135 Elmarit with Goggles on M(240)
fsprow
Does anyone know if the goggles can be removed on this lens, which I have and like, so it can be used with the EVF?
Why do you assume the goggles had to be removed in order to be able to it with EVF?
It is hard to see why they should be removed, but if I recall correctly, it is a matter of two screws...And you would destroy the alignment.
It would be simpler to get an R 135/2.8 which is the same lens, but unbeloved and not too expensive.
The goggles make part of the focus mount on my sample # 11829 so no way to remove them w/o dismantling the focus mount IMHO.
See below the lens head, the regular focus mount and the 16462 short mount Luigi was referring to above.
