cbretteville Posted March 14, 2007 Author Share #21 Â Posted March 14, 2007 Advertisement (gone after registration) Thanks guys! Â I picked the viso apart and removed the washer. Quite a nicely made one actually. The screws are longer and in brass, infortuneatly the threading dosen't go all the way up so I can't just replace them. One ball is missing and the springs have been modified so they will need to be replaced too. Â I'll try the focusing on my M8 later today, just to see if things are as they should now. It looked much better when I tested it off camera last night after removing the washer. Â @ Jan: if you have the specs on the screws I'd appreciate the data. Â - Carl Link to post Share on other sites More sharing options...
Advertisement Posted March 14, 2007 Posted March 14, 2007 Hi cbretteville, Take a look here Help! 135 Tele-elmar on Viso III - no infinity focus. I'm sure you'll find what you were looking for!
luigi bertolotti Posted March 14, 2007 Share #22  Posted March 14, 2007 Thanks for helping! Here are a bunch of q&d shots - Carl  [ATTACH]29495[/ATTACH] [ATTACH]29496[/ATTACH] [ATTACH]29497[/ATTACH] [ATTACH]29498[/ATTACH] [ATTACH]29499[/ATTACH]  Carl, I have not read all the posts regarding the Viso, BUT seems to me to notice something in the Tele Elmar HEAD: there is a small flange at the BACK END of the lens unit: SEEMS TO ME (NOT 100% sure, but I remember something in Lager book, do not have it HERE) it can be UNSCREWED, and maybe this is the cause of "limited intruding" of the lens unit into the OTZFO/VISO. I am going to my memory... maybe others TE had NOT that flange... Lager explained why... My own TE has it... can be unscrewed-screwed again with no sort of risk... TRY... Link to post Share on other sites More sharing options...
cbretteville Posted March 14, 2007 Author Share #23 Â Posted March 14, 2007 Luigi, thanks - I'll check it out when I get home. Â - Carl Link to post Share on other sites More sharing options...
jc_braconi Posted March 14, 2007 Share #24  Posted March 14, 2007 Carl, For information, I just tried the same mounting and it works from 1 meter to infinity is your viso III a scientific one ?  Cheers jc Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/18740-help-135-tele-elmar-on-viso-iii-no-infinity-focus/?do=findComment&comment=200634'>More sharing options...
cbretteville Posted March 14, 2007 Author Share #25 Â Posted March 14, 2007 JC, I have no idea. It wasn't listed as such. - Carl Link to post Share on other sites More sharing options...
doubice Posted March 14, 2007 Share #26  Posted March 14, 2007 Carl,  Yours is not the scientific Visoflex version, it was simply modified for some special purpose. Also, the flange that Luigi is referring to is a light baffle which was only installed on some early Tele-Elmars. It would be in the way when mounting the head onto the 16464 and can be easily pulled of - it was just a friction fit. However, by this time many of these flanges were lost as their purpose was questionable.  Details of the screw:  Length incl. Head:.......9mm Head Height:................1.5mm Thread diameter:.........2mm Head Diameter:...........3mm  All the best,  Jan Link to post Share on other sites More sharing options...
Rona!d Posted March 14, 2007 Share #27 Â Posted March 14, 2007 Advertisement (gone after registration) The "official" scientific Viso III looks different, Carl has a standard Viso which had been modified, as mentioned before. Link to post Share on other sites More sharing options...
cbretteville Posted March 14, 2007 Author Share #28 Â Posted March 14, 2007 Thanks Jan! The screws on mine are 12mm long so I'll timply try cutting 3mm off. Theyre brass screws so they shouldn't be hard to cut with a Dremel.The rest of the measurements fit your specs. If that works I'll have to come up with a replacement for the spring loaded balls, if neccesary. Tests will show. Â Â - Carl Link to post Share on other sites More sharing options...
cbretteville Posted March 14, 2007 Author Share #29  Posted March 14, 2007 Thanks to all for helping out. Here are two test shots from the M8 showing real promise. Both shot using a tripod and UV/IR filters. These are just the in-camera JPEGs resized and gently sharpened using Photokit sharpener.  First one is with the 135 Tele-Elmar lenshead f4, 0.7sec, ISO160. Distance is about 1 meter.  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  Second one was shot with a 50 Elmar-M mounted directly on the viso. f5.6, 16sec, ISO160.   - Carl Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  Second one was shot with a 50 Elmar-M mounted directly on the viso. f5.6, 16sec, ISO160.   - Carl ' data-webShareUrl='https://www.l-camera-forum.com/topic/18740-help-135-tele-elmar-on-viso-iii-no-infinity-focus/?do=findComment&comment=201258'>More sharing options...
doubice Posted March 15, 2007 Share #30 Â Posted March 15, 2007 Hello Carl, Â Glad all worked out. Â Just out of interest - you posted your message at 3:49pm my time, which translates to 23:49 Oslo time. What are you doing up at close to midnight playing with Leicas?........... Â Cheers, Â Jan Link to post Share on other sites More sharing options...
luigi bertolotti Posted March 15, 2007 Share #31  Posted March 15, 2007 Luigi, thanks - I'll check it out when I get home. - Carl  Carl, I remembered right... tell me if You had this strange "baffle"... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/18740-help-135-tele-elmar-on-viso-iii-no-infinity-focus/?do=findComment&comment=201345'>More sharing options...
telewatt Posted March 15, 2007 Share #32 Â Posted March 15, 2007 Hello Liugi, Â the"baffle" is "important" for using with the original mount, but on the visoflex you can't use it, it do not fit... Â regards, Jan Link to post Share on other sites More sharing options...
telewatt Posted March 15, 2007 Share #33  Posted March 15, 2007 Hello Carl,  the first one is realy nice... ..I love the head of the lense it is so fantastic and the "fingerprint" is great..  regards, Jan  ..and sorry for not seeing the "big Washer"... ..I only saw very thin washers for calibration on some Visoflex.....but ronald did a good job.. Link to post Share on other sites More sharing options...
luigi bertolotti Posted March 16, 2007 Share #34  Posted March 16, 2007 Hello Liugi, the"baffle" is "important" for using with the original mount, but on the visoflex you can't use it, it do not fit...  regards, Jan  Thanks, Jan, you're right: I just had wondered if a maybe "no removal" of the "maybe existent" baffle could have caused a limited intrusion of the TE head into the Viso focusing adapter (14464), that in turn could have brought the impossibilty to focus at infinity, that was the original problem of our Norwegian friend... these kind of threads are fun a lot for we lovers of old fashioned equipment... yesterday night I tried to screw my TE head with baffle UNREMOVED onto the 16464... you cannot ever reach an initial coupling of the two screws of 16464 and lens head... it stops before against the 16464 inner.  Bye Luigi Link to post Share on other sites More sharing options...
