biglouis Posted September 29, 2016 Share #1 Â Posted September 29, 2016 Advertisement (gone after registration) I have a Nissin i40 which is in other words a Leica SF40 but my copy is designed for use on micro 43rds cameras. Â Can I use this flash safely on my Leica Q in manual mode? Is it likely to work? Â Thanks in advance if anyone knows the answer. Â LouisB Link to post Share on other sites More sharing options...
Advertisement Posted September 29, 2016 Posted September 29, 2016 Hi biglouis, Take a look here Nissin i40 on Q . I'm sure you'll find what you were looking for!
Voxen Posted September 29, 2016 Share #2 Â Posted September 29, 2016 Mine (for Fujifilm) works with the Q in manual mode without any problem. 1 Link to post Share on other sites More sharing options...
esophoria Posted September 29, 2016 Share #3 Â Posted September 29, 2016 I have a Nissin i40 which is in other words a Leica SF40 but my copy is designed for use on micro 43rds cameras. Â Can I use this flash safely on my Leica Q in manual mode? Is it likely to work? Â Thanks in advance if anyone knows the answer. Â LouisB Â I have both the i40 and the SF 40... Â you can safely use the i40 on the Q in manual mode. Â It will just fire the flash...no harm to the Q. Link to post Share on other sites More sharing options...
Bjiork Posted September 29, 2016 Share #4 Â Posted September 29, 2016 Is the flash locking in the position and stays ok? Link to post Share on other sites More sharing options...
Louis Posted February 4, 2018 Share #5 Â Posted February 4, 2018 Mine (for Fujifilm) works with the Q in manual mode without any problem. Â If Nissin i40 for Fujifilm works manually on Q, does any other flash for Jujifilm camera also work on Q manually? Link to post Share on other sites More sharing options...
Louis Posted February 4, 2018 Share #6 Â Posted February 4, 2018 I have both the i40 and the SF 40... Â you can safely use the i40 on the Q in manual mode. Â It will just fire the flash...no harm to the Q. Â For what camera is your Nissin i40?... As I understand, onluy i40 for Fujifilm works manually on Q? Link to post Share on other sites More sharing options...
hliewprk Posted February 11, 2018 Share #7  Posted February 11, 2018 Advertisement (gone after registration) I had Fujifilm ef-x20 flash in manual mode - 1/64, Q set to A for aperture, iso, ss. Just shoot and indoor pics seem to be like out of TTL mode. Need to change aperture, rotate the top dial backwards. Not sure how the flash works with Q but SF40 would be nice. Link to post Share on other sites More sharing options...
bandrews Posted February 12, 2018 Share #8  Posted February 12, 2018 If Nissin i40 for Fujifilm works manually on Q, does any other flash for Jujifilm camera also work on Q manually?  I may be wrong but believe most modern flashguns should work in manual mode as they use the central pin to trigger. 1 Link to post Share on other sites More sharing options...
hliewprk Posted February 12, 2018 Share #9  Posted February 12, 2018 yes, my 15 year old canon 550ex works just fine with Q. Seems work in eTTL mode but no preflash for TTL. 1 Link to post Share on other sites More sharing options...
jaapv Posted February 12, 2018 Share #10 Â Posted February 12, 2018 And no worries about harm. Leica uses high-voltage circuitry for the flash. 1 Link to post Share on other sites More sharing options...
jmschuh Posted February 12, 2018 Share #11  Posted February 12, 2018 yes, my 15 year old canon 550ex works just fine with Q. Seems work in eTTL mode but no preflash for TTL.   It is unlikely or impossible that the Q supports the Canon ETTL protocol. Link to post Share on other sites More sharing options...
rijve044 Posted February 12, 2018 Share #12 Â Posted February 12, 2018 Does anybody knows if Leica uses the Nikon configuration of the contacts in the hotshoe? Leica has 4 extra contacts, Nikon 3 contacts. I can see these 3 could match with the Leica contact pins. Otherwise I can go on manual and use the central synchronisation pin only. Thanks. Link to post Share on other sites More sharing options...
uffehagen Posted February 12, 2018 Share #13 Â Posted February 12, 2018 Does anybody knows if Leica uses the Nikon configuration of the contacts in the hotshoe? Leica has 4 extra contacts, Nikon 3 contacts. I can see these 3 could match with the Leica contact pins. Otherwise I can go on manual and use the central synchronisation pin only. Thanks. Â I have Nikon SB800 and Nikon SB900, and they will fire but no TTL. I set the flash to A and the same Aperture on the Q to get a normal flash output. Distances can be read on the flash display. By changing the A on either flash or Q I can have a little more or less light Link to post Share on other sites More sharing options...
rijve044 Posted February 12, 2018 Share #14  Posted February 12, 2018 I have Nikon SB800 and Nikon SB900, and they will fire but no TTL. I set the flash to A and the same Aperture on the Q to get a normal flash output. Distances can be read on the flash display. By changing the A on either flash or Q I can have a little more or less light  Thank you very much for this information. No Auto TTL that's what I wanted to know. Regards Dre Link to post Share on other sites More sharing options...
yuanna Posted March 11, 2018 Share #15  Posted March 11, 2018 (edited) I have Nissin i60 for my Sony a7rii, trying to use on my new Leica Q camera, I only need multiple manual output power for shooting, does any body know is safe to use ? pleas advise. thanks. Edited March 11, 2018 by yuanna Link to post Share on other sites More sharing options...
