Acetate Negative sheets by Hama.
Paulus
I recently bought some acetate negative sheets to hold my Tmax and tri-x films.
Real rubbish . I could not get my film in. They are to tight.
Does anyone have had this same problem. What kind of acetate sheets still exist?
I wouldn't use clear sheets, the translucent paper sheets are far better and easier to use. The common problem with the clear sheets is they grab the film when you are pushing it into its slot, so it's not just you. If you use a film with the thin or curly base, such as Neopan, they become a nightmare.
Steve
Having experienced this "sticking" of acetate sheets, also the certified ones, I have since switched to Hama's 2250 with 7 6-neg strips. Where I live they are easily the best deal around and work perfectly also on a light table.
Philip
I think it's because photographers think can see their negatives better, or/or make contact prints without taking them out of the sleeve. But it rarely works in practice.
Steve
It worked for me , with the other non Hama folders, but one can't buy them anymore...I wonder if this is the beginning of the end for negative films, when the holders become so bad of quality and they seem to have some kind of monopoly?
Paulus, ther are at least 5 makes of sleeves (possibly more), two in the States, one in Italy and Germany, and one in the UK, all producing archival storage systems. (which is not pergamin/glassine nor acetate). A lot to choose from, so no need to worry. :)
It seems Kaiser also makes some kind of holders.
I've invented expletives in trying to use these hideous sheets.
Pete
Just out of intellectual curiosity: I would dearly love to learn some new ones, please.
:D
Good quality polypropylene or acetate (PAT) is also available. But your negatives must be completely dry before putting them in.
Advantage: Contact prints possible without dust problem.
Pergamin sleeves are also archival but you have to remove the strip for seeing any details. And it is not possible to make any contact print from it without removing all strips.
But it is much cheaper material too. Less then half priced compared with the transparant types.
ANSI IT 9.16/DIN ISO 10214
Both versions of these sleeves are within these specs. Which doesn't mean there are even more (better) archival solutions but it also depends how and under which conditions you are storing your negatives.
