AgfaPhoto VistaPlus and D76
Stealth3kpl
I have lots of VistaPlus 200 film. What would be a good starting point if I were to run it through with the intention of developing it in D76? Run it through at 200? Develop as per TriX? Then how would I proceed to fine tune the process? Is it a ridiculous notion? I am interested to see the outcome, especially if it means I save on C41 processing in the future.
Pete
Pete
Hi Pete, always in the film :)
I am also developing my color film Kodak Portra in C41.
I expect my water bath, for a constant temperature required
I intend to work at 30 ° C ... not burn me !
I already Tetenal Kodak and a Jobo tank
the rest develops like a b&w film
Home Processing of C-41 Color Negative Film • defocus·blog
Best
Henry
I have a lot of links if you're interested
http://www.pirate-photo.fr/documents/films/agfafilms-Vista.pdf
and I'll apply this technique (Pete translate with google) :)
http://www.pirate-photo.fr/forum/viewtopic.php?t=655
Agfa Vista is also sold quite inexpensively here in NL at Kruidvat, though not quite as low as the equivalent of 1£. I've used it on and off the last few years and generally like it. I think both 200 and 400 produce nice results, though both can be pretty grainy in darker settings (see larger versions of the second and fourth image below). First two are with ISO 200.
Booored | Flickr
Leica II Summitar
Practising the evening's speech | Flickr
Leica II Summitar
Waiting for fish | Flickr
M6TTL 35 Summilux Asph (11663)
Seven red lights | Flickr
best
Philip
Pete
Like you, I've acquired a lot of this from the Pound Shop, (although my local store now seems to have run out) and was considering using my normal B&W developer Rodinal and found this https://www.flickr.com/groups/rodinal/discuss/72157626770588601/
I know it's not D76 but is this of any value?
Pete
An example of my experiment with developing Vista Plus in Rodinal as per the instructions from Flickr in my previous post. Scanned as a colour negative, which is my normal practice even for B&W, they came out with a distinct yellow tinge.
However when converted to B&W in Lightroom the results appear OK.
Hope that's helpful :)
Yes that's correct Agfa Vista Plus exposed at ISO 200, I used the following for the example above
All at 20ºC
Pre-soak 5min,
Rodinal 1:50 dilution - Development time of 10 minutes. Started with 30 sec agitation then 5 sec more each 90sec
Stop 1min
Fixer 3min
Wash.
