mbarzegar Posted May 8, 2012 Share #1 Â Posted May 8, 2012 Advertisement (gone after registration) I am looking at buying a used M8 and need to determine the shutter count. The seller does not know as he bought it used. The latest picture shot on the camera was assigned L9997077.jpg by the camera. I am having a hard time determining which part of this file name is the folder name and which part is the hexadecimal number that needs to be converted. Any ideas? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted May 8, 2012 Posted May 8, 2012 Hi mbarzegar, Take a look here M8 Shutter Actuation Count. I'm sure you'll find what you were looking for!
lct Posted May 8, 2012 Share #2 Â Posted May 8, 2012 Welcome to the forum. If it is an original file, just drop it on the M8Info icon. Link to post Share on other sites More sharing options...
mbarzegar Posted May 8, 2012 Author Share #3 Â Posted May 8, 2012 Thanks! It's great to be part of this forum! Thanks for the link. I installed the application but when I drag the file onto the open window of the application it says it is not a valid file. I am wondering what might be causing this? Perhaps the memory card was not formatted properly and has some data from before. Link to post Share on other sites More sharing options...
jaapv Posted May 8, 2012 Share #4 Â Posted May 8, 2012 Mac or PC? Â Btw, the hex unique image ID is not in the file name, but in the EXIF file. Link to post Share on other sites More sharing options...
mbarzegar Posted May 8, 2012 Author Share #5 Â Posted May 8, 2012 Thanks Jaap! I use a Mac. I used an Exif viewer. The only data that might be relevant is the following: EXIF Version {0x9000} 0220. Is this the image id? I can't find any other field labeled image id. If so, then I presume I need to convert 220 from hexadecimal which would be 544 in decimal. Link to post Share on other sites More sharing options...
jaapv Posted May 8, 2012 Share #6 Â Posted May 8, 2012 You need to use the original file and convert from raw and save. It is not very relevant, as any shutter problem that might arise (not very likely, but possible) is not related to shutter count. There have counts of over 300.000 reported in this forum. If the camera is clean and not worn it is unlikely to have gone past 10.000 anyway. Link to post Share on other sites More sharing options...
lct Posted May 8, 2012 Share #7 Â Posted May 8, 2012 Advertisement (gone after registration) ...I installed the application but when I drag the file onto the open window of the application it says it is not a valid file. I am wondering what might be causing this?... Usually caused by the fact that your jpeg file is not a original one. You need a raw file or a jpeg direct out of the camera. Feel free to send me your file to lctphot at aol dot com an i'll see what i can do. Link to post Share on other sites More sharing options...
mbarzegar Posted May 8, 2012 Author Share #8 Â Posted May 8, 2012 Thanks Jaap. Good point about camera condition itself. I will find out later today. Link to post Share on other sites More sharing options...
mbarzegar Posted May 8, 2012 Author Share #9 Â Posted May 8, 2012 Usually caused by the fact that your jpeg file is not a original one. You need a raw file or a jpeg direct out of the camera. Feel free to send me your file to lctphot at aol dot com an i'll see what i can do. Â Thanks ICT. I will email it to you. Appreciate your looking into it!! Best, Mo Link to post Share on other sites More sharing options...
mbarzegar Posted May 9, 2012 Author Share #10 Â Posted May 9, 2012 Usually caused by the fact that your jpeg file is not a original one. You need a raw file or a jpeg direct out of the camera. Feel free to send me your file to lctphot at aol dot com an i'll see what i can do. Â Tried sending the file to your email but was bounced back by AOL. Link to post Share on other sites More sharing options...
lct Posted May 9, 2012 Share #11 Â Posted May 9, 2012 Even in zip format? If so you might wish to send it through Yousendit for free (https://www.yousendit.com/). Link to post Share on other sites More sharing options...
mbarzegar Posted May 9, 2012 Author Share #12 Â Posted May 9, 2012 Even in zip format? If so you might wish to send it through Yousendit for free (https://www.yousendit.com/). Â I just zipped it (2MB) and tried AOL again. If it bounces again, I will use the other one. Thanks again! Link to post Share on other sites More sharing options...
mbarzegar Posted May 11, 2012 Author Share #13 Â Posted May 11, 2012 Even in zip format? If so you might wish to send it through Yousendit for free (https://www.yousendit.com/). Â I sent it to you via Yousendit. I would appreciate it if you could take a look and give me your opinion. Thanks!! Link to post Share on other sites More sharing options...
lct Posted May 11, 2012 Share #14 Â Posted May 11, 2012 Haven't received it i'm afraid. Did you get a link from Yousendit? Link to post Share on other sites More sharing options...
mbarzegar Posted May 12, 2012 Author Share #15 Â Posted May 12, 2012 Haven't received it i'm afraid. Did you get a link from Yousendit? Â No worries. Thanks Jaap. I passed on the camera after inspecting it. Bought a mint used M9 instead! Link to post Share on other sites More sharing options...
mbarzegar Posted May 12, 2012 Author Share #16 Â Posted May 12, 2012 No worries. Thanks Jaap. I passed on the camera after inspecting it. Bought a mint used M9 instead! Â Sorry! I meant ICT not Jaap!! Link to post Share on other sites More sharing options...
jaapv Posted May 12, 2012 Share #17 Â Posted May 12, 2012 Congratulations on a wise decision nevertheless. Link to post Share on other sites More sharing options...
jdlaing Posted May 13, 2012 Share #18 Â Posted May 13, 2012 On the m8.2 I have I: Â Turn the camera on. Press the right arrow key 4 times. Press the left arrow key 3 times. Press the right arrow key 1 more time. Press the info button. Scroll down to body debug data. Press Set. Scroll down to NUMEXPOSURES. Â Turn camera off to exit........ Link to post Share on other sites More sharing options...
lct Posted May 13, 2012 Share #19 Â Posted May 13, 2012 Thank you! To know the lens ID and aperture estimated by the camera: Â Turn the camera on. Press the right arrow key 4 times. Press the left arrow key 3 times. Press the right arrow key 1 more time. Press the info button. Scroll down to "Sensor Test". Press Set. Turn camera off to exit. Link to post Share on other sites More sharing options...
jdlaing Posted May 13, 2012 Share #20 Â Posted May 13, 2012 Thank you! To know the lens ID and aperture estimated by the camera: Â Turn the camera on. Press the right arrow key 4 times. Press the left arrow key 3 times. Press the right arrow key 1 more time. Press the info button. Scroll down to "Sensor Test". Press Set. Turn camera off to exit. Â Link to post Share on other sites More sharing options...
