Digilux2 Elpro advice sought
RDSChicago
Robert, welcome to the forum! :)
And congratulations on finding the Elpro!
There's not much to know about it IMHO. It doesn't make any difference to using the camera, just brings the focus distance down to half what it was before. All the controls work the same, there's no exposure difference, just a closer focus.
That's one of the benefits of the Elpros: no change in function, but a high-quality image at closer distance.
Enjoy it!
PS--A convenient way to carry it is in a plastic hockey-puck display case.
Robert,
Welcome to the forum and congratulations on acquiring an Elpro-D!
I've owned one for several years and further to what Howard said just screw it to the front of the lens set the focus ring to Macro Focus and start shooting. The exposure value is unaffected and it works through the full zoom range without a problem.
When you feel ready I hope you'll post some photos in the Forum's photo forums.
Pete.
Robert, welcome to the Forum! And congratulations on finding an Elpro-D! It is a most useful accessory for a fine camera. Once fitted, you can't stop looking for suitable subjects to shoot.
Further to this post, I too just acquired a mint Elpro D for the Digilux 2. A few things I wondered
1. WHat was the orignal price of this nice glass? I got mine for two hundred fifty clams and thought that was a decent (not great) buy, especially given the ones I;ve seen on ebay lately for about double that
2. I did not get any instruction/paper insert-- was there one originally? if so, what did it say?
3. Do we know what the minimal effective focal distance is?
Many Thanks!
Incidentally, the only thing that irritated me about the Elpro-D was that it was supplied in just a cardboard box - no protective case. Until I found the excellent leather case made by Luigi.:)
Pete.
goatster -
I think the list price new for them was between $250 and $300, but that was many years ago.
The amount $289 keeps coming to mind. Though I haven't checked this it feels as though it cuts the lens to subject distance by one half. As I recall there was no paper explaining anything with it, and as Pete observes above, it came in a cardboard box slightly larger than the Elpro. I keep mine in a clear hard plastic hockey puck case with the opening edges "painted" with red nail polish to help me figure out how to open it.
goatster -... I keep mine in a clear hard plastic hockey puck case with the opening edges "painted" with red nail polish to help me figure out how to open it.
Now where would I find one of those in the UK?
Just Googled and Amazon shows this box: http://www.amazon.co.uk/HOCKEY-PUCK-DELUXE-DISPLAY-CASE/dp/B001TWFGEI I can't see my Elpro-D living in one of those!
David--
That's the deluxe desk-top $29.99 version.
I use the plebeian version The Container Store > Small Ball & Puck Display Cubes (though the price has doubled since I bought).
When I bought the excellent Canon 58mm close up lens 250D (retail c. £80) and step down Kood rings they also arrived in a flimsy cardboard box.
Cost effective solution c £2 :-
Have a look in the kitchen cupboards/supermarket or workshop/garage for strong plastic food or similar containers that have the right diameter and then cut down to size to contain the CU lens. Then cover with self adhesive felt ( Alkhor Venilia or similar) to protect lens inside etc.
The lid in the photo is from a gravy granule container and the other 'lid' ,as far as I can remember came from the same container.:
Visiting a supermarket to size up the containers with your close up lens in your hand usually attracts the attention of security personnel::D
If a suitable sized container could be found this system could also be used to protect a lens of any size.
Regards,
David
...When I bought the excellent Canon 58mm close up lens 250D...
David
Hello,
It closes - up Canon 250 D tempts me a lot.
But where to find a reducing ring 69 towards 58 mm to adapt this lens Canon ?
Thank you.
Guy
Hello Guy,
Try Jack The Hat - - Photographic backgrounds, backdrops, strobist,
They are situated in Maryport, Cumbria UK and are a great company to deal with.
I ordered two Kood stepping rings
1x 69 - 62mm
1x 62 - 58mm
Excellent quality and finish.
(there is some vignetting using the wider end of your lens)
Total cost including shipping in UK GBP £10.98
For comparison I attach some samples with and without the Canon CU.
Regards,
David
With Canon CU lens
With Canon CU lens
With standard Leica lens
David -
Years ago I scoured a supermarket looking for a lid as a replacement lens cap for my Leica 500MM mirror lens.
Hi Stuart,
The foray into the kitchen/dining room ( a no-go area for me except to eat) looking for suitable containers caused deep suspicion from my wife, Sue. She was particularly 'pleased" when she subsequently found various products sans identifying containers with contents sealed in plastic bags - unlabelled !
David
Hello Guy,
1x 69 - 62mm
1x 62 - 58mm
Regards,
David
Very good images Davide ! :)
It is thus necessary to use two reducing rings (69-62 and 62-58) for to go 69 to 58 mm before fixing closed-up Canon 250D ?
I suppose that so focal 28 and 35 mm cannot be used.
Thanks to you.
Guy
Hello Guy,
I tried to source a single reducing ring but to no avail.
The Kood rings are well made and screw together and on the front of the D2 lens (without lens hood). Lens thickness including rings is 20mm.
I tend to use the D2 set to ' AF- Macro' or use manual focus at 90mm.
From about 50mm to 28mm vignetting does occurs but if you choose to use at these settings you could subsequently crop the image in PP.
Regards,
David
Hello Guy,
Regards,
David
Hello David,
It is perfect, thanks to your clear explanations I understood.
Large a thank you with you !
Guy
