Uncoded lenses and framelines
Leonil
So I was thinking, Ive only ever used the M a couple of times from a friend and I was thinking.
I have a 50 summicron (chrome) lens that's uncoded, and have a Zeiss 28mm 2.8 on order.
If say I have the 50mm frame lines on the rangefinder - selected via the menu, and I change lenses to the 28 and then select the lens via the menu, will I have to keep doing that EVERY TIME I change the lens to an uncoded lens?
I know that you can have multiple frame lines on the view finder but In my experience the frame lines aren't digital, its all hardware. And seeing as the 50mm lines are on with the 35mm lines at the same time, how do I can organise my 28mm when paired with a 50mm?
Or am I just dumb and its all taken care of already in the camera?
Frame lines are not set by any menu, they are mechanically linked to the lens mount. The lens you use will make the appropriate frame appear - as you know they are in pairs, as Leica can only fit so many masks in the assembly.
Thanks, good to know Im just over thinking things.
For the M9 at least, Zeiss suggests manually setting (menu) your new Zeiss lens as any of 21 2.8 Asph, 24 2.8 Asph (less good) or 28 2.8 Asph. Probably you should do the same with the M240. You may get better results setting the lens manually rather than leaving it as 'off'. Obviously you'd make the menu change when switching to 50mm. Reid reviews suggests some lenses do not need Lens Detection. As noted above this is not related to framelines but colour/vignetting corrections in-camera.
... And seeing as the 50mm lines are on with the 35mm lines at the same time, how do I can organise my 28mm when paired with a 50mm? ...
I got this tip from Thorsten Overgaard:
You can use the user profiles. Make your favourite settings (ISO, WB, DNG, JPG, etc) and have a manual lens selection for the 50 Summicron, then save as user profile 1. Change the manual lens selection to something that fits the Zeiss 28, then save as user profile 2. Maybe a user profile 3 with auto lens detection.
Whenever you change the lens, you quickly go via SET menu and select the respective user profile. Works for me.
Seems like a good idea - But Im hoping that when my 28 and new M arrives, I can just change lenses (Uncoded lenses) and not worry about telling the camera what to do.
