M versus M9 in moderate cold winter
flyalf
I just tried both M and M9 in -15 down to -21C. Both cameras had fully charged batteries and were kept in trunk of car overnight in temp between -15 down to -21C (yeah, this travel was in rural area, so no theft risk). I then went for a hike / photo shoot-out for 5 hrs:
My conclusion: M handles the medium low temp down to -21C without problems, M9 can hardly be used.
My M9 took only 5 exposures and then went dead. No reaction when switching on/off. When removing and inserting same battery it woke, but the following exposure were not recorded on card :(.
I took 90 exposures during the 5 hrs with the M, most with LV (tripod work). I had no problems and when finishing the battery info showed 85% remaining. Quite good :)!
Photo:
http://www.l-camera-forum.com/leica-forum/landscape-travel/318067-roses-ice.html#post2612210
Thanks for this info, good news on the M performance.
I've used my M9 regularly in the cold, and found the same poor performance when I use an older battery. With a new fully charged battery, my M9 works fine -15 to -20 C (last month I shot at least 50-60 shots over a couple hours at these temps and still had over 50% charge left).
If your M9 battery is more than a couple years old, I'd suspect it is getting a little tired (although I've never started winter shooting with an overnight deep freeze, and that could certainly make a difference).
Until later,
Clyde
Did you compare the behaviour also, when using fresh, warm spare batteries between the two cameras?
I would be interested, if the issue was just battery related (I suppose) or camera related.
Sorry, I did not compare with new batteries since my fingers at that time stopped working :D. Also the M9 batteries are more than 2 years old, so they are perhaps a bit degraded?
Last December when I was in Inner Mongolia, one morning the temperature dropped to as low as -20 to -25C. I had both the M240 and M8 with me. The M240 performed well for over 2 hours, but locked up towards the end-of the shooting session. But battery was still showing over 50%. I used the EVF for many of the shots as I was using my WATE and a couple of R lenses. At these temperatures, the 35-70 R VE focusing and zooming became very stiff. The lubricant might be frozen. However, the focusing of the 180 Apo-Elmarit R remained smooth. No issue with the M lenses. The M8 did not fare well. It stopped working after about 20 minutes, despite indicating the battery was at full charged. Here is the link to some images from this trip,
http://www.l-camera-forum.com/leica-forum/landscape-travel/315454-winter-landscape-inner-mongolia.html
I've had my M out for a least an hour each day in -5 to -10C weather here in our southern "Snowpocalypse". I've had no issues, and battery life has been great. I only used live view once, not some something I generally do.
The only problem I had was the 2 pounds of gorgeous metal heat sink sucking the heat from my face.
Back from roadtrip. Still very satisfied with M (and M9 in -15C and warmer).
I have however noticed one issue with M and M9 in cold weather: There seems to be produced much, much more dust at sensor. I dont know where this comes from, if its from change of lenses or produced by shutter. Can it be that the cold makes the shutter "flake" of mini-particles?
Also quite irritating the dust particles move around from exposure to exposure, so I cannot sync dust removal in LR :eek:.
Still, a great camera for winter usage. If only the menu buttons could be larger/more bumpy to operate with gloves...
Well if the sheeps can take the cold so can I and my M :D:p
2014_01_Northways-66 by fotoalf, on Flickr
A few more photos from cold trip:
2014_Jan_Northways - a set on Flickr
