Loose aperture ring? On new 35mm 1.4 Summilux
JCharlton
I just received a brand new Leica M-35mm/f1.4 ASPH Summilux-M, and I'm curious if this is normal behavior. Right around the 1.4 setting, there seems to be a two click stops - as you can see from the video, no other aperture stops do that. I only have a few days to return the lens if needed, so please advise.
Best,
Justin
Video: https://vimeo.com/55897509
Please forgive the beginning and jump to 20 second mark for the demonstration.
Best,
Justin
I have the FLE and it does the same thing at 1.4. From what I understand this is normal behavior for many Leica lenses. No need to worry!
A lot of lenses do that, don't worry.
It wouldn't be much of a concern if my Leica 50mm f/1.4 Summilux-M Aspherical did the same. So is it this particular lens that functions like this or a defect in my unit or design, I wonder.
Well, I'm determined to find out for myself. I've ordered a second lens and will compare the aperture ring performance on the two. Spent 5K on a single lens, was hoping for better hardware construction than my $1200 Zeiss Distagon. I will have an update later this week.
It's not a construction issue, as far as I can tell. See other people asking the same here 35mm summilux aperture ring question (FLE version) - The GetDPI Photography Forums
Not a fault, not a 'construction issue', many lenses (most lenses) do this. I have a Zuiko lens next to me right now, it moves a tad past both ends of the scale.
Do you think it's worth returning or sending into Leica for them to look at it? Maybe it can be tightened. A bit frustrating, as the spot where there is play in the ring, happens to be at the point of full 1.4 aperture, so it's easy to accidentally bump down the aperture a bit when focusing. :(
Do you think it's worth returning or sending into Leica for them to look at it?...
If there is some play in the ring yes but rotating past the widest mark is normal for many lenses and won't change the actual aperture in any way.
The aperture doesn't change in that last little bit. It is normal on many lenses. Don't worry.
I don't understand why you're frustrated... everyone says it's normal. The lens is 1.4 not 1.3 or 1.2, so you can't "accidentally bump down the aperture." If you'd like, send it into Leica for them to tell you there's nothing wrong.
Hmm... It's not necessarily rotating past the 1.4 aperture, if anything, it's tending to rotate in a bit, just to where the aperture blades begin to show. As I've said, I've ordered another copy and will compare the two on Friday and upload a video if there is a significant difference. I do appreciate all the answers, though!
Update: After receiving a second copy of the lens, I can confirm that it behaves very similar around the 1.4 mark. Whew! Good to finally have closure on the topic. Thanks for all the helpful, and some humorous, responses.
