Leica lens on non Leica digital body - why?
stevelap
I hear the motherboard is fried.
How about this shot? Can you see the moiré in this one? This one is nasty upon both of my monitors.
  • Replies 78
  • Created
  • Last Reply
I have a question. I am shooting a 5d2 with an Elmarit 60 macro. In this image, are you seeing the moiré that I am seeing? I have a secondary "movie watching" samsung monitor that doesn't show the moiré... but the apple monitor sure does.
Second question: I am using a fotodiox chipped adapter. I just put it on yesterday and while reviewing some images, an Error 70 message came up and now the screen on the camera is fried. Would the chipped adapter do this?
Interesting. I have two calibrated displays.
On 2009, 17" PowerBook Pro I see quite a bit of moiré.
On 8 year old 30" Apple Cinema Display basically moiré free.
No moire on either image on my NEC PA or EIZO monitor. Do you see moire at 100% magnification?
Apart from the error (which I'm pretty sure also doesn't have anything to do with the adapter), how do you like the fotodiox adapter and which one are you using? The pro version or something else?
Wow... didn't this conversation just get funky?
So, is this elmarit macro out-resolving the 5d's sensor?
Fotodiox adapter holds the lens to the body well. The focus confirmation is iffy at the best of times. VERY hit and miss.... and yes it's the pro version.
This discussion is not correct.
In the picture examples the regular pattern fails. One becomes moire when a pattern of the "right" size interferes with the sensor pattern. And - of course - a sharp lens.
Jan
How do you call this then?
Using an LG IPS screen calibrated with EyeOne Match. No moire that I can detect on the first image, but very distinct on the second. Hm. I wonder what this actually says. Is it about the sensor-lens combination or simply LCD display quality?
I have seen that too (in the meantime). :)
What caused this moiré? I don't expect, that there is a structured surface in the original scene (the mannequin).
I have revolved the picture slightly using Photoshop. The moiré stayed. My theory was, that the regular bayer pattern of the sensor interfered with that of the monitor. Depending on the enlargement of the monitor picture. That would be comparable with the moiré, that could occur in the past by digital printing.
But there is no moiré outside the body.
Jan
According to Sfage it's a Canon pic thus with AA filter.
yeah, but did you enlarge the already re-sized post? You can't tell anything about that.
Not that Canons with an AA filter don't show moire. They do. So do Nikons, Fujis and everyone else's digital cameras (I have the bridesmaid's dress shots to prove it). And in all systems I've found it more or less rare--whether it's on an M8/DMR/M9/S2 (all AA-less) or a 1d2, 5d, 1ds2 or D3 (all with AA filtering).
But moire also shows up as a non-printable artefact when zooming into complex patterns on LCD screens or as the result of certain JPEG outputs (in which case they print fine :)) Both are different from moire happening at the camera level... and that's why I asked to see the original file, if it was available.
