Remaining/new bugs in FW 2.0.1.5
Guest roey
I am not sure if this is a bug as such, but since the fw upgrade if the camera is set to manual lens selection the shutter does not close automatically if you remove a lens. I made the mistake of taking a lens off and sitting the camera down on a table for a few minutes. As the shutter was open and the camera was on the sensor seems to have statically 'sucked' a huge amount of dust onto itself. The next few shots I took had thousands of dust particles. It all blew off pretty easily...
x
  • Replies 319
  • Created
  • Last Reply
The distinction is important: If there is a bug you only need to demonstrate its existence and an engineer will try to eradicate it. If there is a feature you despise it doesn’t suffice to point out it exists; an engineer would just nod his head and assure you that that is indeed how it’s supposed to work. You have to convince him that it would be far better if the camera behaved differently. Anything else would get you nowhere.
In either case, that engineer should be replaced by someone smarter ;)
Over-exposure warning on the camera's display doesn't work as expected.
When the over-exposure highlighting threshold is set to 255 then you'd expect red blinking in those areas of the picture that have an 8-bit value of 255... not so. As a matter of fact, nothing will blink, no matter how severe the over-exposure of the the capture is. When setting the threshold to 254 then only the edges of the over-exposed areas will blink red ... which is almost imperceptible on the camera display.
In fact, the over-exposure highlighting feature won't work unless the threshold is set to 253 or less. That's a bug. I don't know if this bug also existed in the previous firmware, too.
When the highlight warning threshold is set to a value of x, then all areas equal to or greater than x (in 8-bit terms) should blink red. By the way, the same should hold for the under-exposure warning threshold. If that value is set to y then then all areas equal to or less than y (in 8-bit terms) should blink blue.
So while this bug isn't fixed, I shall set my over- and under-exposure warning thresholds to 3 and 253, respectively :mad:
This feature has been mentioned here before and seems to pre-date the current software version.
I do not think it's something to get het about, as the loss in gamut is something like 2 per cent. That's only a small fraction of a zone. I would like to see a picture where this reduction in gamut becomes visible.
How can I run out of engineers if I replace N dumb engineers with N smart ones ?
Smart engineers will make mistakes, too. In fact, they will make more mistakes than dumb ones.
Once you hire an engineer, he will take an appreciable amount of time to become productive. A smart one will start with some glorious mistakes and you would therefore fire him before he becomes productive. Hence, you will suffer a shortage of engineers.
On the old firmware, people complained that their LTM adapters were causing the 240 to say "no lens attached", where the M9 and M8 do not. I suspect that this was due to the M240 using lens detection to protect the shutter during live view lens changes. This is not an issue for cameras without live view.
One feature on the new firmware is that all LTM adapters now work. This might be due to Leica changing the firmware to ignore the lens detection for manual selection, so it must leave the shutter open in live view (ie. it cannot determine between a lens removal or an LTM adapter in use).
It is a choice between making all adapters work, or protecting the sensor during lens change.
Even if your generalization about engineers were true, I would still be replacing dumb engineers with smart ones. The way I discern between dumb and smart engineers is not only based on the number of mistakes they make.
In any case, I much prefer to suffer a shortage of smart engineers than abundance of dumb engineers. :rolleyes:
At least dumb Engineers would be able to write down or type the necessary code.;)
I have met plenty of smart Engineers* during my career and while many of them were very nicely dressed they were not necessarily competent Engineers.
Pete.
*Not so-called software engineers but Professional Engineers such as Civil Engineers, Structural Engineers, Mechanical Engineers etc.
Agreed. By experience, there is a "mysterious" inversely proportional relationship between how smart an engineer is and how nicely he is dressed :)
