Guest NEIL-D-WILLIAMS Posted April 21, 2015 Share #1 Posted April 21, 2015 Advertisement (gone after registration) I have had both the Lee Filter system (Original and now the seven7 I think that's what they call it and was wondering how everyone else in the camp get on with it. The original set that I had was from what I can remember okay with minimal vinagaretting whereas this seven7 kit gives me a whole bunch of vinagaetting especially with my 21mm lux. I do like using it on the 240 as you can see the effect via the live view whereas on my M9 you couldn't so it was a wee bitty hit and miss Thoughts comments from the landscape crowed ??? Link to post Share on other sites More sharing options...
Advertisement Posted April 21, 2015 Posted April 21, 2015 Hi Guest NEIL-D-WILLIAMS, Take a look here Lee GND filter system for Leica..............Okay or not??. I'm sure you'll find what you were looking for!
DrM Posted August 5, 2015 Share #2 Posted August 5, 2015 Hi Neil, Personally I use the Lee 5 system for the M240 and it works great. Any reason to go for the seven7 kit? Link to post Share on other sites More sharing options...
250swb Posted August 6, 2015 Share #3 Posted August 6, 2015 With cameras that can do bracketed exposures I can't think of a reason for graduated neutral density filters. Take three or four shots and blend however many you need to cover the contrast range or effect you want, not all bracketed exposures have to end up looking like an HDR image. The exception might be 'action' landscape pictures, where one exposure would be needed to capture a raging sea etc., but skilful editing can overcome most problems. Steve Link to post Share on other sites More sharing options...
stevieg Posted October 20, 2015 Share #4 Posted October 20, 2015 My understanding of the seven5 filters is that they are designed for cropped sensors. The seven5 graduated ND filters have transitions over a much shorter space and would end up being overly "hard" for the full-frame M240 that I use. There would also be the problem of vignetting with wider lenses that seems to be bourne out from your experience. I have the 100 series filters as I also have a Nikon system. I haven't had any vignetting problems with my widest lens (21SEM). I also use their circular polarizer with no issues. Personally, coming from the velvia film era, I would prefer to balance the exposure "in camera" with graduated ND filters rather than try to take multiple shots and then create a blended HDR effect later. I don't think it creates the same image. Just my preference though. Link to post Share on other sites More sharing options...
MarkP Posted October 20, 2015 Share #5 Posted October 20, 2015 With cameras that can do bracketed exposures I can't think of a reason for graduated neutral density filters. Take three or four shots and blend however many you need to cover the contrast range or effect you want, not all bracketed exposures have to end up looking like an HDR image. The exception might be 'action' landscape pictures, where one exposure would be needed to capture a raging sea etc., but skilful editing can overcome most problems. Steve Completely agree with this. Link to post Share on other sites More sharing options...
pedaes Posted October 20, 2015 Share #6 Posted October 20, 2015 My understanding of the seven5 filters is that they are designed for cropped sensors. The seven5 graduated ND filters have transitions over a much shorter space and would end up being overly "hard" for the full-frame M240 that I use. There would also be the problem of vignetting with wider lenses that seems to be bourne out from your experience. I have the 100 series filters as I also have a Nikon system. I haven't had any vignetting problems with my widest lens (21SEM). I also use their circular polarizer with no issues. Personally, coming from the velvia film era, I would prefer to balance the exposure "in camera" with graduated ND filters rather than try to take multiple shots and then create a blended HDR effect later. I don't think it creates the same image. Just my preference though. Where does that understanding come from? Having been on Lee training events,never heard it mentioned ,remembering also film users. There is a 'soft grad' option available if you think it would be better for you, although Lee themselves suggest hard grads for 35mm format. Drop them an e-mail and ask. Link to post Share on other sites More sharing options...
Guest JonathanP Posted October 20, 2015 Share #7 Posted October 20, 2015 Advertisement (gone after registration) With cameras that can do bracketed exposures I can't think of a reason for graduated neutral density filters. Take three or four shots and blend however many you need to cover the contrast range or effect you want, not all bracketed exposures have to end up looking like an HDR image. The exception might be 'action' landscape pictures, where one exposure would be needed to capture a raging sea etc., but skilful editing can overcome most problems. Steve +1 I haven't used my Lee system since I sold my 5x4 camera. Also I don't find that I need to do multiple exposures very often at all with the dynamic range available on the M240 if exposed and processed correctly. Jonathan Link to post Share on other sites More sharing options...
stephengv Posted November 6, 2016 Share #8 Posted November 6, 2016 Can you confirm that there is vignetting on a 21mm? Link to post Share on other sites More sharing options...
Dan Bachmann Posted November 6, 2016 Share #9 Posted November 6, 2016 With cameras that can do bracketed exposures I can't think of a reason for graduated neutral density filters. Take three or four shots and blend however many you need to cover the contrast range or effect you want, not all bracketed exposures have to end up looking like an HDR image. The exception might be 'action' landscape pictures, where one exposure would be needed to capture a raging sea etc., but skilful editing can overcome most problems. Steve I agree, though the thought of less time doing skillful editing is something I like in theory. That said, since moving from dSLRs to Leica M, the filters, lighting kit and tripod generally stay at home and my editing is down to what I can get out of the RAW file. Link to post Share on other sites More sharing options...
willeica Posted November 6, 2016 Share #10 Posted November 6, 2016 I agree, though the thought of less time doing skillful editing is something I like in theory. That said, since moving from dSLRs to Leica M, the filters, lighting kit and tripod generally stay at home and my editing is down to what I can get out of the RAW file. I'm with you all the way on this, Dan. No filters of any kind and just what I can get out of the RAW image. Thankfully, we do not see much of the Lee 'Big Stopper' etc stuff from Leica users. In camera clubs the milky waves and long flowing water from filters have gone beyond a cliche at this stage. Everybody does it and it has long since ceased to be interesting. The same with tripods. I have them but rarely use them. Using a fixed mount such as a tripod is the antithesis of what a Leica is supposed to be; a light mobile camera which enables the user to vary the viewpoint at will. William Link to post Share on other sites More sharing options...
