Benefit of Cable Release
Gary Clennan
A simple question but I wanted to find out the main purpose of people using a cable release with their M240. When I do tripod based landscape shots, I typically use aperture priority (don't shoot me) and adjust exposure compensation accordingly. I also use the timer to avoid any unintentional shake. I understand that a cable release would be used in Bulb mode which I have yet to use. I thought a cable release was primarily used for super long timed exposures. With the M240's limit of 60s, this really doesn't come into play. Basically, I am trying to find a reason to buy one but am not sure I need or would use it.... :)
It's not only to be used in Bulb mode, also just the mode like you say, but without the delay of the auto trigger...
It's just a 'remote control' for the shutter release really.
You can use cable realise at any speed. When using long exposure or B (Bulb) you can lock it up.
Main reason for cable realise is no need to touch the camera during shooting with instant firing unlike self timer which is timed.
Landscapes can have decisive moments too! Light breaking through a gap in passing clouds and illuminating a peak, the certain precise moment of a sunrise when the light is just right, the forming of clouds or a flock of birds passing that were unexpected but present themselves for a fleeting moment...
You should use a cable release at all times with a tripod, to avoid touching the camera and causing any camera shake, and avoiding camera shake is (mostly) the point of using a tripod in the first place (although I sometimes use one simply for convenience, or to maintain a point of composition, or to allow me to make direct eye contact when taking a portrait ).
The self timer is a fall back. It works but you're not in control of the precise point of capture.
Small point - short, stiff releases are entirely self defeating because they push the camera, causing movement. The best release is compliant, usually rather long.
Sent from my DEC Alpha 4000.
A cable release is used on a 35mm camera for the same reasons that it's used on a large format camera.
1. It greatly reduces camera shake
2. It gives you precise control over when to trigger the shutter
3. It allows you, when photographing a person, to communicate in a relaxed, normal way with the subject.
The second point is important not just for landscapes (waiting for a lull in the wind, etc.) but also portraits. Combined with the third point, one can have a natural conversation with the subject and trigger the shutter when the shot looks "just right".
Leastwise, that's what I learned from using a large format camera, and I find that it carries over very well to smaller formats.
Unless one can figure out how to trigger remotely.
Jeff
I think you are referring to my complaint that there are no compact remotes that work through the M9 USB. No?
Indeed it is a disappointment.
Jeff
Which raises the important point that with the M 240 and the Multifunction Hand Grip, one can also trigger the camera from a laptop screen.
The same is possible with the M9 using a Mac's built-in Image Capture. A major frustration is that the M9 cannot be triggered using common, capable and inexpensive remotes.
  • 1 year later...
Just met a guy from Texas claims to be a professional panorama photographer who is now working in (very high end) Camera store. I asked to purchase a cable release for a M240. He replied Leica does not make one, and why would you need one you have a self timer. He proclaimed to make 100 ft panoramas stitching multiple images never using a cable release and all the images line up perfectly.
1. If I had an employee working for me and someone wanted to buy a cable release I would expect the salesman to sell that person one. I would not expect the salesperson to try to impress the customer with his knowledge of cameras, methods of Photography and all of the best friends of his that are famous photographers. (after all he is working in the joint)
2. I'm not sure if Leica makes a cable release specific for the M240 but they have previously made and still offer a cable release.
If there is something about Leica you don't know and want to find out I now have met the MAVEN pm me if want the name.
The big benefit of a cable release, allows shutter speeds beyond 8 seconds, and beyond 60 seconds if you use auto mode.
Bulb mode and a stop watch is how landscape was shot for much of the 20th century and it still works best.
Well I am from Texas and do not profess to be a professional but if Leica designed the 240 to accept a cable release then there are some that will work. I have two Leica cable releases that are 20 years old that work great. I believe the only issue is that the release be able to plunge far enough to trip the shutter.
Those by Hama or cheap Chinese cable releases fit and are as smooth and secure as those I have from Linhof, Sinar etc. When I got my M240 there was a similar debate going on about why the thread in the shutter release was different, but despite trying six different makes (not as many as Pico) I couldn't find one that didn't work, and two are new and very cheap, and four are very old and expensive.
As others have said, there are decisive moments in landscape photography that aren't exclusive to using a Leica, they are worth waiting for but often need responding to immediately. I set the camera on a tripod and often wait for the light to change, look at the clouds to see when the sun will peak through, or wait for a branch to settle or gust of wind to create a pattern on water. So a cable release is the tool for catching the perfect moment, and not simply recording that you were there.
Steve
