Leica M 240 battery
Pelpa78
Let's not assume the Leica battery for the M240 is without fault.
Really ..... let's not ........
I just paid a lot of money for a brand new Leica battery in sealed box which was absolutely faulty. No new replacement available where I am at the moment, and nobody seems to know when one will be available.
For me, another failure of a brand new Leica product .............
  • Replies 61
  • Created
  • Last Reply
  • 2 weeks later...
So I took my M and 50 Summilux to work today planning to do some photography on my walk home. I had put a freshly charged battery in the camera 72 hours earlier but did not check it this morning - no need to, right?
Wrong! Got out of work, battery drained! Not sure if the shutter had been off or on but no way any of the buttons or shutter were accidentally held down during the day. This would never have happened with the M9 or Monochrom.
Am I pissed off :mad:
... but did not check it this morning—no need to, right? Wrong! Got out of work, battery drained!
A similar thing happened to me in the first or second week with my new M ... but never again since then. I suspect it's an issue with new batteries that silently goes away after a couple of discharge-recharge cycles.
Dear Jaap,
It happened to ke at least three times. I figured my setting for auto-power of is not working well as Infigured that everytime it happened, the main switch had moved from off to on (single) in the camera bag. I suspected that in the bag the shutter button was pressed repeatedly or constantly half way so the battery drains. However it could be related to something else as well.
All the best, Jörg
Received replacement spare battery yesterday in time for my trip ( it was a relief ) ........ it charges up and seems OK. I plan to charge and allow to discharge a few times before travelling with it.
On the plus side, the M 240 appears to be an extremely fine camera. I am looking forward to learning how to get the best from it.
...It happened to ke at least three times. I figured my setting for auto-power of is not working well as Infigured that everytime it happened, the main switch had moved from off to on (single) in the camera bag. I suspected that in the bag the shutter button was pressed repeatedly or constantly half way so the battery drains...
Battery drain can be fast if "auto power off" is set to off indeed. Suffice it to forget to switch the camera off for that. Disabling the sleep mode is the only way to get short startup and wakeup times though so far.
I have two batteries, each recharged numerous times. Last week both drained within 8 hours. It could have been avoided if I turned the camera off, of course.
I just bought a Panasonc Lumix LZ1 battery - a rather nothing thingy really-, at an eyewatering 69 Euro....:eek: Five batteries will buy the whole camera including a battery...:rolleyes: If Leica offends, they are not the sole offender.:mad:
I got a third party one at 9.90 Euro too - works just as eel....
I have the same problem with my M240. After checking many times, it seems auto off is faulty. Actually it's intermittent, because sometimes it works fine and turns the camera off as it's supposed to do, and sometimes it fails to shut the camera down and the battery continues to drain.
Dear Jaap,
All the best, Jörg
Hi everybody,
It seems my iPad played some tricks onme when I was typing.
Therefore I have to correct the above. The auto-power off on my camera is always set to 2 minutes, that way the above said about the battery drain makes more sense.
Now, since one week I do have two batteries and can go to India for a couple of days with less worries.
And whatever will eventually be solved in future firmwares worries me less.
Jörg
The camera is set to power down after two minutes on all modes. There is no way that any of the switches were accidentally pressed for an extended period of time. The battery was probably only charged once or twice so I'll watch out for it again. I've already spoken with Leica Australia who are happy to check the battery if it happens again. I do have two batteries.
If you disabled sleep mode previously, you will have longer statup and wakeup times (about 2 seconds) but you will avoid battery drain (about 10% per hour) this way.
Hello ICT
Are you saying that if I leave the camera on but set to power off after two minutes, the battery will drain in about 15 hours (10% per hour)?
That seems unreasonable.
My M9 with similar settings would last for days.
