Summaron on M8 , what IR/UV filter options?
due163
Hi all
I bought a great condition Summaron 35/3,5 and its awesome, and it takes fantastic B+W ., but Id liek to use a filter to take colour shots too
What options do I have for a A36 IR/UV filter?
just the Leica SOOGZ?
http://www.l-camera-forum.com/leica-wiki.en/index.php/SOOGZ
If you can't find one of those you could buy any A36 filter, any IR/UV filter, remove the filter from the ring and cut it down to fit into the A36 filter mount.
Please suggest how one would cut down a glass filter. My 60 mm Leica is plastic, but have no Leics in smaller size. My B+W appear to be glass, but not sure.
Besides earlygallery's cutting-down option and the obvious SOOGZ-solution I see only two chances:
1. swap your A36-version of the Summaron to the newer version with E 39.
2. the black part of the lenses front should have a filter-mount with small diameter. If you measure it, you could ask at Foto Huppert http://www.foto-huppert.de/default2.asp
if B+W makes an UV/IR-Filter with this size on demand for you. They have done this before, though I am not sure if they would do so now with IR-Cut-Filters.
  • 1 month later...
Hi all
I ended up buying a vintage A36> summitar ring and then a new Summitar>E39 ring
total cost was under 40 bucks including shipping for both , Im eagerly awaiting the last ring to try it out
Happy New Year
