masjah Posted January 23, 2014 Share #1 Posted January 23, 2014 Advertisement (gone after registration) I'm not having a lot of success getting Focus Peaking to work on my new M240. It's set to "ON" in the Menu, and often (in fact mostly) I don't seem to be able to see the red outline at all. Itt's a bit premature for me to say that it's not working properly, but has anyone any tips please? I'm using the EVF2 with R-M adapter, and a 28-90 R zoom (which has been manually selected as the lens in use. I was using a wide aperture. Link to post Share on other sites More sharing options...
Advertisement Posted January 23, 2014 Posted January 23, 2014 Hi masjah, Take a look here Focus Peaking. I'm sure you'll find what you were looking for!
bephoto Posted January 23, 2014 Share #2 Posted January 23, 2014 you should push the Focusing button the one in front of the camera, R lenses don't trigger Rangefinder mechanism so there is no way for camera to know you started focusing. let me know how did it go. Link to post Share on other sites More sharing options...
farnz Posted January 23, 2014 Share #3 Posted January 23, 2014 John, Focus peaking works pretty well with my 28-90 Vario-Elmarit-R on the M and I think it's because it has reasonable contrast. I assume that you're pushing the focus button on the front of the M, which can be awkward to push in far enough when handheld. I've stuck one of those clear, plastic, self-adhesive 'bump dots' to the focus button, which not only makes it easier to push because it's raised but my finger finds it very easily owing to its different texture. They're available for pennies from stationers. I've also found that focus peaking is easier to see when the EVF image is magnified 5 or 10 times. Pete. Link to post Share on other sites More sharing options...
wlaidlaw Posted January 23, 2014 Share #4 Posted January 23, 2014 Focus peaking works well on my very similar Zeiss Vario Sonnar 28-85 lens, with a push on the focus button. The two lenses which have the strongest focus peaking are my Zeiss Planar 50/2 and SEM 18mm, where focus peaking is almost too much. I would like this to be variable, perhaps with a button push (Video button?) and roll on the top control wheel. On lower contrast lenses like my Hartblei 80mm Super Rotator, focus peaking is wholly absent. Wilson Link to post Share on other sites More sharing options...
masjah Posted January 23, 2014 Author Share #5 Posted January 23, 2014 Thanks everyone. I've been pushing the focus button, but I'll try again tomorrow. Does the red outline only show while the focus button is actually being held down, or does the button act as a trigger to initiate the peaking? As I said, it is set to ON in the Menu. Link to post Share on other sites More sharing options...
wlaidlaw Posted January 23, 2014 Share #6 Posted January 23, 2014 Thanks everyone. I've been pushing the focus button, but I'll try again tomorrow. Does the red outline only show while the focus button is actually being held down, or does the button act as a trigger to initiate the peaking? As I said, it is set to ON in the Menu. John, You only have to push the focus button once and it stays on until you push the shutter release. I would have said that the Vario Elmarit 28-90 is at the very least equal contrast to my Vario Sonnar, so peaking should be very evident. If it is not, I am afraid there is something wrong. Usual remedies ensue such as factory reset, popping battery and turning focus peaking off and on again. Wilson Link to post Share on other sites More sharing options...
masjah Posted January 23, 2014 Author Share #7 Posted January 23, 2014 Advertisement (gone after registration) John, You only have to push the focus button once and it stays on until you push the shutter release. I would have said that the Vario Elmarit 28-90 is at the very least equal contrast to my Vario Sonnar, so peaking should be very evident. If it is not, I am afraid there is something wrong. Usual remedies ensue such as factory reset, popping battery and turning focus peaking off and on again. Wilson Thanks Wilson, that's what I thought. I'll try the usual, andd allso try some different R lenses, and keep you all posted. Link to post Share on other sites More sharing options...
algrove Posted January 23, 2014 Share #8 Posted January 23, 2014 John Just thought about your issue. Did you hit the LV button before you press the #3 button on the front of camera? Link to post Share on other sites More sharing options...
masjah Posted January 23, 2014 Author Share #9 Posted January 23, 2014 John Just thought about your issue. Did you hit the LV button before you press the #3 button on the front of camera? Yes, I'm in LV mode, with the EV-2 attached, and the EV-2 button pressed to display through it. Link to post Share on other sites More sharing options...
jaques Posted January 24, 2014 Share #10 Posted January 24, 2014 contrary to what the instruction manual describes- focus peaking is next to invisible unless you magnify the image. At first I thought mine wasn't working as well... it also does not work very well at all with some lenses wide open. Personally I think it is too weak- and I wish there was a way to adjust the peaking levels... I think you should be able to at least see it without magnification on the LCD screen- after all this is what is pictured in the instruction manual... Link to post Share on other sites More sharing options...
wlaidlaw Posted January 24, 2014 Share #11 Posted January 24, 2014 I agree it should be adjustable because the converse is that on very high contest lenses FP is too strong and rather distracting. Wilson Link to post Share on other sites More sharing options...
jaapv Posted January 24, 2014 Share #12 Posted January 24, 2014 contrary to what the instruction manual describes- focus peaking is next to invisible unless you magnify the image. At first I thought mine wasn't working as well... it also does not work very well at all with some lenses wide open. Personally I think it is too weak- and I wish there was a way to adjust the peaking levels... I think you should be able to at least see it without magnification on the LCD screen- after all this is what is pictured in the instruction manual… But if it were stronger it would be less accurate, and that is pretty good right now. Adjustable would be a nice thing. Link to post Share on other sites More sharing options...
thighslapper Posted January 24, 2014 Share #13 Posted January 24, 2014 But if it were stronger it would be less accurate, and that is pretty good right now.Adjustable would be a nice thing. It is on the Sony A7r ........... but on low it's invisible and on high makes your eyes water and is inaccurate ..... so with all the lenses I have tried (Sony and Leica) it's stuck on medium ..... Link to post Share on other sites More sharing options...
masjah Posted January 24, 2014 Author Share #14 Posted January 24, 2014 contrary to what the instruction manual describes- focus peaking is next to invisible unless you magnify the image. At first I thought mine wasn't working as well... it also does not work very well at all with some lenses wide open. Personally I think it is too weak- and I wish there was a way to adjust the peaking levels... I think you should be able to at least see it without magnification on the LCD screen- after all this is what is pictured in the instruction manual... Jaques thanks for this. In a perverse way that's actually quite reassuring, so far as anything might be wrong with the camera. I'll continue to experiment (bit tied up with other things for the next day or two though). I'll report back. Link to post Share on other sites More sharing options...
01af Posted January 24, 2014 Share #15 Posted January 24, 2014 The Leica M (Typ 240)'s focus-peaking level is just fine the way it is. If they should change anything about it then it's not the peaking level but the number of magnification steps. Currently it's 1×, 5×, and 10×. I'd like to have, say, 1×, 4×, 7×, and 12× instead. The visibility, usability, and accuracy of the focus peaking highly depends on the viewfinder magnification matching the lens magnification (focal length) and the level of detail in the subject. So having more magnification steps would be a good thing. One the other hand, having too many of them would be distracting. I think having three steps rather than two (not counting the 1× magnification) would be just right. And being able to choose between different outline colours would be nice, too. Besides red, I'm thinking of yellow and blue. Link to post Share on other sites More sharing options...
FMB Posted January 24, 2014 Share #16 Posted January 24, 2014 Is it true that the frontal button must be pushed "soft and short"? I don't know if it's only my camera needing this type of pushing, because if I push it for a while it seems not to be active. What about the behavior of your cameras? Francisco. Link to post Share on other sites More sharing options...
thighslapper Posted January 24, 2014 Share #17 Posted January 24, 2014 And being able to choose between different outline colours would be nice, too. Besides red, I'm thinking of yellow and blue. ....... yellow and white options on the SonyA7r ........ white is useless for fairly obvious reasons most of the time .... yellow just irritates .... so it was back to red.... ho.... hum ..... Link to post Share on other sites More sharing options...
satijntje Posted January 24, 2014 Share #18 Posted January 24, 2014 In Order to see the red lines better, I have set the M240 to jpeg and dng but the jpeg in Black and white. This way its easier to see the red lines or dots. Try it, it works Great! John Link to post Share on other sites More sharing options...
jaapv Posted January 25, 2014 Share #19 Posted January 25, 2014 That is smart lateral thinking. Just the trick if you have a red subject… Link to post Share on other sites More sharing options...
Leonil Posted January 25, 2014 Share #20 Posted January 25, 2014 I do just that after someone kindly pointed that out to me in the forum. I never ever shot RAW+JPEG ever before until now - my screen shows as B&W and my Live view is B&W and peaking shows up like a boss! Link to post Share on other sites More sharing options...
