Fondation Vuitton - Frank Gehry by JM__, on Flickr
18 Super Elmar - Velvia 50 - Leica MD
Turin at sunset.
M + CV Ultron 21/1.8
Edited by epand56
On 9/19/2018 at 8:37 PM, jmahto said:
M240 with CV15mm VII shooting M2 shooting Mono Lake :)
Please how did you manage to avoid the Italian flag with this lens on the M240?
My CV 15 v. II always features a red stripe on the right side.
How are y'all even making images that are capable of being uploaded from LR? I just tried on an M10 file and it won't even try...
I use flat field processing on LR. It is one click processing. All you have to do is to supply the flat field sample pic. I created one for myself by shooting a uniform white subject with my lens coded as 21mm. You should use the same coding for flat field sample and your actual photo since LR will use the format as template for color correction and fall off. In practice I have noticed that even without lens coding match LR flat field processing does more or less ok job.
If you don't want to create your own sample and want to use mine then DM me and I will share my samples. If you are not using LR then also it is possible by special programs but probably with less success. You need to search it up.
Edit: Because of this I am not tempted to upgrade to VIII. Mine is small enough to be carried anywhere. :)
This is without FF correction. You can see the coloration on the right side and severe vignetting.
Edited by jmahto
It's really not rocket science... export to a jpeg with 1280px longest side and then optimize using something like https://tinyjpg.com/
Not sure but try also setting a longest side limit to 1000 pixels
Try this. Screenshot of LR export dialog.
Leica M10 + Leica Wide Angle Tri-Elmar 16-18-21mm F/4 ASPH @ 16mm
Sunset View of The Peak by Andrew Tan, on Flickr
Edited by andrewtansj
I did not use it for years, but Cornerfix was working fine, if I remember correctly. It is based on a profile you need to create.
I used Cornerfix about 10 years ago and it was a bit messy. Now I just slide the vignetting tool in Lightroom to the right and it fixes any 'Italian Flag' in seconds. If any red still remains you can desaturate red slightly. I used this recently with a Voigtlander 21mm Color Skopar and it worked perfectly. Even 6 bit coded lenses such as the Leica WATE and 24mm can display some 'Italian Flag' and a tiny adjustment eliminates this.
I don't bother with creating profiles. I find that this is not necessary.
William
Edited by willeica
Two ladies and many colors on a beach in riviera.
M + CV Ultron 21/1.8 Asph.
As I much as I enjoy the Leica system, I sure hate being associated with communities like this 😕
M10 + CV 21/4 here, public park in Austin. Thx for the help minus snark, Exodies and jmahto :)
Ponte Vecchio, M M246, 21mm SEM
Edited by eddds
Portofino, MM246. 21mm SEM
Regards,
Edgard
  • 3 weeks later...
Times Square
Leica M240 with Voigtlander Ultra Wide Heliar III 12mm F/5.6
1/350 sec F/16
Voigtlander 10/5.6 Heliar Hyper-wide with SL.
Egyptian Avenue, Highgate West Cemetery, London.
  • Like 16
  • 2 weeks later...
Hi everyone.
I'm thinking of investing in a wide angle lens for my M10.  I have a 50mm and 90mm Summicron lenses. I also have a Leica Q with its fixed 28mm lens. I use the Q as a semi-wide angle and want something wider, which would go on the M10.  Maybe 18mm or 21mm?
Ken Rockwell likes the 21mm f3.4 ASPH Super-Elmar-M but I'm not sure it will be sufficiently different in terms of angle of view from the 28mm on the Q.
He also likes the Leica Super-Elmar-M 18mm f/3.8 ASPH.
Any suggestions?
Thanks
2 hours ago, Johnclare369 said:
Hi everyone.
Any suggestions?
Thanks
21mm is plenty different from 28mm.
If you want to go wider than 28mm as on Leica Q, listing only current Leica M lenses, choice is substantial.
24mm f1.4 and f3.8
21mm f1.4 and f3.4
18mm f3.8
16-18-21mm f4
And than there are Voigtlander and Zeiss M lenses, starting from 25mm all the way to 10mm.
In terms of suggestion how much wider than 28mm do you need or wish to go, also at what maximum F stop?  SEM 21mm f3.4 is always a good choice and well different form 28mm - as i stated already.
