tpeevski Posted January 5, 2015 Share #1 Posted January 5, 2015 Advertisement (gone after registration) Hello to all Leica users. This is my first post about my Leica M8.2 and the first issue with it. I've bought it on ebay in september 2014 and it has 4,500 shutter clicks. Now it shows almost 7 thousand and it still looks like new. 10 days ago I've decided to update the firmware to 2.024. The update was successful(now it shows firmware 2.024) and I am not completely sure that the problem comes from this, but now, when I try to make a picture, the red light starts blinking like it 'writes' to the sd card but nothing happens. Even when I switch off the camera the blinking continues and I have to take the battery out in order for the blinking to stop. Is there a way to reset the camera in some way, or does anybody have any advice. It's strange because everything else works fine - it can take pictures, you can enter any of the menus and submenus... I'll be grateful if someone can help. Thank you all! Link to post Share on other sites More sharing options...
Advertisement Posted January 5, 2015 Posted January 5, 2015 Hi tpeevski, Take a look here M8.2 - Firmware 2.024 Update issue? . I'm sure you'll find what you were looking for!
Lenshacker Posted January 6, 2015 Share #2 Posted January 6, 2015 Have you tried a different SD card? Or formatting the SD card with the new firmware loaded? You should be able to "roll back" to 2.014 to see if the problem goes away. I have not had any problems with the M8. Link to post Share on other sites More sharing options...
dg2mst Posted January 6, 2015 Share #3 Posted January 6, 2015 I have had similar issues with 2.024 on my early M8 (SN 310XXXX) and have successfully downgraded back to 2.014. If you need help doing so, please feel free to contact me. As of today I am aware of four similar cases. In every instance the camera would seemingly work as it should, except that when taking a photograph, the memory card would not stop flashing and no file would be recorded. 1 Link to post Share on other sites More sharing options...
tpeevski Posted January 6, 2015 Author Share #4 Posted January 6, 2015 Hi there. Thanks for the replies. I've found a 2.014 firmware online after a search and tried to downgrade but it looks that the M8.2 refuses to 'read' that firmware. I've followed the instructions for the firmware update (as I did with the 2.024) but nothing happens. Probably I am doing something wrong... Any suggestions on how to downgrade? Thank you for your time. Link to post Share on other sites More sharing options...
Jeff S Posted January 6, 2015 Share #5 Posted January 6, 2015 Any suggestions on how to downgrade? Send a PM to the post just above, per his offer. Jeff 1 Link to post Share on other sites More sharing options...
lct Posted January 6, 2015 Share #6 Posted January 6, 2015 [...] when I try to make a picture, the red light starts blinking like it 'writes' to the sd card but nothing happens. [...] everything else works fine - it can take pictures, you can enter any of the menus and submenus [...] Welcome to the forum . What do you mean by "nothing happens" if i may ask? I can't seem to understand what your problem is exactly sorry. If you can take pictures and enter menus is it just the blinking lights which bother you? Just curious. Link to post Share on other sites More sharing options...
tpeevski Posted January 7, 2015 Author Share #7 Posted January 7, 2015 Advertisement (gone after registration) Hi there. Probably I did not explained the problem correctly. By 'nothing happens' I mean that when you press the shutter-release button, the shutter clicks like it takes a picture but that is not happening, the display remains dark and you can see only the blinking red light. When you switch off the camera, the red light continues to blink. And when you check the sd card - there are no pictures inside. So, the shutter clicks but no pictures are being recorded to the card (I've tried more than 5 different sd cards - brands and storage capacity). 1 Link to post Share on other sites More sharing options...
pippy Posted January 7, 2015 Share #8 Posted January 7, 2015 (edited) ...10 days ago I've decided to update the firmware to 2.024. The update was successful(now it shows firmware 2.024) and I am not completely sure that the problem comes from this, but now, when I try to make a picture, the red light starts blinking like it 'writes' to the sd card but nothing happens. Before updating the firmware myself I was aware that this had happened to some M8's and so I did an on-line search to see what the problem was. It seemed to affect some early M8's but yours is the first time I've read of it happening with an 8.2. The following text is a translation of the first item I read which mentioned the problem as posted in the German section of the forum on the 20th Dec last (apologies in advance to dg2mst - see post #5, above - for google's mashed translation of this, his earlier post!); "After a successful update an image was recorded on a memory card no more. The settings were reset naturally. I tested it with multiple cards and DNG and JPEG. The maps were doing formatted in the camera and the PC, which made no difference. The red LED has just hingeblinkt permanently on. Interestingly, the camera view previously made pictures to another memory card and easily enlarge." Later on he states that returning to the previous firmware sorted out the problem in his case. If it were me I'd persevere in trying to get your camera to 'read' the older version. He, like you, experienced the problems with several different SD cards so the cards don't seem to be the issue. Have you contacted Leica about this? They might be able to sort out the problem over the phone? Just a thought. FWIW I uploaded the 2.024 version on my 8.2 without encountering the problems you and others have faced. The serial # of my body is 35564XX. Best of luck in getting it corrected. Could you keep us informed of developments, please? Philip. Edited January 7, 2015 by pippy 1 Link to post Share on other sites More sharing options...
tpeevski Posted January 7, 2015 Author Share #9 Posted January 7, 2015 I uploaded the 2.024 version on my 8.2 without encountering the problems you and others have faced. The serial # of my body is 35564XX. Best of luck in getting it corrected. Could you keep us informed of developments, please? Philip. First, thank you for your response. My M8.2 serial number also begins with 355. The strange thing is that now, it refuses to read the 2.014 firmware file that I've downloaded (also used the one that dg2mst send me). But when I put the 2.024 upd file on the card again - the same message about the 'update the firmware to version 2.024'. I don't know if that's normal, once it was upgraded to that firmware already. Obviosly, I'll have to contact Leica about this. If only there was a natural way for a user reboot or reset to a previous firmwares.... Link to post Share on other sites More sharing options...
lct Posted January 8, 2015 Share #10 Posted January 8, 2015 Doesn't encourage me to do the update that... Thanks to keep us informed of what Leica say. Link to post Share on other sites More sharing options...
jaapv Posted January 8, 2015 Share #11 Posted January 8, 2015 The bitter irony is that it is utterly unnecessary to update the firmware. It only adds the new Summarit lenses to the lens recognition register, that is all. As long as you do not buy one of these lenses, you don't need it.... My fixed rule for all electronics is: Don't update unless there is a clear benefit. Believe me, I learnt the hard way.... 4 Link to post Share on other sites More sharing options...
Jeff S Posted January 8, 2015 Share #12 Posted January 8, 2015 My fixed rule for all electronics is: Don't update unless there is a clear benefit. +1 And until other users have reported any bugs or concerns. And, with computers, until I know if other applications are affected (also learned the hard way). Jeff Link to post Share on other sites More sharing options...
handgun Posted January 13, 2015 Share #13 Posted January 13, 2015 I updated my M8 s/n 3111xxxx late last year, 2.024 Firmware.At first everything seemed OK . Just before Xmas I was shooting on rapid 2 of 3 frames at a time, the temperature was 7deg C (45 F) and it just stopped, blank screen and LED about 30 mins later started again. done this three times now, the latest was today ! So I have re-loaded 2.014 and so far every thing seems OK. every thing is in the same place, and all my settings are as they were. it could have been the temperature, but i don't think so, it's never done it before. Could be the SD card ? I have not changed it yet, will continue to use the same card to see if the problem re-occurs. Regards Dave Link to post Share on other sites More sharing options...
lct Posted January 31, 2015 Share #14 Posted January 31, 2015 Had to update to FU 2.024 for a new lens. No problem so far... Link to post Share on other sites More sharing options...
lct Posted January 31, 2015 Share #15 Posted January 31, 2015 The bitter irony is that it is utterly unnecessary to update the firmware. It only adds the new Summarit lenses to the lens recognition register [...] Summicron 50/2 apo also. Link to post Share on other sites More sharing options...
Symeon Posted February 23, 2015 Share #16 Posted February 23, 2015 The firmware 2.024 is buggy. Somehow it does not suit the M8/M8.2 cameras and Leica hasn't warned us about it. Typical. Get rid of it and return to an older firmware. The red light will go on and on and on and it will only stop if you remove the battery. regards. Link to post Share on other sites More sharing options...
bwibowo Posted February 24, 2015 Share #17 Posted February 24, 2015 i use 2.024 on my m8 and so far no issue 2 Link to post Share on other sites More sharing options...
lct Posted February 24, 2015 Share #18 Posted February 24, 2015 i use 2.024 on my m8 and so far no issue +1 Link to post Share on other sites More sharing options...
david strachan Posted April 19, 2015 Share #19 Posted April 19, 2015 I've updated my two early M8's to Version 2.024. No problems. cheers Dave S Link to post Share on other sites More sharing options...
Symeon Posted April 26, 2015 Share #20 Posted April 26, 2015 Different experience here folks. My M8 just froze with the latest firmware. Same thing happened to a friend. I'll give it another try though and let you know. Link to post Share on other sites More sharing options...
