ryee3 Posted March 27, 2013 Share #1 Â Posted March 27, 2013 Advertisement (gone after registration) Are there adapters available to fit R lenses on a Hasselblad digital camera? I am happy with R lenses on a digital Canon for action photos applications etc but for macro photo applications, the image quality is not as good as what I perceive I am able to get on the DMR? Link to post Share on other sites More sharing options...
Advertisement Posted March 27, 2013 Posted March 27, 2013 Hi ryee3, Take a look here R lenses on Hasselblad digital format. I'm sure you'll find what you were looking for!
mmradman Posted March 27, 2013 Share #2 Â Posted March 27, 2013 Never used medium format Hasselblad but i am certain that it will not going to work. Â First registry distance is much bigger on H-blad than Leica R and second image circle of R lenses is optimised for 24x36mm negative, i.e. small, very small for MF - it would be like putting micro four/third format lenses on full frame camera. Link to post Share on other sites More sharing options...
earleygallery Posted March 27, 2013 Share #3 Â Posted March 27, 2013 As above, it's not possible. Link to post Share on other sites More sharing options...
tobey bilek Posted March 28, 2013 Share #4 Â Posted March 28, 2013 Generally not possible, however a custom made adapter might be made to allow working in the close range only where the image circle is larger. Then there is a problem with the design parameters of the lens not allowing for such close focus to be optimum. Â I would advise the best solution is a canon body and adapter for R lenses. Link to post Share on other sites More sharing options...
pico Posted March 28, 2013 Share #5 Â Posted March 28, 2013 Even if you did have an adapter to fit R lens to a V Hasselblad body, you would be limited to using the rear curtain as a shutter (the flaps in front of the film magazine) which is a fixed speed. Link to post Share on other sites More sharing options...
Michael Geschlecht Posted March 29, 2013 Share #6 Â Posted March 29, 2013 Hello ryee3, Â For macrophotography: You might try getting a detachable lens head from a 135mm Hektor 4.5 & a focussing mount or bellows for it. Use that with an appropriate adapter for the Hasselblad or use the detachable lens head alone with a Novoflex adapter for a Hasselblad bellows. Â Don't forget a 12575 lens hood. Proper lens hoods often make a big difference in macro-photography. Â The 135mm Hektor 4.5 was originally designed to cover a larger format than the Leica's 24mm X 36mm. Â Don't forget to stop it down for use after focussing at full aperture. You might experiment with different F stops beginning at F 11. Â Best Regards, Â Michael Link to post Share on other sites More sharing options...
tobey bilek Posted March 29, 2013 Share #7 Â Posted March 29, 2013 Advertisement (gone after registration) I have used 135 and 90 long focus designs on 4x5 and they cover 3/4 or more of the film. Do not use tele designs like tele elmar. They will not work. Â I forgot about the shutter issue. Link to post Share on other sites More sharing options...
