incorrect frameline issue
lordofwar
Hi all,
I've seen a strange problem with my M 240: it doesn't show the right frame line for 35mm lens. As long as I mount a summarit 35mm on the camera, it can recognize the lens without problem, but shows the 50mm/75mm frame line. If I push the "info" button, it shows a 35/2.5 lens has been detected. Really strange. I've tried manual, off, automatic lens detection, and even reset everything, it still shows the incorrect frame line. Anyone here has seen similar issue? Seems to me like a firmware bug...
Yes, it's mounted correctly. Other lenses don't have the problem. I tried the same 35mm summarit lens on a M9 and the frame line is shown correctly, so it's not the lens. I'm sending it back to Leica for repair...
Does the lens click in correctly when you mount it? And do your other lenses behave normally?
I have had this happen a couple of times with my M240, and it's simply a mechanical issue of not having the lens fully rotated into the mount. It's a tight mount, and with some lenses there is not always a nice "click" into place, but you need to fully rotate the lens against the hard stop.
