mitchell Posted May 9, 2007 Share #1 Â Posted May 9, 2007 Advertisement (gone after registration) Has anyone used a polarizer with the M8? I'm interested in any problems with IR interactions or problems using with an IR filter. Â Has anyone used the polarizer that comes with a viewer that fits in the hot shoe? What is the brand name? Â Thanks, Â Mitchell Link to post Share on other sites More sharing options...
Advertisement Posted May 9, 2007 Posted May 9, 2007 Hi mitchell, Take a look here Polarizer for M8. I'm sure you'll find what you were looking for!
cbretteville Posted May 9, 2007 Share #2  Posted May 9, 2007 'Kenko'. Here's some more info: Robert White - Camera Accessories  - C Link to post Share on other sites More sharing options...
gerasdoc Posted May 9, 2007 Share #3 Â Posted May 9, 2007 I am using the Kenco polarizer with the hotshoe viewfinder. It's a good solution for the M8. I bought a 72mm polarizer and step up rings so that I can use it on all of my lenses. Link to post Share on other sites More sharing options...
robbegibson Posted May 10, 2007 Share #4 Â Posted May 10, 2007 The Leica M polarizer works fine on the M8. It works without occupying the hot shoe.However, the adapters only go up to 49mm. Â Robbe Link to post Share on other sites More sharing options...
lars_bergquist Posted May 10, 2007 Share #5  Posted May 10, 2007 The Leica M polarizer works fine on the M8. It works without occupying the hot shoe.However, the adapters only go up to 49mm. I agree. There are however 'quick and dirty' solutions too. Many polarisers have a direction mark on the rotating part of the mount. To darken the sky, just rotate this part so that it points in the direction of the sun, and you are home free. To cut reflexes from a horizontal surface (water etc) point the mark up, at 12 o'clock. General rule: Correct direction is perpendicular to the reflecting surface. Experiment and learn.  This last fact can be used to mark a polariser mount (e.g. from B+W) without the mark. Lay out a horizontal reflecting surface. View it through the filter, rotating the outer part until the reflection is minimised. At that orientation, mark the ring at 12 o'clock.  A pola filter gives the same result at two orientations, 180° apart (that is the idea behind the M Polariser). It does not matter which orientation you use.  You can approximate the Kenko solution by carrying two filters, one for the lens and one smaller (maybe 39 mm) for viewing, both marked as above. Identical orientations give identical results.  Linear and circular polarisers also give the same result. The M8 has no beam splitter or mirror behind the lens, so it works fine with the linear, less expensive kind.  The old man from the Age of the Nicol Prism Link to post Share on other sites More sharing options...
jaapv Posted May 10, 2007 Share #6 Â Posted May 10, 2007 It is essential to use an IR filter behind the polarizer on the M8. IR light is not polarized, thus visible light is halved, IR not, so IR contamination is doubled (at least) Link to post Share on other sites More sharing options...
Photoskeptic Posted May 10, 2007 Share #7 Â Posted May 10, 2007 Advertisement (gone after registration) The Kenco seems ideal. Where can one purchase this system in US? Link to post Share on other sites More sharing options...
mitchell Posted May 10, 2007 Author Share #8 Â Posted May 10, 2007 Thanks everyone. Jaap I'm glad you mentioned this. I thought there was something like that, but couldn't remember. Â I hope someone knows where to get the Kenco in the US. Or I may just go with two sizes to fit my M lenses. That way I'll have one for the lens and one for my eye. Â Best, Â Mitchell Link to post Share on other sites More sharing options...
jaapv Posted May 10, 2007 Share #9  Posted May 10, 2007 Thanks everyone. Jaap I'm glad you mentioned this. I thought there was something like that, but couldn't remember.  I hope someone knows where to get the Kenco in the US. Or I may just go with two sizes to fit my M lenses. That way I'll have one for the lens and one for my eye.  Best,  Mitchell  Mitchell, buy a step-up ring for a filter you have or can get and dremel an appropriate slit in that ring. In that way you can see the effect directly in the viewfinder. You only need to buy two cheap step-ups at Heavystar on e-bay insted of an extra expensive filter, which works not as easily as this solution as well.  Link to post Share on other sites More sharing options...
wparsonsgisnet Posted May 10, 2007 Share #10 Â Posted May 10, 2007 Try this: get a pola filter that is bigger than your lenses. To use it, rotate it in front of your eyes, watching the polarization effect, and then hold it against the front of the lens with the chosen orientation. Â When I tried this with a Canon pola I bot a lot of years ago it wasn't particularly effective.. I hauled out the pola for the D2 and will try it with the lenses on my M8. On the D2, it was much more effective than is the Canon. Â Watch this space. Link to post Share on other sites More sharing options...
mitchell Posted May 10, 2007 Author Share #11 Â Posted May 10, 2007 Thanks Jaap and Bill. I'm mulling it over. Link to post Share on other sites More sharing options...
gerasdoc Posted May 10, 2007 Share #12 Â Posted May 10, 2007 The Kenco seems ideal. Where can one purchase this system in US? As far as I can tell the only dealer is Robert White in the UK. That is where I purchased it. Link to post Share on other sites More sharing options...
arthury Posted May 11, 2007 Share #13  Posted May 11, 2007 Mitchell, buy a step-up ring for a filter you have or can get and dremel an appropriate slit in that ring. In that way you can see the effect directly in the viewfinder. You only need to buy two cheap step-ups at Heavystar on e-bay insted of an extra expensive filter, which works not as easily as this solution as well.  Jaapv,  I have never seen slit- step-up rings. I don't see them in B&H. If you know of any in the US, please post link. Thanks! Link to post Share on other sites More sharing options...
agro Posted May 11, 2007 Share #14  Posted May 11, 2007 You might consider this.  Step up to Steps  Cheers Agro Link to post Share on other sites More sharing options...
nryn Posted May 11, 2007 Share #15 Â Posted May 11, 2007 Arthur, you can also go with a pre-packaged version of what Jaap is talking about. There are two I know of: Steps and FilterView. Link to post Share on other sites More sharing options...
albertknappmd Posted May 11, 2007 Share #16 Â Posted May 11, 2007 I had the Filterview set up for my M7... Concept was great but the cheap metal and poor workmanship left alot to be desired. I had SK Grimes (S.K. Grimes Services for Large Format Photographers, CNC Photographer's Machinist) examine the pieces and they built their version in high grade aluminium and it works beautifully. I heartily endorse it and if you are interested, just call them and use my name. I use the UV/IR filter under the adaptor as the IR is obviously not polarized and is evffectively doubled intensity-wise by the polar. :) Link to post Share on other sites More sharing options...
Photoskeptic Posted May 11, 2007 Share #17 Â Posted May 11, 2007 Ordered mine today from Robert White. Since I'm across the pond may take awhile to receive, but I'm quite excited about this product. Link to post Share on other sites More sharing options...
jaapv Posted May 14, 2007 Share #18  Posted May 14, 2007 Jaapv, I have never seen slit- step-up rings. I don't see them in B&H. If you know of any in the US, please post link. Thanks!  You make the slit yourself. It is quite easy- these things are made of low-grade aluminium. Link to post Share on other sites More sharing options...
albertknappmd Posted May 14, 2007 Share #19 Â Posted May 14, 2007 But that is exactly the problem, Jaap, the low-grade aluminium. That is why I had SK Grimes make a step up system of HIGH-grade aluminium. It works beautifully... Albert:) Link to post Share on other sites More sharing options...
gilles_lorin Posted May 14, 2007 Share #20  Posted May 14, 2007 Mitchell, buy a step-up ring for a filter you have or can get and dremel an appropriate slit in that ring. In that way you can see the effect directly in the viewfinder. You only need to buy two cheap step-ups at Heavystar on e-bay insted of an extra expensive filter, which works not as easily as this solution as well.  Hi Jaapv,  This is very interesting, thank you for sharing. Can you accurately frame through the slit?!? Link to post Share on other sites More sharing options...
