24mm lens without an EVF or Finder
sml_photo
I hear one calling your name in the distance.
Seriously though, I wouldn't be without it. I soot a lot of Architecture and buildings and it is invaluable. A gorgeous little lens.
I'm not saying no...I've put my foot in my mouth more times than I can count!
In the meantime, I'm absolutely looking forward to the 24.  24 and 50 are my two most used focal lengths with my DSLR.  Nice to have Leica glass with those perspectives!
  • Replies 119
  • Created
  • Last Reply
For me now it is 24 and 35.
WooHoo.
Ordered the 24mm Elmar today.
The comments and observations on this page (and others) really helped me make the decision.  Appreciated....and entertaining.
Now I'd better like it or it's your fault!!
thx.
Enjoy it, use it with all your heart.
The Elmar-M is an excellent performer, my choice too.
I use it either with the EVF for precise framing and focusing, or with the standard finder (most of the time). You get used to what it sees over time and with experience, just like working with a Hasselblad SWC ... Or most cameras' optical finders, really. Most SLR finders show between 92-96% coverage, not 100% unless you have a pro-grade model. Bright line finders rarely frame that accurately.
G
My ZM 25 brought up the 35/135 framelines, so I changed the lens mount for one that brings up the 28/85 lines provided free from Zeiss. Not sure about the Leica though.
I have both the evf and an external ovf, but never use them. I mostly frame with the camera viewfinder, and for critical work, just use the rear lcd. I find that my accuracy with the camera ovf is very high. Just add 10% to whatever you can see in the frame :)
G
I'm going to start out without an external finder and see (literally!) how that works.
It would be nice if I could get used to it that way and avoid the need for the EVF2 or Brightline.  We'll see...
Thanks for the tip!  And advice.
I use it either with the EVF for precise framing and focusing....You get used to what it sees over time and with experience, just like working with a Hasselblad SWC ... Or most cameras' optical finders, really. Most SLR finders show between 92-96% coverage, not 100% unless you have a pro-grade model.
I went to B&H this past Friday to try the 21SEM and EVF2 combo on my M-P240.  When composing via the OVF and EVF, I found the latter easier but not really displaying that much more than what I saw via the OVF.  I'm right eye dominate and shoot with both eyes open.  I'd say the above statement is accurate and consistent to what I expect.
You should be fine without it. Try framing something at about a hundred yards away and then at 50 feet and look at both on the computer to help you judge the limits.
Thanks for passing along the results of this "experiment!"
I'm expecting the lens to arrive this week.  I'm gonna try that.
Thanks.
Thanks.
If you can pick something in the viewfinder that you want at the far left and right edges of the frame and they are roughly where you want them in the image at bot distances it helps with shots in the future. The nice thing about 24 megapixel raw images is if the image is slightly wider than you need a little judicious crop doesn't cost anything image wise.
You're welcome, and just to clarify....my experiment was at pretty short distances 50 - 150 ft; but you get the idea.  There was some great discussion early on in this thread that talks about just pointing and shooting given the wide angle and DOF;  you can zone focus and literally shoot from the hip pretty easily.
Yes, I know.
That is not my general practice or inclination.  Though, of course, I do resort to that from time to time.
Thanks.
JUST received the lens yesterday.  I've only taken a handful of random shots so far.  Lookin' good!  More later today and tomorrow.
But, I am wondering....  I thought I had heard that the 28mm lines would show in the finder, however it's the 35mm lines that I see in my M-P (240) Safari.  Is that normal?  Is something wrong?
(I realized, of course, that there are no lines for the 24mm lens.)
Thanks!
With my 21SEM, I see 28+90mm in the RF.  You really need to push your M into your face to see it the 28mm border.  If you don't, 28mm it's more of less the entire OVF as the frame lines make a border just inside the the most outer edge RF.
