Bye bye Monochrom....
flanoizele
  • Replies 58
  • Created
  • Last Reply
1. RF adjustment is more accurate
2. Vertical image adjustment is easier and more accurate ( a commonly overlooked misalignment which makes perfect focussing difficult).
3. Getting rid of the illumination window seems to have made things a bit more contrasty.
4. I suspect Leica have done something to the optical components .... possibly different glass/coatings etc. which has improved image clarity.
The review screens on the M9 and MM are rubbish. I'll admit ...... but if you have a well adjusted camera and perfectly calibrated 75 you should have no problems, even wide open with portraits ......
My 75/2 has just returned from it's 3rd trip to Solms/Wetzlar to be adjusted ..... if you change to a 240 I would certainly check this lens critically with liveview and peaking ...... the floating element Leica lenses seem to be very tricky to calibrate perfectly ....
I have a Monochrom and M240. I consider them complementary.
The Monochrom's files continue to astound me. Yes. I'd like an M240 Monochrom for a number of features including the improved viewfinder, shutter, etc. as long as there was no loss of IQ, tonality, etc. with the inevitable CMOS sensor.
I don't have major problems with focusing the Monochrom but lenses such as my 1.0/50 Noctilux, 2.4/75 Summilux, and 3.4/135 APO-Telyt used wide open will always be challenging. I try to avoid shooting wide open if possible - partly to improve contrast & focus accuracy and because I'm not a fan of zero-depth-of-field-photography. But this is where the EVF of the M240 is an advantage
I primarily use the back screen for the histogram. I would never make a final decision about focus accuracy off a back screen, even on the M240.
If you shut down the lens a stop or so from maximum aperture you will still have very shallow DOF (but perhaps a bit more natural than just having a cornea in focus), improved contrast, and have more in-focus keepers? Or just focus bracket.
Which 75 are you using for portraits? The sharpness of the 75 Summicron ASPH sharpness is very unforgiving for human subjects.
Guest NEIL-D-WILLIAMS
OP. is your MM a black one or a silver one? the reason I ask is that the silver ones have a superior OVF and focusing with that puppy is a blast.........no loblem at all
Are you being funny or is there an upgraded OVF in the new Monochroms of which I'm unaware :confused:
Mark
I think you already know the answer to that:D
Hi Mark,
I use the 75 Summicron ASPH and you are absolutely right about the unforgiving nature of this lens for portraits. In the mean time I am pretty used working with it but I do need to spend some time in post to soften the picture just a little (especially for female models).
Good, I thought I'd missed something :o.
You do know though that the silver Monochrom is optimised for highlights whilst the black Monochrom is optimised for the shadows. So you'll need to get both for a correct exposure :p
I was lucky I got the film model.......no need for that digital crap
I notice that a lot of people are mentioning the ability to focus. I admit that I had quite some issues with that also in the beginning as I did with finding how to expose "correctly" with the Monochrom. However this is no longer the real issue. The issue is that I can't verify it after I took the shot. In 80% of the situations this isn't a big deal, but when I shoot payed jobs or when I pay to have a model coming over for a photo shoot I have to make sure I got it right.
I only started photography 2 years ago now and the MM is my first Leica (even first RF) ever. So unfortunately I don't have the (Film) experience some of you are referring to. Furthermore I refuse to only use my Leica for leisure, I want to use it also when doing client portraits shoots and even wedding.
Hi Flanoizele,
I think that most of the issues discussed here about focusing difficulties are not so much using the rangefinder focusing mechanism per-se. It is the issue of accurate focusing of fast lenses used wide open where depth of field is very limited and/or with lenses which forward or back-focus a little (especially older lenses such as pre-asph summiluxes, 1.0 Noctilux, or lenses a little out of calibration).
The rangefinder optics of the M240 has been upgraded and does make accurate focusing easier than the M9 and Monochrom, and has been optimised to 2 metres.
Regards,
Mark
I think we quite understand. However we really should split this discussion into two parts.
The first being the ability to focus, which is a matter of individual skill and will increase with practise. The 240 may well help here, but is not essential imo.
Secondly the ability to check the result, and I can understand the need for a better screen.
I sincerely doubt whether the EVF will perform more satisfactorily in this respect, and I think even the better screen on the 240 is suboptimal - isn't any smallish LCD?- and tethered shooting whenever possible seems to be a better answer.
Failing that, Luigi is right that focus bracketing in a reportage (wedding) situation is always wise.
Hi Mark,
Assuming 75mm is your favourite short telephoto for portraiture have you looked at a gentler lens:
Spend a shiltoad of money on the extraordinary Leica 1.4/75 Summilux
Save a shitload of money on the lovely Voigtlander 1.8/75 Heliar Classic or 2.5/75 Color Heliar
Of course there are then a whole lot of options in 90mm
The best thing I ever did to help me focus accurately was to get a Walter eyepiece that has a lens in it that corrects both for spherical and cylindrical defects. I don't use the rear screen except for menus and, rarely, looking at a histogram; I'm quite comfortable with that as it matches the way I work with film cameras.
Chris
As an owner of MM and M240 (previous M9) I understand what you say.
Some comments:
I also found the MM and M9 to slow me down occassionally. Full buffer for example sometimes. And I certainly agree the display of the New M to be much better.
THE EVF I only use very seldom, and if only for longer focal lengths. Everything else I am faster and more precise with the Rangefinder.
The 75 Summicron is a wonderfull lens but I agree it is difficult to focus and I sometimes wonder if the transition between sharp/focus plane and background might be to abrupt for portraits images.
Thre are other lenses where a slight missfocus doesnt look that bad , but with the 75 it sometimes does. (Maybe because the focused plane is so super sharp?)
On the other side the MM is so unique in its output that so far I didnt want to sell it.
It was a year ago in September that I bought my Leica Monochrom. Let me tell you it was Love at first sight. :)
...So now I decided that next Saturday I will go out and test the new M-P. If I find this focus peaking thing in combination with a EVF workable I am almost sure I will buy it...
I would never had imagined writing these lines on this forum and it breaks my heart to get separated from my MM but I can't see any good reason to keep both of them....:confused:
@flanoizele,
The above tells me that you should keep the MM.
It sounds for all the world that if you trade off the MM, you will regret doing so - very quickly and very deeply. Think carefully before you do this; once it's gone, it's gone.
JMHO but I say keep the MM and buy the M-P. Avoiding the anguish of making an ill advised and regrettable trade is certainly good enough reason to keep the MM.
