RAw settings
Vertigo
Remember, the M has one menu under the "Menu" button, and a second one under the "Set" button.
The "Set" button is also used as an "enter" key to confirm any selection under both menus.
And things like contrast, saturation and color space are grayed out in raw, as they are meaningless.
Vertigo, The above quote is quite accurate. I am going to guess that you are using the Raw/Jpeg option which will generate some confusion. If you use the two format option (RAW/JPEG), the adjustments mentioned by Jaap will be available and not "grayed out"; but they will have no effect on the RAW image. However, they will appear to have had an effect in that the JPEG image is the one displayed. If this is your situation, you are probably better off just shooting raw and doing the adjustments with software.
A further advantage of shooting only RAW is that processing time is much, much faster. Of course battery life is also longer. regards, ron:)
