Nr90 Posted March 14, 2015 Share #101 Â Posted March 14, 2015 Advertisement (gone after registration) Very cool tool! Thanks for this 1 Link to post Share on other sites More sharing options...
Advertisement Posted March 14, 2015 Posted March 14, 2015 Hi Nr90, Take a look here M8raw2dng - Tool to convert Leica M8 RAW files to DNG. I'm sure you'll find what you were looking for!
Guest Posted March 16, 2015 Share #102 Â Posted March 16, 2015 No, it still doesn't work, as I have described under #30 at http://www.l-camera-forum.com/leica-forum/forum-zur-leica-m8/318565-sensor-der-m8-2.html Link to post Share on other sites More sharing options...
Nr90 Posted March 17, 2015 Share #103  Posted March 17, 2015 It took me a while before I could edit the parameters for the OS X droplet. This is what I did:  1. Download the .zip 2. extract the .zip -> This gives you a file called m8raw2dng-droplet.app 3. Right click m8raw2dng-droplet.app and click Show package contents 4. Open the contents folder 5. Open the Resources folder 6. Open the Scripts folder 7. Open the file main.scpt (applescript is the default editor) 8. Change the parameters and save the file  After which the droplet worked as described.  PS: This is under 10.10.3 (14D105g) Link to post Share on other sites More sharing options...
Guest Posted March 17, 2015 Share #104  Posted March 17, 2015 It took me a while before I could edit the parameters for the OS X droplet.This is what I did:  1. Download the .zip 2. extract the .zip -> This gives you a file called m8raw2dng-droplet.app 3. Right click m8raw2dng-droplet.app and click Show package contents 4. Open the contents folder 5. Open the Resources folder 6. Open the Scripts folder 7. Open the file main.scpt (applescript is the default editor) 8. Change the parameters and save the file  After which the droplet worked as described.  PS: This is under 10.10.3 (14D105g)    Thanks, but it still doesn't work on my Mac with the same system OS X 10.10.3.  Pt 1.: Perhaps that's no problem, but there is no zip, the download contains three bundles:  - m8raw2dngv11mac, - m8raw2dngv12beta_mac and - m8raw2dng-droplet.  Pt 2 - Pt 7.: works, but don't know which parameters have to be changed under Pt.8.: The script editor looks like this:  " # global variable definitions global TheApp, Params  # TheApp should point to the m8raw2dng executable on setTheApp() set TheApp to "/Applications/m8raw2dng" end setTheApp  # Params are the Parameters you want to hand over to the script on setParams() set Params to " -v -r -b -p -l -o /Users/YourName/Pictures" end setParams  # From here on leave it be on open filelist setTheApp() setParams() repeat with i in filelist tell application "Terminal" activate set filecount to 1 set filename to do shell script ¬ "perl -e \"print quotemeta ('" & POSIX path of i & "');\"" if (count of windows) is 0 then do script TheApp & " -i " & filename & " " & Params else do script TheApp & " -i " & filename & " " & Params in window 1 end if end tell end repeat end open  set filecount to 0 if filecount < 1 then setTheApp() setParams() tell application "Finder" set folderpath to POSIX path of (parent of (path to me) as string) end tell tell application "Terminal" if (count of windows) is 0 then do script TheApp & " -i " & folderpath & " " & Params else do script TheApp & " -i " & folderpath & " " & Params in window 1 end if end tell end if "  As I'm no computer expert, do you have some examples perhaps, how to change the parameters and why is this necessary? Link to post Share on other sites More sharing options...
Nr90 Posted March 17, 2015 Share #105  Posted March 17, 2015 Let's use m8raw2dngv12beta_mac and m8raw2dng-droplet.  m8raw2dngv12beta_mac should give you a folder with three files: lensdb.ini sensdb.ini m8raw2dng   What I did was create a folder in my users directory named: m8raw2dng. Copy the files from the m8raw2dngv12beta_mac folder into the newly created m8raw2dng folder.  Now we must tell the droplet where to find the m8raw2dng executable. 1. Open the main.scpt in the droplet as described above 2. Go to line 6. This says: set TheApp to "/Applications/m8raw2dng" This tells the droplet that the m8raw2dng executable is in /Applications We put in the current user's directory so we change the line to: set TheApp to "~/m8raw2dng/m8raw2dng" (keep the tab in front of the line) (on unix systems the ~ is the path to the current user's home directory) 3. Save the file   Next we must set the parameters. The most important being the output location (where to put the newly created DNG files).  1. Go to your Pictures folder 2. Create a folder called: m8raw (A different name is possible, if so change the following to reflect your folder's name) 3. Open the main.scpt in the droplet as before 4. Go to line 11. It says: set Params to " -v -r -b -p -l -o /Users/YourName/Pictures" This tells the droplet with which parameters it should run the m8raw2dng. For a full description go to: M8raw2dng – Tool to convert Leica M8 RAW files to DNG The most important one is the -o It sets the output directory. Change the line to: set Params to " -v -r -b -p -l -o ~/Pictures/m8raw" (change the path if you chose a different location / name) 5. Save the file     Now your droplet is ready to be used. Drag a folder of RAW and JPG files on top of the droplet and it should output the resulting DNG files in your ~/Pictures/m8raw folder.    You will probably find the resulting DNG files are magenta coloured and uneven. We can fix this later 1 Link to post Share on other sites More sharing options...
ndf9 Posted March 17, 2015 Share #106  Posted March 17, 2015 Hy guys I'm new in this Leica M8 Forum  after i sold my MM, i bought a M8 and new lens, so my question is  Make it sense, to use the Leica RAW+JPG with M8Raw2dng for daytime picture. or is it more a good combination for high Iso (basic ISO160) for darker situations?  Thanks  Nic Link to post Share on other sites More sharing options...
Nr90 Posted March 18, 2015 Share #107  Posted March 18, 2015 Advertisement (gone after registration) Hy guys I'm new in this Leica M8 Forum after i sold my MM, i bought a M8 and new lens, so my question is  Make it sense, to use the Leica RAW+JPG with M8Raw2dng for daytime picture. or is it more a good combination for high Iso (basic ISO160) for darker situations?  Thanks  Nic  My experience with the tool is rather limited, but I wouldn't. Imo the raw files are clearly superior when pushing 160 ISO files up to 5 stops. In daylight the added information is not as apparent. To me the biggest issue is switching to the fine+raw mode. The button dance + changing the compression each time you switch the camera on is too much work for the limited daytime benefit. That said, If you don't mind the button dance, I see no reason to shoot compressed DNG over raw. Link to post Share on other sites More sharing options...
ndf9 Posted March 18, 2015 Share #108 Â Posted March 18, 2015 My experience with the tool is rather limited, but I wouldn't.Imo the raw files are clearly superior when pushing 160 ISO files up to 5 stops. In daylight the added information is not as apparent. To me the biggest issue is switching to the fine+raw mode. The button dance + changing the compression each time you switch the camera on is too much work for the limited daytime benefit. That said, If you don't mind the button dance, I see no reason to shoot compressed DNG over raw. Â I think the Raw files should have more dinamic range as the compressed DNG files also with Highlights. Maybe not 5 stops, but some more flexibility as with compressed files. Â the button dance is quick, and let me feel i would prepare the M8 for something more special. Â I like the idea to change the parameter -c and have the M9 colors after the raw 2 dng conversation Would be interesting to know more about how the raw files are reacting with highlights Link to post Share on other sites More sharing options...
Guest Posted March 18, 2015 Share #109  Posted March 18, 2015 ... Thanks for your help, now it works. Here is the first converted photo of an external viewfinder, acquired at the last local market for used photo equipment:   Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!   • Leica M8.2 • Summicron 50 coll. • SOMKY • ISO 160 • LR 5.7 • Stuttgart • März 2015 • Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!   • Leica M8.2 • Summicron 50 coll. • SOMKY • ISO 160 • LR 5.7 • Stuttgart • März 2015 • ' data-webShareUrl='https://www.l-camera-forum.com/topic/216705-m8raw2dng-tool-to-convert-leica-m8-raw-files-to-dng/?do=findComment&comment=2782977'>More sharing options...
Lenshacker Posted March 18, 2015 Share #110 Â Posted March 18, 2015 The compressed DNG format allocates 74 values to represent the entire upper half of the intensity values. If you do any post-processing, it's worth having the full range of data. Â If you are going to convert images to monochrome, uncompressed allows more flexibility. Â I did some tests here: Â Showcase - M8 Monochrome Conversion comparison RAW vs DNG, M8RAW2DNG V1.2 | Leica Place - Leica User Group 2 Link to post Share on other sites More sharing options...
Nr90 Posted March 21, 2015 Share #111  Posted March 21, 2015 Thanks for your help, now it works.Here is the first converted photo of an external viewfinder, acquired at the last local market for used photo equipment:   [ATTACH]489430[/ATTACH]   • Leica M8.2 • Summicron 50 coll. • SOMKY • ISO 160 • LR 5.7 • Stuttgart • März 2015 •  Nice! Glad to be of help Link to post Share on other sites More sharing options...
ndf9 Posted March 22, 2015 Share #112  Posted March 22, 2015 (edited) So finally!!! Sorry i have to show this to happy with the M8  all pictures with M8 Raw - M8RAW2DNG - DNG - LR5  thank you Arvid, thank you Lenshacker  first: HIGH ISO 5000 equivalent (-5 stops)  second: High contrast  third: full sun  forth: shadow  fifth: High Contrast  sixt: sun from side  seventh: shadow again  8th: fun Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited March 22, 2015 by ndf9 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/216705-m8raw2dng-tool-to-convert-leica-m8-raw-files-to-dng/?do=findComment&comment=2785025'>More sharing options...
pklein Posted April 3, 2015 Share #113 Â Posted April 3, 2015 (edited) Here is some more fun with pushing M8 Raw files. Below is a link to two crops, both at 100% magnification, taken at the same f-stop (despite what the EXIF says). They were taken at night under artificial light. The scene looked a bit darker in real life than it does in the pictures. The crop on the left is ISO 160 pushed to 1250. The shadowed upper part of the face is "dodged" an additional 0.6-stop. Very nice. Â The crop on the right was accidentally underexposed 1-2/3 stops beyond that, so it's probably at about ISO 4000 equivalent. Again, the upper face is dodged an additional 0.5 stop. The color is a bit crunchy, but it would still be usable at reasonable print size. Ignore the vertical line, I believe it's caused by a hot pixel just above what's shown. I haven't yet messed with Arvid's feature to map that out. Â http://gallery.leica-users.org/d/407757-1/M8Raw1250vs2500.JPG Â And, if I convert the ISO 4000 equivalent to B&W, it would print as a nice, moderately grainy picture. Remember, this is at 100%. Â http://gallery.leica-users.org/d/407759-1/M8Raw2500bw.JPG Â Shot with an M8 and 35/1.2 Voigtlander Version I, Raw converter is Capture One 7.12. Screen-size images of the full pictures are here: <http://gallery.leica-users.org/d/407725-1/L1010071.jpg> <http://gallery.leica-users.org/d/407786-1/L1010074.jpg> <http://gallery.leica-users.org/d/407784-1/L1010074+_1_+.jpg> Â The uncompressed Raw files plus M8Raw2DNG software easily gives the M8 a full stop more usable high-ISO than the compressed DNGs. ISO 1250-equivalent is only a tiny bit worse than uncompressed 640, and 2500 (or slightly more) is not as bad as compressed 1250. Your mileage may vary, batteries not included, I am a data point of one, but I find this technique *very* useful. Â A big thank you to Arvid for the software, and to LensHacker for working with it and telling us about it. Â --Peter Edited April 3, 2015 by pklein 3 Link to post Share on other sites More sharing options...
Lenshacker Posted April 3, 2015 Share #114  Posted April 3, 2015 I1015874_2 by fiftyonepointsix, on Flickr  B&W 090 Red filter used with the M8, blue and green channels pulled up. The Blue channel is basically Infrared, Green is "mixed" and Red is visible light. Blue is pulled up about 10x. Green about 5x. Hue is rotated to get Infrared Ektachrome look. This works thanks to the 14-Bit values in the M8RAW2DNG converted raw files, and to the weak IR filter. 1 Link to post Share on other sites More sharing options...
Lenshacker Posted April 4, 2015 Share #115  Posted April 4, 2015 I1015897 by fiftyonepointsix, on Flickr  With B&W 090 Red filter. 1 Link to post Share on other sites More sharing options...
pklein Posted April 5, 2015 Share #116 Â Posted April 5, 2015 Earlier I mentioned the problem of running out of buffer space when shooting quickly. My initial comments were too pessimistic. I ran a couple of tests, and found that I can have 10-12 "JGP Fine + RAW" shots in the buffer at once. Because JPG is involved, the write times are affected by how much detail the JPG algorithm in the camera has to crunch. This probably includes noise/grain, so 2500 will likely have longer write times and bigger files than 1250. At effective 1250, each single shot appears to clear the buffer in about 9-12 seconds. This is with a 4 GB Sandisk Extreme card rated 30 MB/Sec. Â When I shot a single frame every 2-3 seconds, the buffer filled up and refused to take any more shots after the 12th ("Attention: Data Transfer!" message on LCD). On another run, shooting in continuous mode (faster), the buffer was full after 10 shots. In each case it took the buffer 1:42 to completely empty (starting from the first shot). But once one shot had cleared the buffer, the Data Transfer message disappeared and I could take another shot. Â So a good rule of thumb is that each shot will take an average of 10 seconds to clear the buffer, and you can have 10 of the 20 MB RAW+JPG fine frames in the buffer at any one time. Shooting quickly in single-shot mode, you'll fill the buffer in about one dozen shots, after which you can only take one shot every 10 seconds until the buffer empties further. Â So, if you need machine-gun shooting speeds, you'll run into trouble with the M8 uncompressed RAW. If shoot for decisive moments, you probably will be fine most of the time. Â --Peter Link to post Share on other sites More sharing options...
bla Posted April 5, 2015 Author Share #117 Â Posted April 5, 2015 Thanks Peter for this valuable test and the useful information! I would be interested how it behaves for DNG+JPG fine in comparison. Does that improve much? I always recommend to use ISO160 only with RAW, so the jpgs at least get smaller with higher ISO I would love to take RAW only, I think it'd be quite fast. Thanks again for the test! - Arvid Link to post Share on other sites More sharing options...
pklein Posted April 10, 2015 Share #118 Â Posted April 10, 2015 Arvid: I ran another test for you, of the same scene, lens and lighing. This time I used DNG + JPG Fine, continuous mode, with everything else set the same as as with RAW + JPG Fine. The Buffer still filled up after 10 shots, but emptied in 1:06. A 38% improvement in overall speed. Â It's a multi-variable problem, because we're keeping the JPG processing, but the DNG is half the size of the RAW and more "stepped" in gradation rather than continuous, and the square root compression is being applied with DNG, but not with the RAWs. Â It is fun to play with this. Now I need to see if I can map out the hot pixels on my sensor, and if that will get rid of a vertical line that has appeared in some of my RAW-derived pictures. I never sent my M8 to Leica to have hot pixels mapped out, I just used Pixel Fixer. So now I need to get my hot pixel data into your INI file. I didn't have to worry about lines with Pixel Fixer. Once I mapped out the hot pixel, any line that descended from it disappeared. Â --Peter Link to post Share on other sites More sharing options...
Guest Posted April 14, 2015 Share #119  Posted April 14, 2015 This photo has been taken at the Anders Petersen exhibition in Munich in 14-bit raw mode by 160 ISO. In Lightroom 5.7 it was postprocessed by 4 1/4 apertures.   Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!               Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!               ' data-webShareUrl='https://www.l-camera-forum.com/topic/216705-m8raw2dng-tool-to-convert-leica-m8-raw-files-to-dng/?do=findComment&comment=2797883'>More sharing options...
saxman777 Posted September 18, 2015 Share #120  Posted September 18, 2015 Hi guys.. I am a late comer, and technically I have nothing to contribute. But I just would like to thank Arvid for his effort. I have just aquired a used M8 specifically because of this app that you've created and I'm loving the output. Next I would like to run this DNG file with Raw Photo Processor (RPP) which I am loving as well. And thanks to all you guys who have contributed to the development as well.  Cheers -Khai- 3 Link to post Share on other sites More sharing options...
