apo summicron-M 90mm asph versus apo-telyt-M 3,4 /135 mm
Paulus
My question is if there are people who have used their Apo summicron-M 2/90mm asph and apo-telyt-M 3,4 135 mm for several years on a M6/MP or M9
Which one do they prefer and , very important, why?
Thank you for participating!
Paulus,
Yes me :) and I agree with Giordano
With Apo Telyt 135 mm asph some examples here :
http://www.l-camera-forum.com/leica-forum/nature-wildlife/185501-bob-poppies.html
http://www.l-camera-forum.com/leica-forum/nature-wildlife/182877-love-poppies-always-poppies.html
.... and with 90 Apo summicron asph, for example here:
http://www.l-camera-forum.com/leica-forum/nature-wildlife/195779-rose-i-love-open-thread-2.html
Henry
I don't have those two lenses, but rather the Elmarit-M 2,8/90 and Tele-Elmar-M 4/135. I don't necessarily prefer one or the other and use whatever focal length I need.
The 90mm is a little easier to frame with using the stock viewfinder and more bodies have 90mm framelines. For example, the M8 has 90 but not 135. Though that's not a big deal - I use a Leica SHOOC finder with the 135mm as it offers a 1x (1:1) view for framing. I have no problems focusing either focal length on the M7 or M8/M9. Though I do often use a 1.15x magnifier. Some day I suppose I'd like to try a 1.4x magnifier.
Any of Leica's later 90/135mm lenses are excellent. Though I'm happy with my lenses, I might at some point go for the APO-Summicron-M 90 for the extra stop in speed.
I have both and don't use them much....... both because of size and in particular weight as far as the 90/2 is concerned.
Focussing with the 135 was no problem but I had endless problems with the 90.
Now I stick to the 90/4 macro which weighs nothing, takes up no space and consistently turns in perfectly focussed and balanced images....
No point having a lens if it's inconvenient to carry with you and difficult to use ........
Hello Everybody,
The 2 lenses photograph differently.
A 90 is a lens for cutting out unwanted foreground, sides & top. As such it pretty much keeps the same perspective & feeling of a 50 while abstacting a subject from within a scene & somewhat enlarging it. It can be the easier lens to work w/.
This is why I often tell people who want to learn photograpy to begin w/ a 90 & not use any other lens until they have mastered it. It's an angle of view that often worked for Rembrant as well as many others throughout the history of painting.
A 135 is different. It only gives you a piece of the scene you are viewing. It makes you choose what to include & what not to include. It has a slight, but definite, ammount of image compression. It makes you work harder to capture a different scene than what a 90 sees.
A lot of what both lenses do is similar in many situations & either will often work equally well.
Sometimes their effect will be different because they are taking different pictures.
Best Regards,
Michael
Ergonomically speaking. About performance much is already spoken. They are both excellent. I'm interested in how easy it is to use them.
For me after 30,000 images, but not in a few years, but in 6 months the 90 I prefer but only due to my hit rate. It draws beautifully.
Buy the 90 first.
Just trying to sum up:
The 90mm apo.asph and the 135mm Apo-Telyt are both supreme lenses. Contrast and resolution could hardly be bettered. (The 90mm Elmarit as well as the Summarit or the last version of the 135mm Elmar, which I didn't try seem to be almost as good, but only almost...).
Both are rather heavy lenses for the M: the 90mmAA because of it's high opening, the Apo-Telyt because of it's length. Both show some flare in critical light, though less than e.g. a 50 Summicron. (May be the Elmarit/Summarit/Elmar versions are less sensitive for flare.)
Both are "slow" in handling, as the focus throw is long, which some people look upon as an disadvantage - I think it's an advantage. For both are difficult to focus. With a long throw you may focus more precisely. Though here also the difference starts: as you may achieve an exact focussing if you are careful with the 90mm even at f/2 it's a hit and miss trial to do so at f/3.4 with the 135mm. Leica says that you should use the 135mm stopped down to f/5.6 to achieve good focus, though many users in this forum say you can use the 135mm fully opened - and there are good results shown here in other threads. But it is a fact that the M rangefinder with 135mm is beyond it's range where it works comfortably. There are pros and cons for the eyepiece magnifier - I'd recommend to use it for both lenses and for sure with 135mm.
The other big difference is shaking: with 135mm you need very short shutter times for good results - especially with the M9. The Apo-Telyt will show it's full potential (which is enormous) only on a tripod. With 90mm you are not completely safe, but the bigger opening of the lens gives you much more security. If you compare the results of 90mm and 135mm at 1/180 sec you'll immediately see the difference: if you are not extremely shake-resistant anything longer than 1/250 does not work with 135mm.
The most evident difference between both focal lengths may be seen in the viewfinder: the field of view for 90mm is small, for 135mm it is just tiny.
(The least important difference: the Apo-Telyt cannot be coded - though you don't need the coding for your photos, just if you like them in your EXIF).
So for practical use 90mm will give you much more - though I'd never give away the Apo-Telyt.
Hello Again Paulus,
In regard to range/viewfinders: Try putting an AA or 3.4 on an M3 - An M3, whatever else it is, is a camera designed for a 90. No slouch w/ a 135 either.
Also: Keep in mind - Altho a 90 is often easier to use in situations where either a 90 or 135 will do as well & more speed is certainly an advantage there are other parameters: What does the 1 lens do better than the other the times the other is not sufficient? Which lenses are you using it w/? How do you see the World? & more.
Plus: There is such a thing as a tripod. Also: There are small sturdy table tripods w/ soft cushioned non-marking feet & large ball heads. They don't take much space & you can put or brace them in 1,000's of places if you stop to look & practice on occasion. Don't forget cable releases.
Best Regards,
Michael
after using the 90 mm several times and the 135 not so often, i think the 90 mm is much more versatile, even due to its faster speed. At the end it is rather difficult to find the correct "sight" for a 135 mm photo with the m finder - i feel very distracted by the "huge" field OUTSIDE the actual picture.. and will give it away possibly
Excellent post.
I take only on exception-I have the 135 APO coded and it works on my M9 as of the firmware update before this last one. Don't have the firmware numbers at my finger tips.
