mike.schneier Posted September 24, 2014 Share #1 Â Posted September 24, 2014 Advertisement (gone after registration) I recently purchased an R4S and I have been having some issues with the light meter. When shooting outdoors with 100 speed ISO my meter has been saying I am over exposed even at F 16. Also when I open and close the aperture there is no change in the light meter reading. I have replaced the battery but still have had the same issue. Any advice on this issue? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted September 24, 2014 Posted September 24, 2014 Hi mike.schneier, Take a look here R4S light meter issue. I'm sure you'll find what you were looking for!
wagner Posted September 25, 2014 Share #2 Â Posted September 25, 2014 Hi Mike! Â It looks, as if the leaver for the aperture-control is not moving. It's "sticking" in open position, probably because the leaver is slightly bent and is not catched the by the lens "aperure ring". Â To test, if the aperture control works in principal, try to move the leaver - on the botton - carefull with your finger. In the viewfinder you should then see then the change of the speeds. Â regards, Â Torsten Link to post Share on other sites More sharing options...
wildlightphoto Posted September 25, 2014 Share #3 Â Posted September 25, 2014 A very basic question, apologies if this is too obvious - does the lens have the R metering cam? Link to post Share on other sites More sharing options...
