Rock 'n' Roll lens for live concerts?
Overgaard
Does anybody have good experiences with lenses for concerts.
Usually one will have to work from the front of the scene (often with monitors in the way) or from a very distant location.
Further, the light is low and/or shifting and people on stage might move a lot around.
I've recently tried 80mm F/1.4 and with the 2X extender (making it into a 160 mm F/2.8).
I have also tried with the 400mm Telyt F/6.8.
I'm considering the 180mm F/2.0, the 180mm F/2.8 but I'm also looking at the modular set 280mm F/2.8 - 800mm F/5.6.
Ideally it would be great to work from a distance (for example by the sound mixer or at a balcony) in a good clear position without monitors in the way, with a fast lens, yet able to get (very) close with a tele. I'm basically talking portrait lens from 10-20 meters away.
Thorsten,
What's your budget and have you got a pass? For mere mortals like me, I take my R9/DMR 80-200/4 ROM and shoot at ASA 400 (- 2EV if necessary). This I can hand hold at 1/60th wide open and with a breath hold, one can get pretty good images from the 20th row. I would love to take my 280 APO telyt in, but security would stop me!!!
Here's some shots with the 80-200.
Best wishes,
Charlie
Thorsten,
I had a lot of luck with a 180 and a 1.4 extender. I would get there early and secure a front position, (stand up concerts), in this case, and good use plyable wax earplugs. (The best shooting spot always seemed to be from in front of the speakers.) I would shoot tungsten film, and never use flash. The film 3M 640T I don't think is made any more.
But pushed to 1000. I always shot at 1/500th and the reuslts were always tack sharp. The colors were accurate as the colors of the concert lighting. Flsh would have eliminated them. Performers don't like flash during performance also.
Rafael
It depents, what you like to get on the Film..:D
..normally it is nice to do the pictures a little bit from the bottom toward the top..
..but if you can't get near to the stage you have to do it with longer lenses...
I use the AA 90mm lens for the music part....and the 180mm is for security...:D
regards,
Jan
P.S. look at my webside, there are some pictures...
Thanks. Very interesting advice.
When in front of stage everything from 35mm to 90mm will do and 180mm is almost too long.
(Usually photographers are allowed for the first three pieces in front of stage - and never using flash).
What I'm looking for is something that will accomplish this type of photo (as the enclosed) from a higher angel at large concert halls. And that usually mens from way back as you can't place a ladder in a crowd anyway. I learned this photo was done by George Chin and he tells on his webpage that his range of lenses goes to 300mm - and all his lenses (from 15mm and up) are f/2.8 which is kind of handy if and when you need to figure out the light. All this F/1.4, F/2, F/4.0 drives you nuts, shifting back and forth, compared to just having one parameter.
I like action (which is usually implied i rock concerts) og at least some of the dynamic that live music should have, unsharp backgrounds and simplicity. I like that the enclosed photo has those elements.
A portrait of Snoop Dogg up his nose where he is frozen by a 1/500 second is not what I am looking for.
Chris' 400mm suggestion (Canon - what the f... are you up to?) lens sounds excellent.
A 28-500mm F/1.4 zoom is what I wish for, not heavier than 500 g. (is anyone from Leica reading this).
Anyway, I learn something from each poster, so don't stop them coming.
Charlie Chan,
The budget is... well, it's Leica. I wrongfully thought the complete 280-800mm modular set was 10,000 Euro or thereabout though.
I looked and learned earlier today that that will only cover the lens shade and then a coffee to celebrate the acquisitation of that lens shade - a full set is more like 30,000 Euro.
@thorsten...
most of the time i don't have to shoot from the soundboard.
http://barbecuediguana.com/archives/2007/04/16/music-and-no-sleep/
16-35/2.8L and 85/1.2L ... on 5d's ... at 400 iso. the 70-200/2.8L from the pit is just too much glass and not really needed.
i hope you're not planning on shooting film on a wireimage assignment! ;)
http://www.wireimage.com/GalleryListing.asp?navtyp=AME===270260
no, i couldn't forget the leicas ... don't worry! ;)
Guest licht
I use the Nikon D2X and D200 for concerts with the AF-S 17-55/2.8DX at one body and the AF-D 85/1.4 or AF-S 70-200/2.8 VR at the other body.
Also in the bag: AF-S 12-24/4.0 DX (for pictures of the audience or views of the whole stage), AF-S 28-70/2.8, AF-D 50/1.4, AF-S 105/2.8 VR
Only "divas" like Kyle Minogue, Maria Carey, Cher, Rod Stewart, David Bowie and last week Keith Urban don´t like the photogs to stand in the pit,
that´s the time when I use the AF-S 300/2.8 (with crop 1,5 it´s like 450mm).
I like stage shots with normal to wide lenses much more as they give the viewer the feeling to be in the action. The pictures with 300mm look like the view through a telescop from far away.
Look here for Justin with a little bit more action (2003):
