera meter is accurate, or if the photographer is metering for the scene intelligently. Of course the way to compensate for an inaccurate meter is to change the ISO so the camera thinks the scene is too bright or too dark, but this will be universal across all films. The way the photographer can compensate for under exposure is to take a reading with more shadow in the meter area and then recompose.
Others in this thread have commented on the different effect over or under exposing film has on colour, but the effect a photographer wants (and created by changing the ISO) is separate to the basic exposure principle. This because even if the ISO is set at 50 for the effect on the colour, the scene will still need metering intelligently by choosing to further over or under expose the image if necessary to maintain that effect. So by all means experiment with film speeds, but it is never a direct equivalent of compensating for correct average exposure because as soon as you dial in a different ISO (given an accurate meter) the effect it has on the films characteristic curve changes the nature of the films response and look, and this is true for B&W as well as colour.
All makes sense.  I would just clarify that my general workflow of rating medium to high contrast scenes at 80 (and then developing at 100) is simply to ensure that I don't underexpose by not choosing the right average meter reading that is appropriate for the given scene.  Lots of times it is not super clear as to what the correct average reading should be, particularly when the darkest areas are in the 3-4 zones and the brightest areas are in the 7-9 zones.  You know you're gonna have to compromise, but which way to you go?  Keep the dark zones dark w/ little or no details (or with detail but with ugly color casts) and crush some shadows or increase the exposure a little to better preserve the shadow detail but then move the bright zones closer to 9 and then pure white and risk, e.g., not getting as pretty of a blue sky or lose some other pastels in the horizon.  I don't think one can say that there is a single right answer for this; I would argue that it is highly dependent on the particular scene as well as the intended rendition. With B&W, there is much more artistic freedom; but with color, especially Ektar, one is constrained by the knock-on effects of the color palette.  My main point was that I find Ektar to be particularly sensitive to color shifts when it either gets too much light or not enough light.  B/c I find the shifts to be particularly undesirable with underexposure, I tend to put my finger on the scale ever so slightly with a 1/3 stop increase in light - and then I take my average readings and see which zones it puts the brightest, darkest and middle gray parts of the scene.  And then I adjust (as anyone should) this accordingly to make sure that you hit that sweet spot of EVs to strike the best balance between getting the best exposure and minimizing color shifts.
Thanks Adam. Nicely put. Again though you are discussing the problem of getting the optimal exposure which is often more art and experience than science, and as so often with film it's just that bit more tolerant to overexposure.
