I have found the M 240 to be fine for landscapes, used with a light Gitzo tripod.
However, when I'm serious, out comes my Hasselblad - which delivers, in my view, much more stunning results.
I also recently had a Hasselblad with Phase One back and still shoot with a MF digital camera. However, even when using my M's for landscapes shooting I consider my M landscape shooting as being serious too.
I too was very disappointed to realize the limitations for "bulb" exposure when I went to photograph the Milky Way the other night. I was sure the night was going to be a total loss, as I couldn't get exposure times greater than 16s at the ISO (500) and aperture (4.0) I wanted to use. That being said, I was pleasantly surprised when, in Lightroom, with an exposure increase to 2.60, the photos came out relatively well, with little to no noise, considering the above noted limitations (attachment below.) It won't win any Nat Geo prizes or become the new standard for astrophotography, but if you're enjoying a night out with the Milky Way you can still get the job done.
I would suggest a faster lenses, for example the 21mm Summilux. Focused to infinity. That will surely make up for any issues with exposure time.
As much as I love and use my M240 and M4, I have found it just doesn't the job for landscape shooting.  For this I drag a Hasselblad and I tripod along, take the time to set up correctly and get great results. This also applies to indoor architectural shots.
The M's are for everything else.
According to the manual there is a hole underneath the M240 that can be used to attach the camera to a tripod, I imagine this is similar to a Hasselblad that also has a hole.
Steve
Steve
Does not overcome the 1 minute exposure limitation.
Although, the wide angle lenses available are generally better than other platforms.
Look on the bright side, it puts an end to long exposures of a jetty sticking out into the sea, and a 60 second indicated exposure is 60 seconds, if using film a 60 second indicated exposure could mean you standing around for 10 minutes waiting for the reciprocity failure to catch up.
Steve
To say that the M isn't a good platform for landscapes because of constraints on long exposures is a bit of a stretch. I primarily shoot landscapes, and find the M to by my preferred platform to do so. It sounds like the issue is more with things like astrophotography, and extreme long exposures. But the M is a fine landscape camera.
M240 really sucks for landscapes.
Yeah, absolutely awful for landscapes, rocks, snow etc!!
If the M happens to be all I have with me and I want to shoot a landscape image, then it is more than fine.
But it is not my first or even second choice by any means. I much prefer either my Hasselblad or 4x5 system for that work, especially now that I am likely going to get a CFV50c back for the Hasselblad system for when I need to shoot digital.
I'd agree, indeed the M240 sensor has a lot of dynamic range and low noise in shadows making it very suitable for landscape.
Although 1 minute exposure limit is still a big problem, it greatly limits options for smooth water effects.
Edited by Mornnb
