M mysteriously switched from raw to jpg format
jrovner
OK, here's a very strange one. I always shoot with my M 240 only in raw format. Today I realized that all the shots I've taken since July have been jpg. (That would explain a lot about the poorer quality I've been seeing, and my inability to lift clean detail out of shadows in post processing.) I am highly confident I never reset the camera to shoot jpg. Any idea how this might have happened on its own?
Even if you have no use for user profiles (plural) you might benefit from having one user profile. When packing to go out for the day, turn on the camera, click info to see battery and sd card usage, click set to make sure your profile is selected, make any adjustments needed from your standard profile and off you go.
Definitely very strange...that someone who professes PP skill and is dissatisfied with the "poorer quality" of the M's jpegs would not notice for 3 months that all his images have .jpg file extensions ;)
Trust me, I've had the same thought!
My own post processing routine would have prohibited this going unnoticed.  I only shoot raw and they open by default in ACR.  If I open a jpeg it opens by default in Photoshop.
I would be interested in knowing what post processing routine might allow such a thing to happen, in order to possibly avoid it myself in future.
I am unfamiliar with the default behaviors in Lightroom, Capture One, and others.
I don't know how you get to the post processing stage without noticing you haven't done any work on the .dng image in ACR?
I have made the mistake myself, set the camera to JPEG, probably to try and help answer a question on LUF (!!), and forgot to set it back to .dng, but opening the subsequent shots in Photoshop without the preliminary steps of ACR immediately rings the alarm bell they are JPEG's! I agree entirely with what Exodies says, you can go blind to what your LCD or menu is saying to you, especially if you know you never use JPEG, and similar mistakes can happen with ISO, exposure compensation etc. So follow the advice of having a custom profile saved for your default setting and each time you've uploaded a set of pictures go through the same routine, charge your battery, format the SD card, and reset your profile, or any variation that works for you. A custom profile is also useful during a long day out if you have been making many changes and quickly want to get back to your standard settings.
Steve
Steve
I work in Lightroom only, so everything appeared normal -- I inserted the SD card into my computer, saw the images on the import screen, and clicked Import to bring them into Lightroom. Everything looked as it normally does when that process incorporated a raw conversion. Of course, it's easy to see now that there were plenty of jpg notifications available to me. But the power of expectation is very strong. My long term hobby, other than photography, is sleight of hand magic, which relies entirely upon the spectator's tendency to see what he expects to see, as long as the magician's sneaky moves are disguised in a natural way. In this case, Leica was the magician, and I was fooled.
