Walter Mandler 90mm Elmar Triplet?
ncc1701
Can someone tell me if this is truly a triplet?
From what I know the knurled focus ring and 39mm thread suggest this is of Walter Mandler designed triplet.
It is also bayonet mount
But all Serial number lists suggest its made in 1962:
1 913 001-1 967 100: 1962
According to Erwin Puts it is made in 1964:
4/90mm, Elmar , 3-element lens, 1964.
This lens is a Canadian design and with only three single elements, a case-study of
optical simplicity. Its full aperture performance is better than that of the predecessor
with the classical 3 group/4 element construction. Overall contrast is a bit higher, the
definition of fine detail has improved edge contrast and especially the performance in
the field is much better. Vignetting is .7 stops. At 1:4 the contrast gets visibly higher
and now very fine detail is recorded over the whole image area with good clarity. The
Elmarit 1:2.8/90mm at 1: 4 cannot equal the 3-element Elmar here. Stopping down
further brings in finer detail and at 1:11 we find image quality of a thoroughly
modern level. This lens has been introduced at the same time as the Tele-Elmarit
1:2.8/90mm, which replaced the Elmarit 1:2.8/90mm. As the Tele-Elmarit could not
be used with the bellows attachment and had not the best performance at closer
distances, Leitz offered the Elmar as a lens for these applications. Close up
performance is quite good. Distortion is negligible. It does show the intriguing
strategy of fine tuning the lens performance for a specified set of tasks. It was not
possible in those days to create one general purpose lens and so Leitz optimised the
designs in different directions. A luxury that could not be extended indefinitely as it
was a costly strategy. With modern glasses, this lens would deliver a very interesting
performance.
Any insight would be appreciated?
I hope I am not violating any rules by quoting Puts?
If it truly is, What is the value of this lens in decent condition, not mint but pretty nice?
Thanks in advance.
x
Yes, this is the well known and still good Elmar 90 "3 elements", an item belonging to this batch :
1920001 1921000 Elmar 90 mm 1:4 (S+M) 1962 1000 (Puts - see our Wiki section)
The items in Screw mount are surely few. The less common of the Elmars 90, but not rare in bayonet mount... a quick look at ebay and some dealers' sites can give you an idea of its value.
We do not give any valuation on this Forum see sticky threads on top of this Forum.
Your lens is a genuine Elmar 4/90 - 3 Element
Ref # 6 SM #8 M
While we are at it, the following text portion as quoted from E. Puts has always puzzled me:
...Its full aperture performance is better than that of the predecessor
and now very fine detail is recorded over the whole image area with good clarity. ...
Full aperture performance is better ... At 1:4 the contrast gets visibly higher and ... Well, f4 IS the full aperture of this lens, so exactly when does the contrast gets visibly higher? From my own experience, the lens is already very good at full aperture, with just gradual improvements on stopping down.
And to the OP: Yes, your lens is a copy of the 3-element Elmar 90. Enjoy it, as it is even today a terrific 90mm lens, small and lightweight and very flare resistant.
Andy
My impression (after a working life in the publishing business) is that whatever his other virtues, Mr Puts does not check his texts after writing them. They are full of inadvertences like this one.
The old man from the Age of Proofreading (THAT was very long ago ...)
Hello Everybody,
The comparison of the 3 element 90mm F4 Elmar w/ the 90mm F2.8 Elmarit may also be read as: @ the image/object ratio of 1 : 4.
That is to say @ 1/4 life size, as on a bellows.
He later goes on to discuss the Tele-Elmarit as a lens which cannot be used on a bellows.
Best Regards,
Michael
Hello Everybody,
Best Regards,
Michael
Hi Micheal,
I thought about that, too, but believe that Puts, judging by the context, is in fact referring to f4. Otherwise his sentence would not make any sense. He starts his comments by referring to full aperture, then goes on to say how the lens improves on stopping down (f4 should maybe read f5.6), and finally mentions f11 (note that in Europe f-stops are also denoted as 1:2.8 etc., as evidenced by the engraving on the front ring of at least the older Leica lenses).
Best,
Andy
Hello Andy,
Thank you.
It is interesting. On re-reading the original Post it looks like it is a translation which can be read various ways.
On re-reading I think he was trying to say: The 3 element F4 is better @ F4 than the non-tele 90 F2.8 is @ F4 & that @ F11 the 3 element F4 is the equal of a modern lens. Also, separately, the 3 element F4 is a good close-up lens.
Best Regards,
Michael
I own this lens - and I think it is terrific. It is sharp, and the contrast is excellent. There is no vignetting that I can see in practice, which means I really like the pictures I get from it. I don't need larger apertures, I like the small size for traveling, and I have no incentive to buy a newer lens.
Hello ncc1701,
Welcome to the Forum.
btw: You might be interested to know you have been mentioned on this Forum on more than 1 occassion before your arrival.
In the photo showing the front of your lens there is a chrome plated lens cap on the left. Is the item on the right of the lens #'d 16467 or perhaps lettered OUAGO ?
Best Regards,
Michael
Yes it is the OUAGO!
I have been mentioned? hmm? Im assuming you are speaking of the Star trek reference, not actually me?
Thanks again for your replies!
This forum is an amazing asset to the RF community. I truly enjoy spending hours sifting through threads as I'm sure all of us do!
Kudo's to you all!
Thanks all for your insight!
How in your experiences does this lens compare to the 90/4 Elmar-C?
I will most likely keep this lens, it's in great shape and small!
On film, I preferred a lot the Elmar 3 elements (imho, the Elmar C wasn't in the same league as its brother Summicron C 40, expecially wide open) : on digital, never compared directly and Elmar C went sold in the meantime... :o; Elmar 90 3 elements' head, with OUAGO and/or other accessories (bellows etc.) , is my preferred tool for macro with M8+Viso 3
Elmar 90 3 elements' head, with OUAGO and/or other accessories (bellows etc.) , is my preferred tool for macro...
I agree completely! This set up is the best close-up facility I have ever used or seen - Visoflex 3 (or 2), Bellows 2, and 3 element Elmar 90.
Yup :)
...How in your experiences does this lens compare to the 90/4 Elmar-C?...
Sharpness and contrast are about the same I would say, but the most notable difference is vignetting at full aperture. While the 3-element version does not show any appreciable vignetting, the Elmar-C does so even at f5.6, needing f8 to avoid vignetting completely.
Andy
