it just happened again:confused: and I didn't have a chance to capture it on film... I could photograph the dial sitting firmly planted on S mode (where I always have it and never bump it- I virtually never use C mode, and only use the timer on a tripod).
I had just convinced myself it had fixed itself again too. Hope springs eternal (and is eternally dashed... in the end). So that's that: I was going to suggest to Leica either a full replacement: or a written guarantee that if the error occurred again the camera would be replaced immediately. I already happened again so it has to be a replacement camera. I will start making the calls tomorrow.
I have a question: could this issue be recorded in the full metadata? Does it record if the camera is on S, C or timer mode? If it showed the camera on S mode- but the self timer coming on- then I would have my proof.
also I just noticed my photo #'s in lightroom: they start at L1009912
Does this mean my 'new' camera has fired off over 9900 shots already?? :eek: That's more than I put on my M9-P in two years:rolleyes: and I have only shot maybe 300 on the M myself.
Edited by jaques
UK law and Australian law have some common features, but I'm not sure how far that goes in consumer issues. Even though in this case the fault appears to be Leica's, in the UK it is the responsibility of the retailer to sort it out, or provide a replacement, or provide a refund; what the manufacturer will or won't do is irrelevant - in law. The retailer may not see this as fair, but that is who your "contract" is with, not not Leica. Is that the same case with you? Has your retailer offered any redress?
PS I'm not a lawyer!
No that only means you have, at one point, inserted a card with a filenumber L1009xxx.Or somebody in Leica CS did so.
There is a lot of hidden data in the EXIF that you can not normally see with most EXIF data shown in applications like LR or C1. However, it may be worth looking at the EXIF of the captured image. If you send me the file when I get back home from my current business trip on Friday I could try and decode it for you. Just PM me for my email.
Thanks for the offer John. Can you get that data from a downsized Jpeg? here is the image: I pressed the shutter precisely 12 seconds before it was taken- dial set firmly to S mode- I was running inside to (vainly try to) get my iphone to video it when the shutter fired:
Edited by jaques
It is true.
I am confused then... I just checked the first image I took with the camera - it was number Ll000001.
then after I got the camera back from Solms- I inserted a card- reformatted it- as I always do- took a shot- and the number was L1009912?
How does that work?
Edited by jaques
I would need the full original JPG or DNG file to ensue I had an unmodified EXIF.
when I processed the DNG in LR I exported it and selected 'include full metadata'? but if it isn't all there- how can I best send you the large DNG file? I am on a mac- and have access to their (NSA riddled) cloud- but I have never used the feature...
Or instead of sending it- is there any way I can look at the metadata myself easily? If I could access it I could post the text here for expert evaluation... Do I need some kind of program? I am a complete imbecile in these matters....
when I ouput that JPEG I selected included 'full metadata'.
Edited by jaques
Jaques,
It requires a special command line program on your Mac. I have it on my Mac at home but not here on the road with me. You can try and upload to my public DropBox folder
It require special effort to decode the information so it is easier for me to look and see if it is there rather than trying to explain to you how to do it.
If it won't let you, let me know and I will provide an alternate means but not today as I have to get some sleep.
really? Yours is the first other account of this issue I have seen posted anywhere. It is very annoying isn't it? Whilst I am sorry for you- I am happy to hear that this is not totally isolated to my camera. Perhaps if it occurs to more users Solms will be more inclined to believe me- and to figure out why it happens.
Edited by jaques
How does that work?
The camera will remember the highest number used, so in your case that is the number of the last image on the card used in Solms. Simply reset the numbering. There is procedure for it.
http://www.l-camera-forum.com/leica-forum/leica-m9-forum/98104-file-numbering.html#post1031399
Edited by jaapv
Ok thanks Jaap. This never happened on the earlier M digital did it? And am I correct to assume that you can no longer tell how many shots the camera has actually fired?
I have uploaded the image to my own dropbox John- I couldn't manage to load it direct to yours... I will just PM you the link now- thanks in advance for your offer to have a look at it. If any other meta data sleuths are interested to delve into it let me know and I can send the link to you.
Edited by jaques
Jaques, it depends on the camera settings for file numbering. You can also reset or edit the file numbers too.
With a newly formatted card the camera would normally then continue the sequence from its (internally stored) memory of the last frame shot. As some one mentioned that may be from whatever the technician used when testing your camera. If you insert a card which has existing files on it, then the camera will normally continue that sequence instead.
There are other possible variations based on whether you have more than one folder on the card too.
I have looked at the above JPG and the file you sent me via PM.
Here is the EXIF data for the JPG above:
==== "/Users/johngriffith/Downloads/self timer-1009958.jpg" ====
---- ExifTool ----
ExifTool Version Number : 9.39
---- System ----
File Name : self timer-1009958.jpg
Directory : /Users/johngriffith/Downloads
File Size : 87 kB
File Modification Date/Time : 2013:12:14 11:37:38-08:00
File Access Date/Time : 2013:12:14 11:38:25-08:00
File Inode Change Date/Time : 2013:12:14 11:37:38-08:00
File Permissions : rw-r--r--
---- File ----
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Current IPTC Digest : 370a6a2aae30783523f548d96cd3cf1e
Image Width : 600
Image Height : 401
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:4:4 (1 1)
---- IFD0 ----
Make : Leica Camera AG
Camera Model Name : LEICA M (Typ 240)
X Resolution : 300
Y Resolution : 300
Resolution Unit : inches
Software : Adobe Photoshop Lightroom 5.0 (Macintosh)
Modify Date : 2013:12:11 13:50:08
---- ExifIFD ----
Exposure Time : 1/2000
F Number : 2.4
Exposure Program : Manual
ISO : 200
Exif Version : 0230
Date/Time Original : 2013:12:11 07:58:58
Create Date : 2013:12:11 07:58:58
Shutter Speed Value : 1/2000
Aperture Value : 2.4
Exposure Compensation : 0
Max Aperture Value : 1.0
Metering Mode : Center-weighted average
Light Source : Unknown
Flash : No Flash
Focal Length : 50.0 mm
Color Space : sRGB
Focal Plane X Resolution : 1653.333344
Focal Plane Y Resolution : 1653.333344
Focal Plane Resolution Unit : cm
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Manual
White Balance : Auto
Digital Zoom Ratio : 0
Scene Capture Type : Standard
Contrast : Normal
Saturation : Normal
Sharpness : Normal
Image Unique ID : 00000000000000000000000000104567
Serial Number : 4714557
Lens Model : Noctilux-M 1:1/50
---- GPS ----
GPS Version ID : 2.2.0.0
GPS Altitude Ref : Above Sea Level
GPS Altitude : 0 m
GPS Status : Measurement Void
GPS Dilution Of Precision : 0
GPS Speed : 0
GPS Track : 0
---- Photoshop ----
X Resolution : 300
Displayed Units X : inches
Y Resolution : 300
Displayed Units Y : inches
---- IPTC ----
Coded Character Set : UTF8
Application Record Version : 4
Date Created : 2013:12:11
Time Created : 07:58:58
Digital Creation Date : 2013:12:11
Digital Creation Time : 07:58:58
---- ICC-header ----
Profile CMM Type : Lino
Profile Version : 2.1.0
Profile Class : Display Device Profile
Color Space Data : RGB
Profile Connection Space : XYZ
Profile Date Time : 1998:02:09 06:49:00
Profile File Signature : acsp
Primary Platform : Microsoft Corporation
CMM Flags : Not Embedded, Independent
Device Manufacturer : IEC
Device Model : sRGB
Device Attributes : Reflective, Glossy, Positive, Color
Rendering Intent : Perceptual
Connection Space Illuminant : 0.9642 1 0.82491
Profile Creator : HP
Profile ID : 0
---- ICC_Profile ----
Profile Copyright : Copyright © 1998 Hewlett-Packard Company
Profile Description : sRGB IEC61966-2.1
Media White Point : 0.95045 1 1.08905
Media Black Point : 0 0 0
Red Matrix Column : 0.43607 0.22249 0.01392
Green Matrix Column : 0.38515 0.71687 0.09708
Blue Matrix Column : 0.14307 0.06061 0.7141
Device Mfg Desc : IEC Welcome to the IEC - International Electrotechnical Commission
Device Model Desc : IEC 61966-2.1 Default RGB colour space - sRGB
Viewing Cond Desc : Reference Viewing Condition in IEC61966-2.1
Luminance : 76.03647 80 87.12462
Technology : Cathode Ray Tube Display
Red Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
Green Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
Blue Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
---- ICC-view ----
Viewing Cond Illuminant : 19.6445 20.3718 16.8089
Viewing Cond Surround : 3.92889 4.07439 3.36179
Viewing Cond Illuminant Type : D50
---- ICC-meas ----
Measurement Observer : CIE 1931
Measurement Backing : 0 0 0
Measurement Geometry : Unknown (0)
Measurement Flare : 0.999%
Measurement Illuminant : D65
---- XMP-x ----
XMP Toolkit : Adobe XMP Core 5.5-c002 1.148022, 2012/07/15-18:06:45
---- XMP-xmp ----
Creator Tool : Adobe Photoshop Lightroom 5.0 (Macintosh)
Modify Date : 2013:12:11 13:50:08+10:30
Metadata Date : 2013:12:11 13:50:08+10:30
---- XMP-aux ----
Lens : Noctilux-M 1:1/50
---- XMP-photoshop ----
Date Created : 2013:12:11 07:58:58
---- XMP-xmpMM ----
Document ID : xmp.did:cbccd1bb-f04a-40ea-9788-9853dc9623c3
Original Document ID : 30303030303030303030313034353637
Instance ID : xmp.iid:cbccd1bb-f04a-40ea-9788-9853dc9623c3
History Action : derived, saved, derived, saved, converted, derived, saved
History Parameters : saved to new location, converted from image/dng to image/jpeg, saved to new location, from image/jpeg to image/dng, converted from image/dng to image/jpeg, saved to new location
History Instance ID : xmp.iid:a96ed8d3-36a9-42a7-aed5-fc5c08543831, xmp.iid:0ede9258-5eef-4957-b3b9-23e9f65df5c3, xmp.iid:cbccd1bb-f04a-40ea-9788-9853dc9623c3
History When : 2013:12:11 13:48:58+10:30, 2013:12:11 13:50:08+10:30, 2013:12:11 13:50:08+10:30
History Software Agent : Adobe Photoshop Lightroom 5.0 (Macintosh), Adobe Photoshop Lightroom 5.0 (Macintosh), Adobe Photoshop Lightroom 5.0 (Macintosh)
History Changed : /, /, /
Derived From Instance ID : xmp.iid:0ede9258-5eef-4957-b3b9-23e9f65df5c3
Derived From Document ID : xmp.did:0ede9258-5eef-4957-b3b9-23e9f65df5c3
Derived From Original Document ID: 30303030303030303030313034353637
---- XMP-dc ----
Format : image/jpeg
---- Adobe ----
DCT Encode Version : 100
APP14 Flags 0 : [14]
APP14 Flags 1 : (none)
Color Transform : YCbCr
---- Composite ----
Aperture : 2.4
Date/Time Created : 2013:12:11 07:58:58
Digital Creation Date/Time : 2013:12:11 07:58:58
GPS Altitude : 0 m Above Sea Level
Image Size : 600x401
Scale Factor To 35 mm Equivalent: 9.9
Shutter Speed : 1/2000
Circle Of Confusion : 0.003 mm
Field Of View : 4.2 deg
Focal Length : 50.0 mm (35 mm equivalent: 495.6 mm)
Hyperfocal Distance : 343.65 m
Light Value : 12.5
However, the DNG you sent me must be a mistake as it is an M9 file and here is the EXIF for it:
==== "/Users/johngriffith/Downloads/L1009958.dng" ====
---- ExifTool ----
---- System ----
File Name : L1009958.dng
File Size : 7.2 MB
File Modification Date/Time : 2013:12:14 11:24:05-08:00
File Access Date/Time : 2013:12:14 11:44:41-08:00
File Inode Change Date/Time : 2013:12:14 11:26:26-08:00
---- File ----
File Type : DNG
MIME Type : image/x-adobe-dng
---- IFD0 ----
Subfile Type : Reduced-resolution image
Image Width : 256
Image Height : 170
Bits Per Sample : 8 8 8
Compression : Uncompressed
Photometric Interpretation : RGB
Camera Model Name : M9 Digital Camera
Strip Offsets : 14512
Orientation : Horizontal (normal)
Samples Per Pixel : 3
Rows Per Strip : 170
Strip Byte Counts : 130560
Planar Configuration : Chunky
Software : Adobe Photoshop Lightroom 3.4.1
Modify Date : 2012:11:09 01:25:50
Self Timer Mode : 0
DNG Version : 1.3.0.0
DNG Backward Version : 1.1.0.0
Unique Camera Model : M9 Digital Camera
Color Matrix 1 : 0.7181 -0.1706 -0.0055 -0.3557 1.1409 0.245 -0.0621 0.2072 0.7533
Color Matrix 2 : 0.6627 -0.1079 -0.0498 -0.3949 1.2122 0.2043 -0.1492 0.3123 0.6574
Camera Calibration 1 : 1 0 0 0 1 0 0 0 1
Camera Calibration 2 : 1 0 0 0 1 0 0 0 1
Analog Balance : 1 1 1
As Shot Neutral : 0.496094 1 0.74466
Baseline Exposure : -0.5
Baseline Noise : 1
Baseline Sharpness : 1
Linear Response Limit : 1
Camera Serial Number : 4207314
Shadow Scale : 1
Maker Note Safety : Safe
Calibration Illuminant 1 : Standard Light A
Calibration Illuminant 2 : D65
Raw Data Unique ID : E011E7E308283D78ED8A56E4C8964899
Camera Calibration Sig : com.adobe
Profile Calibration Sig : com.adobe
Profile Name : Embedded
Profile Embed Policy : Allow Copying
Preview Application Name : Adobe Photoshop Lightroom
Preview Application Version : 3.4.1
Preview Settings Digest : 137bbe7c8d3e67d72112580befe1f916
Preview Color Space : 2
Preview Date Time : 2012:11:09 01:25:50+10:30
Raw Image Digest : b358a48a3dba0b513e0e1c35a0f3d979
Noise Profile : 3.58098725871672e-05 4.9286629084442e-07
---- SubIFD ----
Subfile Type : Full-resolution Image
Image Width : 5216
Image Height : 3472
Bits Per Sample : 8
Compression : JPEG
Photometric Interpretation : Color Filter Array
Samples Per Pixel : 1
Tile Width : 352
Tile Length : 352
Tile Offsets : (Binary data 1182 bytes, use -b option to extract)
Tile Byte Counts : (Binary data 899 bytes, use -b option to extract)
CFA Repeat Pattern Dim : 2 2
CFA Pattern 2 : 0 1 1 2
CFA Plane Color : Red,Green,Blue
CFA Layout : Rectangular
Linearization Table : (Binary data 1244 bytes, use -b option to extract)
Black Level Repeat Dim : 1 1
Black Level : 54
White Level : 16383
Default Scale : 1 1
Default Crop Origin : 2 2
Default Crop Size : 5212 3468
Bayer Green Split : 500
Anti Alias Strength : 1
Best Quality Scale : 1
Active Area : 0 0 3472 5216
---- SubIFD1 ----
Image Width : 1024
Image Height : 681
Compression : JPEG
Photometric Interpretation : YCbCr
Preview Image Start : 145072
Rows Per Strip : 681
Preview Image Length : 53148
Y Cb Cr Coefficients : 0.299 0.587 0.114
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
Y Cb Cr Positioning : Co-sited
Reference Black White : 0 255 128 255 128 255
---- XMP-x ----
XMP Toolkit : Adobe XMP Core 5.2-c004 1.136881, 2010/06/10-18:11:35
---- XMP-xmp ----
Creator Tool : Adobe Photoshop Lightroom 3.4.1
Modify Date : 2012:11:09 01:25:50+10:30
Create Date : 2012:11:07 09:22:05
Metadata Date : 2012:11:09 01:25:50+10:30
---- XMP-aux ----
Lens : Leica Noctilux-M 50mm f/1
Lens ID : 31
Date Created : 2012:11:07 09:22:05
---- XMP-crs ----
Has Crop : False
---- ExifIFD ----
Exposure Time : 1/180
F Number : 1.0
ISO : 200
Exif Version : 0230
Date/Time Original : 2012:11:07 09:22:05
Shutter Speed Value : 1/180
Exposure Compensation : -0.332
Light Source : Flash
Flash : No Flash
Focal Plane X Resolution : 3700
Focal Plane Y Resolution : 3689
Focal Plane Resolution Unit : inches
White Balance : Manual
Focal Length In 35mm Format : 50 mm
Image Unique ID : 000000000000000000000000000012FA
Lens Model : Leica Noctilux-M 50mm f/1
---- Leica ----
Leica Subdir 0x3001 : 0
Contrast : Normal
Sharpening : Normal
Leica Subdir 0x300c : 0
Saturation : Normal
Leica Subdir 0x300e : 1
Leica Subdir 0x300f : 1
Leica Subdir 0x3032 : 36241 16384 19579
White Balance : Flash
JPEG Quality : Fine
Leica Subdir 0x3035 : 0
WB RGB Levels : 0.4960939866 1 0.7446595764
Leica Subdir 0x3037 : 4294967295
User Profile :
Leica Subdir 0x3039 : 0
JPEG Size : 5216x3472
Leica Subdir 0x3104 : 03739206000000
Leica Subdir 0x3105 : 03739206000000
Leica Subdir 0x3107 : 4H205807227800
Firmware Version : 1.162
Leica Subdir 0x310b :
Leica Subdir 0x310c : 02
Leica Subdir 0x310d : 02
Leica Subdir 0x310e : 11
Leica Subdir 0x310f : 0
Base ISO : 160
Sensor Width : 5270
Sensor Height : 3516
Sensor Bit Depth : 14
Camera Temperature : 0 C
Leica Subdir 0x3403 : 0.03726
Lens Type : Noctilux-M 50mm f/1
Approximate F Number : 0.0
Measured LV : -1.65
External Sensor Brightness Value: 0.00
Leica Subdir 0x3409 : 1
Leica Subdir 0x340a : 61 62
Leica Subdir 0x340b : 0
Leica Subdir 0x340c : 0
Leica Subdir 0x340d : 0
Leica Subdir 0x3903 : ..n.F.¬.Ô.g...¤.Ø.{.¡.{.-.Y.µ.®a.ÝÁ}.ÄßÑ.#.ù.ñ.J.¾[...]
Leica Subdir 0x3904 : 1
---- Composite ----
Aperture : 1.0
Blue Balance : 0.74466
CFA Pattern : [Red,Green][Green,Blue]
Image Size : 5216x3472
Lens ID : Leica Noctilux-M 50mm f/1
Preview Image : (Binary data 53148 bytes, use -b option to extract)
Red Balance : 0.496094
Scale Factor To 35 mm Equivalent: 1.0
Shutter Speed : 1/180
Circle Of Confusion : 0.030 mm
Field Of View : 39.6 deg
Focal Length : 50.0 mm (35 mm equivalent: 50.0 mm)
Hyperfocal Distance : 83.21 m
Light Value : 6.5
You should notice in the DNG file, the self timer mode is captured. In the above it was = 0. Please send me three DNG files. One with self timer shot set to 2 sec, one with self timer off and set to single shot and one with switch sent to Continuous so we can see the respective field values. They should all be from M240.
Edited by barjohn
