purple blobs in photo with an M8
festgriff
Hi. I havent been able to find anything about purple blobs here in the forum, probably because I am using the wrong keywords. Anyway I would appreciate any ideas about the cause of the purple blobs in the attached photo. It is not the "purpling" of dark fabrics, nor does it seem to be IR refelection from plants as the rest of the foliage isnt showing it. It almost looks as if there was a spill of developer (to go analog).
I have only seen this when shooting indirectly - not directly - into the sun. Lens hood is on, no IR filter yet though. 28-35-50 mm Tri-elmarit ASPH. Shot as DNG and imported into either Capture One or Lightroom - both give the same result. The purple blobs are there in a 35 mm and a 28 mm shot (here is the 35 mm shot) but not in the 50 mm which has me thinking it has do with the focal length and some time of aberration. But I could be totally off base there.
Any ideas or suggstions - or just knowing some of you are also seeing the same effect would help.
Thanks in advance.
Almost certainly flare - in addition to the purple 'blobs', the image shows signs of the more general veiling glare that (in my experience) is a rather unfortunate characteristic of the TE at 50mm.
I am in denial, but Leica lenses CAN flare in contrejour situations like this. Especially the Tri-Elmar.
My 24/F2.8 (which I no longer own) used to regularly display some quite spectacular red flare spots/blobs when shot towards the sun (which I tend to do a lot of). My 35/F2 ASPH is also not entirely forgiving when used in this way.
I am almost sure that same shot/same lens on film Leica... blob...maybe different in color, but I bet a blob would have appeared... I obtained them with lenses ranging from 21 to 135 in similar situations... I think not a problem of M8 by itself, Carsten is right: part of life...
Thanks everyone for the constructive comments. I havent really noticed this kind of thing with my M6 and film so I was worried - and didnt think of flare. I did get flares on film once in a while in such circumstances but never a line of slowly shrinking blobs - maybe the alien star trek idea isnt that far off. :)
Might just be that in this "honeymoon" stage with the M8 I push it a lot farther than I would the good old M6.
