IWC Doppel Posted January 14, 2013 Share #1 Posted January 14, 2013 Advertisement (gone after registration) I have a friend with an M8 (I had an M8 and now an M9, I have not experienced any shutter problems) Basically he took a picture and it coughed, beeped a few times and displayed some errors on the screen. First one was something like 'drive blocked' followed by 'shutter fault'. It was evidently cold outside but not that cold, maybe around 2 degrees C. Finally just switching the on/off switch around through all the settings, when he switched it to 'timer' it recocked and has been fine since. Any advice or idea ? Tks Link to post Share on other sites More sharing options...
Advertisement Posted January 14, 2013 Posted January 14, 2013 Hi IWC Doppel, Take a look here M8 shutter problems. I'm sure you'll find what you were looking for!
pop Posted January 15, 2013 Share #2 Posted January 15, 2013 I'd suspect the battery. My reasoning is that cocking the shutter draws a largish amount of current. An elderly battery which is not freshly loaded might suffer a drop in voltage at lower temperatures which in turn would prompt the computer in the camera to produce error messages. Link to post Share on other sites More sharing options...
jaapv Posted January 15, 2013 Share #3 Posted January 15, 2013 Two degrees is close to the lower limit of the temperature range. If the camera was allowed to come to ambient temperature, the battery capacity would certainly have been significantly diminished, possibly enough to drop below operating capacity during the shutter sequence, especially on an older battery. Link to post Share on other sites More sharing options...
lct Posted January 15, 2013 Share #4 Posted January 15, 2013 Yes comes from the battery probably but i would check if the firmware is up-to-date as well since discreet and continuous modes did cause some shutter problems between firmware updates 2.004 and 2.005 (or 2.014) if i recall correctly. Link to post Share on other sites More sharing options...
LucisPictor Posted January 15, 2013 Share #5 Posted January 15, 2013 Two degrees is close to the lower limit of the temperature range. If the camera was allowed to come to ambient temperature, the battery capacity would certainly have been significantly diminished, possibly enough to drop below operating capacity during the shutter sequence, especially on an older battery. I have recently used my M8 at -5°C without any issues. Link to post Share on other sites More sharing options...
jaapv Posted January 16, 2013 Share #6 Posted January 16, 2013 Quite possible. The outside temperature is not relevant - the temperature inside the battery cells is what matters. There are variables - was your camera cold through and through? - the battery sits in the middle.- That will take quite some time. Did you keep it under your coat ? That will keep it warmish. Was your battery in optimum condition? That makes quite a difference. Etc. Link to post Share on other sites More sharing options...
Mr_Jones Posted January 17, 2013 Share #7 Posted January 17, 2013 Advertisement (gone after registration) I've had repeated problems with the shutter re-cocking in cold environments. Usually needs a few minutes in a bag or under a jacket to recover. I've recently had the problem with a new fully charged battery, previously I thought it was a battery fault as the older the battery the more cold seems to affect it. Link to post Share on other sites More sharing options...
robsteve Posted January 21, 2013 Share #8 Posted January 21, 2013 I've had repeated problems with the shutter re-cocking in cold environments. Usually needs a few minutes in a bag or under a jacket to recover. I've recently had the problem with a new fully charged battery, previously I thought it was a battery fault as the older the battery the more cold seems to affect it. I had that problem and just lived with it for a while. I sent it to Leica last month, noting the problem and they fixed it charging the standard CLA rate. Link to post Share on other sites More sharing options...
IWC Doppel Posted January 21, 2013 Author Share #9 Posted January 21, 2013 I had that problem and just lived with it for a while. I sent it to Leica last month, noting the problem and they fixed it charging the standard CLA rate. Do you know much the standard CLA rate is ? Link to post Share on other sites More sharing options...
robsteve Posted January 22, 2013 Share #10 Posted January 22, 2013 Do you know much the standard CLA rate is ? It depends where you send it, but I think it is about 475 euros (SOLMS) or dollars (Leica NJ). I made the mistake of sending mine to SOLMs and it was more expensive than sending to Leica NJ because of the exchange rate. Link to post Share on other sites More sharing options...
designed Posted February 8, 2013 Share #11 Posted February 8, 2013 I had the same issue when operating the camera at -20°C. First the recock started to be late which caused the "drive blocked" messages, then they changed to "shutter fault" but the camera still soldiered on. After 20 minutes the shutter finally stopped moving, but it recovered quickly inside the house. I've had the camera in a CLA since then, but I have also avoided shooting the Leica at those temperatures. Link to post Share on other sites More sharing options...
-Lss- Posted February 9, 2013 Share #12 Posted February 9, 2013 Those temperatures are pretty common around here. I have never experienced any mechanical issues on my M8 (or any other camera) in winter use, but battery life sure takes a hit in cold. Link to post Share on other sites More sharing options...
