alan.y Posted August 5, 2014 Share #1 Posted August 5, 2014 Advertisement (gone after registration) On the wiki the weight of this lens is given as 560 grams. Is the later version with the embedded, non-telescoping hood lighter than the previous ones? Thank you. 1 Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 5, 2014 Posted August 5, 2014 Hi alan.y, Take a look here Pre-APO Summicron-R 90 -- weight difference between versions. I'm sure you'll find what you were looking for!
wildlightphoto Posted August 5, 2014 Share #2 Posted August 5, 2014 The early pre-APO 90 'cron-R (two-piece hood) is 560 grams, the late (one-piece hood) pre-APO 90 'cron-R is 520 grams. 3 Quote Link to post Share on other sites More sharing options...
lct Posted August 17, 2014 Share #3 Posted August 17, 2014 (edited) Both v1 (11219) and v2 (11254) Summicron-R 90/2 weigh 560g according to my Leitz documentation. I have no experience with the v2 though. Edit: 520g is the Apo-Summicron-R 90/2 (11350). Edited August 17, 2014 by lct 2 Quote Link to post Share on other sites More sharing options...
alan.y Posted August 17, 2014 Author Share #4 Posted August 17, 2014 $2500 / 40 grams = $60 / gram > price of gold. 1 Quote Link to post Share on other sites More sharing options...
lct Posted August 17, 2014 Share #5 Posted August 17, 2014 (edited) The Apo-R is only 20g heavier but 19mm shorter than its M counterpart. Would be great on a R10 but the need for an adapter would ruin the size argument on the M240 i guess. Edited August 17, 2014 by lct 1 Quote Link to post Share on other sites More sharing options...
farnz Posted August 17, 2014 Share #6 Posted August 17, 2014 The Apo-R is only 20g heavier but 19mm shorter than its M counterpart. Would be great on a R10 but the need for an adapter would ruin the size argument on the M240 i guess. It's surprisingly compact on the M240 with M-R and in my opinion seemed more compact even with the M/R adaptor than its sister lens the 90/2 APO-Summicron-M asph. (But then having to use the EVF for the R version makes it less desirable on the M.) Pete. Quote Link to post Share on other sites More sharing options...
lct Posted August 17, 2014 Share #7 Posted August 17, 2014 Advertisement (gone after registration) Being apparently the same lens i would have thought that the length of the apo-R + adapter is roughly (or perhaps exactly) the same as that of the apo-M alone but i don't own the former so i rely on you my friend. I have not the pre-apo M and R with me here but i will compare them out of curosity when i'm back home. Quote Link to post Share on other sites More sharing options...
alan.y Posted August 17, 2014 Author Share #8 Posted August 17, 2014 (edited) It's surprisingly compact on the M240 with M-R and in my opinion seemed more compact even with the M/R adaptor than its sister lens the 90/2 APO-Summicron-M asph. (But then having to use the EVF for the R version makes it less desirable on the M.) Pete. I find the same with the R 80 vs the M 75. The R at 700 grams is almost 200 grams heavier than my v3 German M 75, which is 520 grams, but the former feels better in hand because it's fatter and has more even weight distribution--less front heavy. Actually the R 80 is probably my favorite lens as an object to hold and, alas, fondle! The added articulation of an adapter also makes the lens seem more compact--your eye associates the adapter with the camera, not the lens. If I were to get the M version again I'd pick the first version without built-in hood. Having had the APO M 90, pre-APO M 90 v3, and R90 v2 e55, I think I'd probably feel the same about the 90's... Too bad the APO R is so much of a collector's item. Edited August 17, 2014 by alanjung Quote Link to post Share on other sites More sharing options...
lct Posted March 10, 2021 Share #9 Posted March 10, 2021 (edited) I have no experience with 11254 but AFAIK: • 11219 is the early version with 2-piece built-in hood, E55 or Series 7 filters • 11254 is the late version with 1-piece built-in hood, E55 filters Both have the same optics AFAIK but i may be wrong. 11219: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 11254: Edited March 10, 2021 by lct 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! 11254: ' data-webShareUrl='https://www.l-camera-forum.com/topic/231729-pre-apo-summicron-r-90-weight-difference-between-versions/?do=findComment&comment=4157814'>More sharing options...
